Dusktiger Posted November 21, 2012 Share Posted November 21, 2012 Hey, so this is a step by step guide to make the Diemos Predator kit. this is both to demonstrate the parts that come in the kit, and show what prep-work needs doing for it to come together. I'm making it as a Predator Destructor with Heavy Bolter sponsons, like this: http://www.forgeworld.co.uk/Images/Product/AlternativeFW/large/preddeimos1.jpg OVERVIEW http://farm9.staticflickr.com/8342/8204097987_4b3e33e10d_z.jpg The stuff highlighted in green are the parts used to make your sponsons. the left square is the armor plating that goes in front of the them when completed. STEP 1: Prep Work http://farm9.staticflickr.com/8339/8204097841_c6d857be9f_z.jpg to start off, you need to trim the back of the top-plate. if not, the plate that goes here for the turret won't fit. here it is fitted after trimming: http://farm9.staticflickr.com/8069/8205189054_050ef57c3e_z.jpg STEP 2: Body Assembly http://farm9.staticflickr.com/8208/8205188952_cd818ea862_z.jpg assemble your rhino body up to this stage. then add the top-plate. this has to be done, because the new outside walls wrap around the top-plate. http://farm9.staticflickr.com/8488/8204097495_0a02895cdd_z.jpg here's the sides installed: http://farm9.staticflickr.com/8065/8205188720_4963c516d9_z.jpg And here's the front plate installed: http://farm9.staticflickr.com/8486/8205188544_0d01b9635b_z.jpg finally, the new top-plate is mounted: http://farm9.staticflickr.com/8197/8204097037_7581fa1680_z.jpg STEP 3: Hatch Assembly the kit came with 2 hatches, but unfortunately, they're the same thickness: http://farm9.staticflickr.com/8062/8205188368_cc89338946_z.jpg this is a problem, since this is the right thickness for the left cupola that normally holds your storm bolter wielding guy. so one of the two needs to be sanded down thinner for the right cupola: http://farm9.staticflickr.com/8343/8204096819_5c240ba782_z.jpg Here they are installed: http://farm9.staticflickr.com/8067/8204096701_707b6472ae_z.jpg Link to comment Share on other sites More sharing options...
Dusktiger Posted November 21, 2012 Author Share Posted November 21, 2012 STEP 4A: Sponson Mount Assembly so here's the 4 parts that make the sponson mount:http://farm9.staticflickr.com/8340/8204096581_2bca521733_z.jpgattach the armor plating to the gun mount, like so:http://farm9.staticflickr.com/8347/8205187878_eb4c716836_z.jpgnext is to place the inner pin that allows the sponson to rotate up and down freely. if you want this to move, don't glue this in place:http://farm9.staticflickr.com/8208/8204096281_d996878e33_z.jpgnow glue the gun mount to the pin, again, take care not to get any glue on the bracket that holds the pin if you want this to move freely:http://farm9.staticflickr.com/8350/8204096155_1268a66797_z.jpghere's the sponson mounted on the tank:http://farm9.staticflickr.com/8479/8205187476_c6641e5faf_z.jpghttp://farm9.staticflickr.com/8202/8205187366_82a258c6b9_z.jpghttp://farm9.staticflickr.com/8205/8205187276_724ff73007_z.jpghttp://farm9.staticflickr.com/8490/8204095745_36ddeb1c37_z.jpgSTEP 4B: Sponson Weapon Assembly here's the pieces to make the sponson, unassembled. the power cord and the targeting sensor are what attach it onto the mount, so dont glue these together ahead of time.http://farm9.staticflickr.com/8062/8204095437_797ee7aee8_z.jpgthe ammo drums are specific to each gun. as you'll see below, it has a groove to fit over the shell eject port. the guns are made with the shell eject port on both sides; the drum covers the inside-facing one.http://farm9.staticflickr.com/8207/8204095123_7508aa4507_z.jpgonce mounted, it looks like this:http://farm9.staticflickr.com/8207/8205186760_d1d79c168e_z.jpghttp://farm9.staticflickr.com/8210/8205186624_75a48e7b78_z.jpgFINAL this is the tank after the turret was mounted. i've left off the exhausts so i can paint them easier:http://farm9.staticflickr.com/8485/8205186418_cb72947fac_z.jpg Link to comment Share on other sites More sharing options...
caprera Posted November 23, 2012 Share Posted November 23, 2012 Bookmarked Thanks ! Link to comment Share on other sites More sharing options...
Iacton Qruze Posted November 29, 2012 Share Posted November 29, 2012 awesome. +1 for including so many pics for easier scratchbuild replication. :lol: Link to comment Share on other sites More sharing options...
