tiny sam Posted September 19, 2011 Share Posted September 19, 2011 needed 1) 1 Bolter 2) 1 plastic Q-Tips (those cheap which always bend while using it) 3) a sharp knife 4) a fine drill 5) Super Glue Step 1) remove the bolter barrel with a sharp knife. Step 2) Cut the plastic Q-Tips with a sharp knife to the desirated lenght. Step 3) pierce a hole in the plastic tube obtain at step 2 with a fine drill Step 4) Using Super Glue, glue the barrel obtain in step 3 on the barel less bolter. should be looking like that. glue Link to comment Share on other sites More sharing options...
WeaponAdept Posted September 19, 2011 Share Posted September 19, 2011 awesome. Thanks very much! ;) ;) ^_^ Link to comment Share on other sites More sharing options...
A17roolz Posted September 19, 2011 Share Posted September 19, 2011 You know, I was just thinking "what I need now is a Stalker Pattern Bolter tutorial for my Ultramarines". Thanks muchly! Link to comment Share on other sites More sharing options...
Zincite Posted September 19, 2011 Share Posted September 19, 2011 I like it. But what are 'Q-tips'? :P Link to comment Share on other sites More sharing options...
fivepointedstar Posted September 19, 2011 Share Posted September 19, 2011 The other way to make the front silencers on a Stalker Bolter... Is to use the smoke launchers from any Rhino or older Land raider box set. This launcher has the same look as the one used by Telion. And each launcher has three, so you can get three Stalker Bolters from each. And its easier to make them just by cutting of the ends. Its super easy and better then cutting up precious ear cleaning rods. :P The Launcher I'm referring to come from this sprue. They come in two halves and are easy to cut at the base. Hope that helps Link to comment Share on other sites More sharing options...
Zincite Posted September 19, 2011 Share Posted September 19, 2011 Its super easy and better then cutting up precious ear cleaning rods. :blink: Ahhh. I see. Link to comment Share on other sites More sharing options...
tiny sam Posted September 19, 2011 Author Share Posted September 19, 2011 The other way to make the front silencers on a Stalker Bolter... Is to use the smoke launchers from any Rhino or older Land raider box set. This launcher has the same look as the one used by Telion. And each launcher has three, so you can get three Stalker Bolters from each. And its easier to make them just by cutting of the ends. Its super easy and better then cutting up precious ear cleaning rods. :blink: The Launcher I'm referring to come from this sprue. They come in two halves and are easy to cut at the base. Hope that helps mmm good Idea! after all it's the may objective of that Forum, sharing knowledge :) Link to comment Share on other sites More sharing options...
spiros14 Posted November 14, 2011 Share Posted November 14, 2011 Additionally, using the barrels of the scout boltpistols work pretty well. Link to comment Share on other sites More sharing options...
