Quickshaded Grey Knights (not new plastic ones)
Just found couple of these lying around and decided to give them a try with quickshade, tbh i think they came alright for the quick effort =)
Edit: One more thing to add.. i used the dark tone from AP and i actually used 2 coats instead of 1 (i think 1 coat wasn't dark enough!)
They were primed with Army Painter Platemail
red = blood red (or well the coat'd'arms red equilevant)
Gold = Shining Gold GW
Cloth = Dheneb Stone GW
Skulls = Ivory Vallejo Model
Powerswords were just simply done with Asurmen Blue washes few times over
Bases were done using:
Beastial Brown -> Bubonic Brown -> Bleached Bone & then few Jungle tufts from Army Painter
If you have any more questions hit me with a PM or ask here :)
Anyhow here's the pictures(watch out for unfinished Xenos on few pics ^^):
http://cadaveri.wippiespace.com/Wh40k/GK/oldGK2.jpg
http://cadaveri.wippiespace.com/Wh40k/GK/oldGK1.jpg
http://cadaveri.wippiespace.com/Wh40k/GK/oldGK3.jpg
And little boring picture from the behind:
http://cadaveri.wippiespace.com/Wh40k/GK/oldGK4.jpg
...You gotta be kidding me.
I'm envious, I don't even want to know how much time you're probably saving. The results look awesome.
Ye, doing this the "normal" way would propably take atleast 5 times longer. Gotta love quickshade ;)
Two coats of Dark Quickshade works well on the platemail base. The GK look good. Great bases :D
BTW, watch out for posting xeno pics here on the B&C as strictly speaking it should be deleted and blasted into the Warp :D .
Two coats of Dark Quickshade works well on the platemail base. The GK look good. Great bases :)
BTW, watch out for posting xeno pics here on the B&C as strictly speaking it should be deleted and blasted into the Warp ^_^ .
aye sry about the necron, its just that those were the only pictures i had. And thx ^^
How did you apply the two coats of quickshade?
Brush on or dip?
Did you have to clean the brush with mineral spirits, if you used a brush?
I used Citadel Wash brush for applying the quickshade, after the first layer i cleaned my brush with turpentine(and water). When dry(~12-24 hours depending) i applied the 2nd coat.
After the 2nd coat was dry then i applied Vallejo matte varnish with a brush.
Hope this helped! ;)
It's a product offered by The Army Painter.
Here is a link to their store. Click on the binoculars below the products to see some before/after shots. It's basically a dip, similar to a wood stain. Actually, it is wood stain, but blended with mineral spirits or other thinner to get "the right" mix. I have used it in the past, and it did a reasonable job on my ghouls for D&D.
The application on the Grey Knights in this thread is amazing, though.
