Cpt Stahl Posted June 30, 2008 Share Posted June 30, 2008 So there is my version of the freehand chapter badges : Rampagers : http://www.pix8.net/pro/pic/10647YL11A/1107509.jpg 1 : paint a white trapezoid 2 : paint the thumb. 3 : paint the fingers; 4 : fill with white 5 : Outline the fist. Note : you can jump from step 3 to 5, and fill the han later. 6 : draw the lightning. 7 : paint the lightning in yellow. -+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ Marauders : http://www.pix8.net/pro/pic/10647YL11A/1107510.jpg 1 : paint a red drop. 2 : within this drop, draw a black line; This line should be half in and half outside of the drop. 3 : at the bottom of the line, draw a little black square. 4 : amidst the line, paint a little black line. Enlarge the top of the line, on both side, to figure the sword's blade. 5 : on this small line, that crosses the sword, paint two little squares : there is the base of the sword. 6 : on the red drop, paint lines that will figure the flame. -+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ Tauran (works for Brazen & White Minautors) : http://www.pix8.net/pro/pic/10647YL11A/1107511.jpg 1 : paint a small square. 2 : paint a larger square on top of the little one. The top of this square should be "waved", like the top of a heart. 3 : besides of this square, paint ths horns. 4 : at the base of the horns, paint the ears. 5 : ad the eyes, correct here and there and the result will be fine. -+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ Finally the Scythes of the Emperor (by request of Brother Captain Aruis ) : http://www.pix8.net/pro/pic/10647YL11A/1107512.jpg 1 : paint a white "X". 2 : on top of each line, paint an incurved line. There should be some space between the incurved lines and the top of the cross. 3 : from the top of the cross, paint lines down wards to joint the incurved lines : this figures the blades. 4 : from the top of the blades, paint a sort of "M". 5 : enlarge the bases of the scythes stick. 6 : paint the whole in yellow. 7 : correct and paint thin lines of a brown/yellow mix on the stick. -+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ So, I hope this can help other players to start one of those chapters. Those freehands are not perfect, but as usually, keep in mind, that by practising, in no time your badges will look fine. CCW :no: Cpt Stahl. Link to comment Share on other sites More sharing options...
Brother Captain Aruis Posted July 1, 2008 Share Posted July 1, 2008 Thanks you this will help me. Link to comment Share on other sites More sharing options...
Sigismund Himself Posted July 2, 2008 Share Posted July 2, 2008 I was wondering why it was so quiet and enjoying the break.... More fool me :) All of them added to the Librarium. Link to comment Share on other sites More sharing options...
Cpt Stahl Posted July 2, 2008 Author Share Posted July 2, 2008 ok, will paint some more :P Cpt Stahl. Link to comment Share on other sites More sharing options...
