IPB
IPB
Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> 'Stripey white' plague marine tutorial
nurglephill
post Mar 12 2009, 11:45 AM
Post #1
+FRATER DOMUS+
Group Icon
Group: + FRATER DOMUS +
Chapter Name:death guard
ultra smurf
Thought I would post this in here and see what you REAL nurgle fans think smile.gif
Here is a step by step guide to how I paint my plague marines. It's pretty simple and i use the same technique on tanks, dreadnoughts etc.
First up spray white and touch up with skull white paint, then (using the foundation paint set, which I water down a little to help the paint flow) paint all the metal areas orange, armour trim green and bolters red. With the red and orange I'm not very neat because I use such heavy washes that it covers up any wavey paint lines or missed bits etc. Finally paint the eyes shining gold:
the first pic didnt upload fully (dunno why) but you can see all you need to:
Now we come to the washes all of which are pretty heavy and straight from the pot. First up wash with black aiming for the deepest, darkest parts of the model AND all the coloured areas:
Then brown covering the whole model:
Then green only covering the armour and trim:
Next we start on the stripey white. I have a pot of skull white that has a lot of water added to it. You want it to be thin enough that it flows easily (without pooling into drops like water does) and you can see the colour coming through the paint after one coat. Then it is simply painting little lines on the armour. I find that going section by section works best, going over the armour with one, two or three passes to get the effect I want. Basically it's up to you and gets pretty obvious as you go. A good tip is to leave little 'drip' marks under things like studs by simply painting white around the 'drip'. It looks cool. Here are two half way shots:
and two finished:
Next up go over the green armour trim with the foundation green to cover up any mistakes with the stripey white msn-wink.gif and then catachan green in the corners or peaks as a highlight colour. I like this as its subtle and I want them looking dirty rather than shiney...so a 'dull' highlight works best I think.
Now using the foundation orange again I go over the metal (washed orange) parts but this time i use a crappy brush and 'stipple' bright orange radomly. This looks pretty good, it's fast and adds extra depth to the rust effect. On hoses etc be careful not to over do it. Then you can (i dont always, again because I'm after dull and dirty) use the foundation red to highlight the bolter:
Once thats done the last thing is to paint on (NOT drybrush) some boltgun metal over the orange. This tip was given to me by Mabs and is a fab, fab tip. Think about what bits of the metal will be used the most and therefore have the rust worn off showing the bare metal underneath....like knife blades and where your marine will be holding his bolter..etc etc and then add some in random places so you dont have too uniform a look.
The finished guy:
All he needs now is his back pack which is painted the same way and he is done.
Oh the base i paint randomly in tin bitz and camo green. Then paint pva over the base, leaving some parts bare, and use the little slate basing material from GW. When thats dry mix water effects (from GW) with green wash and dollop it on in the pools you have made by leaving bits of the base bare and then over the slate where ever you feel like. You will need two coats of this to get the effect you want. Once thats done paint the base trim foundation green.
(Note, this guy has only had one coat of the water effects, the second makes all the difference-see below)
Once the whole model is completed (backpack added etc) I spray it in mat puity seal and then go over the water effects with a gloss hard coat.
Here he is fully finished:
Done.
Phew.
Go to the top of the page
+Quote Post
Brother Nihm
post Mar 12 2009, 01:14 PM
Post #2
++INTEMPESTA NOX++
Group Icon
Group: ++ MODERATI ++
Chapter Name: Scourges of Quintus
Quick, call a Lexicanum.
This post has been edited by Brother Nihm: Mar 12 2009, 01:15 PM
My Blog | My Gallery
Call of Chaos: I | II | III | IV
+Quote Post
styx
post Mar 12 2009, 04:51 PM
Post #3
+FRATER DOMUS+
Group Icon
I like the elements of how you did the armor. May have to use some of your concepts to work on mine. I would also suggest going a tad lighter on the white perhaps mix in some of the battle grey in or something to dull down the white some. I am not a huge fan of mixing paint but IMO this may be the way to go!
+Quote Post
Iron_Chaos_Brute
post Mar 12 2009, 06:25 PM
Post #4
+FRATER DOMUS+
Group Icon
I started out with a WTF? attitude, but liked the end result.
Got to remember this...
There is no surer way to get me to tear your army list up for you than claiming that it's unbeatable.
Named Disciple of the Minigun by Minigun762, November 1st, 2009.
QUOTE (Lord_Caerolion @ Sep 8 2008, 10:39 AM) *
"Yeah, these are my Night Lords. The Lord worships Slaanesh, and is a Daemon Prince who can scare people where he wants them to go. And this is his twin, another Slaaneshi Prince, who can do the same."
QUOTE (chillin @ Nov 2 2009, 09:43 PM) *
Do you play a lot of retards?
Check out my blog at: http://ironchaosbrute.blogspot.com
+Quote Post
nurglephill
post Mar 14 2009, 06:25 PM
Post #5
+FRATER DOMUS+
Group Icon
ultra smurf
@ styx; I did think about that but pre heresy death guard had unpainted white armour with only a painted green trim. I wanted an 'only just turned' look.....so white armour left to rot etc. Hence the white. But i see your point and it is as good a choice as mine
+Quote Post
PlagueBearer
post Mar 17 2009, 09:27 PM
Post #6
+FRATER DOMUS+
Group Icon
Chapter Name:Mortis Custodis
I paint my plague marines in a similar fashion too.
Great result with a reasonable amount of effort!!!
I love white Death Guard!!!
+Quote Post
Mar Bloodaxe
post Mar 18 2009, 02:30 PM
Post #7
+FRATER DOMUS+
Group Icon
Well done!
