esinhorn Posted July 7, 2008 Share Posted July 7, 2008 Here is a tutorial on how I make my Choppers for my White Scars 1)Assemble chassis and wheels then cut off the front wheel be careful to make it flush http://i216.photobucket.com/albums/cc52/Esinhorn/CopyofPicture170.jpg 2)Use your hobby knife to make guide holes in the center where the spokes will go then drill them out using a bit slighly larger than the rod you will use http://i216.photobucket.com/albums/cc52/Esinhorn/Picture162.jpg 3) Cut a notch behind the spokes on the chassis and using pliers bend them up http://i216.photobucket.com/albums/cc52/Esinhorn/Picture163.jpg bent up, you only need to bring the spokes up a little bit to make the bike even http://i216.photobucket.com/albums/cc52/Esinhorn/Picture164.jpg 4) Take your plastic rod and cut two equal pieces about an 1" to 1" 1/4 long you can also use the plastic protectors that come with a new paintbrush http://i216.photobucket.com/albums/cc52/Esinhorn/Picture165.jpg 5) Put plastic glue on the end of one side of the rods and insert them into the holes made in the chassis spokes and let dry completely make sure they are even and line up straight at this point http://i216.photobucket.com/albums/cc52/Esinhorn/Picture166.jpg http://i216.photobucket.com/albums/cc52/Esinhorn/Picture167.jpg 6) Then put glue on the other side of the spokes and put them into the hole you made in the wheel spokes http://i216.photobucket.com/albums/cc52/Esinhorn/Picture168.jpg 7) Add handlebars,bottom and faring and you are done http://i216.photobucket.com/albums/cc52/Esinhorn/Picture169.jpg 7a) You can skip this step if you want but I take a small amout of g/s and neaten up where I cut and bent the spokes if you look close at the pic(7) you'll see where I put grey stuff Link to comment Share on other sites More sharing options...
ZsaZsaRasputin Posted July 13, 2008 Share Posted July 13, 2008 Not as good without Mikey :( lol Nice and simple job, nice one Link to comment Share on other sites More sharing options...