"If you can't post anything helpful, get the hell out." DepthCharge
+Quote Post
Neves
post Mar 21 2009, 10:31 AM
Post #8
+FRATER DOMUS+
Group Icon
Chapter Name:Plague Lords, Crimson Fists
That's really nice! Me likes big time!
I'd rather see the world destroyed than ruled by any other.
+Quote Post
nurglephill
post Mar 21 2009, 02:45 PM
Post #9
+FRATER DOMUS+
Group Icon
ultra smurf
from nurgle types it means a lot
phill
+Quote Post
MrWhitey
post Mar 26 2009, 05:43 PM
Post #10
+FRATER DOMUS+
Group Icon
I must thank you nurglephill, I read this guide when you posted it (on Dakka), and decided to get back into 40k from it, with Death Guard. Never would have done so otherwise, as I didn't like the all green Plaguemarines.
I finally had them arrive today, and painted one up using your excellent guide, and the end result, whilst not as good as yours, I still quite enjoy. happy.gif
My first 500 points await painting, 2 squads of Death Guard and a Prince, off I go!
This post has been edited by MrWhitey: Mar 26 2009, 05:43 PM
+Quote Post
nurglephill
post Mar 26 2009, 08:51 PM
Post #11
+FRATER DOMUS+
Group Icon
ultra smurf
WOW.
that is so freaking cool! That looks awsome dude easily as good as mine smile.gif
I am so pleased someone actually found it a useful post. Its made my day that has
thanks
phill
This post has been edited by nurglephill: Mar 26 2009, 08:51 PM
+Quote Post
Muskie
post Mar 27 2009, 12:55 AM
Post #12
+FRATER DOMUS+
Group Icon
Chapter Name:Diseased Sons
I stuck it on my paint page... of course.
"He who desires but acts not, breeds pestilence."
Diseased Sons Homepage
Miniature Painting Blog
+Quote Post
theredcorsair
post Mar 28 2009, 06:49 PM
Post #13
+FRATER DOMUS+
Group Icon
Chapter Name:Scars of Reich (chaos and SM)
*Now where did those plague marines go that a didn't have a nice paint technique for*
Great stuff. I love this unique style and its quite a step up from the classic (and rather aging) green scheme
I'm back from the Dante's Inferno
QUOTE
I like that we refer to Argos' wedding as "The Great Crash"
+Quote Post
Nomada
post Apr 4 2009, 10:51 AM
Post #14
+FRATER DOMUS+
Group Icon
Wow! great results & easy painting! My DG look alike although I go with drybrushes.I might give it a go 4 upcoming reinforcements xDD
+Quote Post
Pake
post Apr 4 2009, 12:22 PM
Post #15
+FRATER DOMUS+
Group Icon
Chapter Name:Excubitor Letum Legio XIV
Phew!
Thank Nurgle I gave up the stripey styley. Far too many people are "having a go".
+Quote Post
nurglephill
post Apr 4 2009, 07:14 PM
Post #16
+FRATER DOMUS+
Group Icon
ultra smurf
QUOTE (Pake @ Apr 4 2009, 12:40 PM) *
Phew!
+Quote Post
Fausto2071
post Apr 5 2009, 05:24 AM
Post #17
+FRATER DOMUS+
Group Icon
Chapter Name:The Pandora Condemners
a really phenomenal paint job
oh man. an army of space marines up on ebay HERE!!!
There's no love in your violence!- Kakihara, Ichi the Killer
+Quote Post
El Cheebo
post Jan 24 2010, 10:27 AM
Post #18
+FRATER DOMUS+
Group Icon
I'm thinking of using this technique but using either blue or purple in place of green. Do you think that will work?
+Quote Post
Sevendaemons
post Jan 26 2010, 01:40 PM
Post #19
+FRATER DOMUS+
Group Icon
Chapter Name:The Klopeks
that is awesome. im gonna try that for some diverse units.
+Quote Post
aeroplane
post Jan 26 2010, 03:53 PM
Post #20
+FRATER DOMUS+
Group Icon
This is a prime example why it is totally acceptable to necro threads - this is awesome, and I didn't see it the first time around.
I love seeing techniques that use white primer; it's a wonderful way to paint certain palettes.
Thanks for a great tutorial! I will make a squad using this scheme and using the gold banding to match the rest of my army, they will look great!!!
He tasks me... he tasks me, and I shall have him! I'll chase him 'round the moons of Nibia, around the Antares maelstrom and 'round Perdition's flame before I give him up!
Perdition's Flame. VII Company, Black Legion, Chosen of the Warmaster.
+Quote Post
nurglephill
post Jan 26 2010, 05:25 PM
Post #21
+FRATER DOMUS+
Group Icon
ultra smurf
QUOTE (El Cheebo @ Jan 24 2010, 10:01 AM) *
Should do smile.gif, the good thing about this technique is its simplicity. So give it a go and post your results msn-wink.gif
QUOTE (Sevendaemons @ Jan 26 2010, 01:14 PM) *
QUOTE (aeroplane @ Jan 26 2010, 03:27 PM) *
+Quote Post
Beef
post Feb 1 2010, 01:46 AM
Post #22
+FRATER DOMUS+
Group Icon
From: The Drinking Halls of Fenris or South London as its sometimes called
Chapter Name:SPACE WOLVES
I am very impressed by the simplicity of your tecknique. Unfortunatly I dont have a Death Gaurd army. Now I wonder if this would work with my SW, hmm
AMY WINEHOUSE
Got xbox live? Add me: FLESH OF RUSS
+Quote Post
1 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
0 Members:
Lo-Fi Version Time is now: 1st August 2010 - 08:27 AM
