Acebaur Posted May 13, 2014 Share Posted May 13, 2014 (edited) So I thought I would throw together a post with as comprehensive list as I can of all the third party sites that have bitz that can be used on our Templar mini's. If you know of something that's not on here please post it and I will add a link to the first post. I'll be adding this to the Black Templar Resource at some point too, so you'll always be able to find it there. Forgeworld FW Templar search (includes pads, shields, vehicles doors, etched brass and the Dreadnought) Scibor http://sciborminiatures.com/en_,shop.php (Enter search criteria templar to see all their products) They have pads, shields, bodies(from torsos to full miniatues), Vehicle accessories and bases Max mini Knight heads Power Maul/Thunder Hammers Cloaks Anvil Industry Robed Legs Cloaks Loincloths Grill Heads Skull Heads (For Chaplain conversions) Crusader/Purity Seals Chains http://www.builders-in-scale.com/bis/parts-chain.html (40 lpi for PA, 27 for TDA, 15-16 for Dreads) Kromlech Rippers - Large two handed chainswords and relic blade Kreuz Shields - Shields with crosses on them Legionary Vibro Swords - Could make good power weapons Legionary Spike Hammers - Possible power mauls Armorcast Decals - Various Cross decal sheets Puppetswar Knight Helms Swords Axes Pretorian Pads - Similar look to the Command Squad Champion's pads Crusader Termos bodies - Could be alt TDA bodies Backpack Banners Standard Bearer Banner Spellcrow Knight Helms Templar Knight Helms Knight Legs Tabard Torsos Templar Tabard Torsos Storm Shields Tabard Bottom Halves Templar Tabard Bottom Halves Edited January 21, 2017 by Acebaur Ebon Hand, Marshal Valkenhayn, Marshal Rohr and 6 others 9 Back to top Link to comment Share on other sites More sharing options...
Honda Posted May 13, 2014 Share Posted May 13, 2014 Nice. I can see where we'll probably want to pin this at some point. Did Dono give us the link for those two handed chainswords he was going to use his Reliquary building? Link to comment Share on other sites More sharing options...
DasPanzerIstUber Posted May 13, 2014 Share Posted May 13, 2014 Do you mean the Kromlech Rippers? Link to comment Share on other sites More sharing options...
Marshal Rohr Posted May 13, 2014 Share Posted May 13, 2014 Max mini has a set of nice swords too. The cross guards are a little more Dark Angel than Templar but you can shave them off and use the back from the upgrade sprue axes in their place. Link to comment Share on other sites More sharing options...
Honda Posted May 13, 2014 Share Posted May 13, 2014 Do you mean the Kromlech Rippers? Yes, that would be them. Thank you. Link to comment Share on other sites More sharing options...
Krikey Posted May 14, 2014 Share Posted May 14, 2014 Chains! http://www.builders-in-scale.com/bis/parts-chain.html The 40 lpi is good for power armor weapon chains, the 27 good for TDA weapons, and the 15 or 16 good for dreadnoughts. You can also use even lower lpi for vehicles. I buy the black chain -- it has a surface ready for painting, so you can place it on miniatures already primed. ~K Acebaur 1 Back to top Link to comment Share on other sites More sharing options...
Acebaur Posted May 14, 2014 Author Share Posted May 14, 2014 (edited) Chains! http://www.builders-in-scale.com/bis/parts-chain.html The 40 lpi is good for power armor weapon chains, the 27 good for TDA weapons, and the 15 or 16 good for dreadnoughts. You can also use even lower lpi for vehicles. I buy the black chain -- it has a surface ready for painting, so you can place it on miniatures already primed. ~K Thank the Emperor you posted this. I've been wondering this forever and now I know where to get them. I'll add it to the first post! Edit: added. Also how to you get them to stay put in the position you want them in? Edited May 14, 2014 by Acebaur Link to comment Share on other sites More sharing options...
Marshal_Roujakis Posted May 14, 2014 Share Posted May 14, 2014 Usually Super Glue, just put it between the joins and be really thin about it, after spraying with paint it usually stays in place. Link to comment Share on other sites More sharing options...
Krikey Posted May 15, 2014 Share Posted May 15, 2014 Edit: added. Also how to you get them to stay put in the position you want them in? What Roujakis said. I usually place them and then very carefully use very thin superglue to set them. Thicker superglue for a dangling/hanging chain. ~K Link to comment Share on other sites More sharing options...
DasPanzerIstUber Posted May 15, 2014 Share Posted May 15, 2014 Uh following up on the Rippers, they're big. About 2" including the handle. I know 40k weapons are rarely realistic but these ones are huge. Just a heads up for anyone planning on using them! :lol: Link to comment Share on other sites More sharing options...
Acebaur Posted May 15, 2014 Author Share Posted May 15, 2014 Uh following up on the Rippers, they're big. About 2" including the handle. I know 40k weapons are rarely realistic but these ones are huge. Just a heads up for anyone planning on using them! That sword that is pictured with them, is it the same size? That seems like it could make a good TDA weapon for my counts as Templar Deathwing Knights. Also added them to the first post Link to comment Share on other sites More sharing options...
DasPanzerIstUber Posted May 15, 2014 Share Posted May 15, 2014 Yeah the picture is correct. So the double sided chainsword and power sword are a bit shorter, but they are also thinner and look more appropriate. The big chainsaw in the middle would make an epic Teeth of Terra if you find someone strong enough to carry it. :)Would photos be useful? Link to comment Share on other sites More sharing options...
Acebaur Posted May 15, 2014 Author Share Posted May 15, 2014 Yeah the picture is correct. So the double sided chainsword and power sword are a bit shorter, but they are also thinner and look more appropriate. The big chainsaw in the middle would make an epic Teeth of Terra if you find someone strong enough to carry it. Would photos be useful? Yeah that would be great. If you can throw a termie in the pic for scale on the power sword that would be awesome Link to comment Share on other sites More sharing options...
Krikey Posted May 15, 2014 Share Posted May 15, 2014 Also from Forge World, Mk III and Mk IV power weapons (especially the Mk III). Mk III: http://www.forgeworld.co.uk/Warhammer-40000/Space_Marines/Space_Marine-Infantry-and-Accessories/LEGION_MKIII_POWER_WEAPONS_SET.html Mk IV: http://www.forgeworld.co.uk/Warhammer-40000/Space_Marines/Space_Marine-Infantry-and-Accessories/LEGION_MkIV_POWER_WEAPON_SET.html Each kit has vicious axes, chainswords (including a 2-handed one), power swords, a thunder hammer, a maul, lightning claws, power fists, various pistols, and some good belt-sized melta bombs. ~K Link to comment Share on other sites More sharing options...
Marshal Rohr Posted May 15, 2014 Share Posted May 15, 2014 The mark 3 heavy chainsword would be a very cool replacement for a teeth of Terra Link to comment Share on other sites More sharing options...
DasPanzerIstUber Posted May 18, 2014 Share Posted May 18, 2014 Sorry for the delay. Here's a comparison shot between the Kromlech Rippers, an Initiate and a Sword Brother. Link to comment Share on other sites More sharing options...
Kyliadan Posted May 18, 2014 Share Posted May 18, 2014 (edited) I use the big Kromlech one as my marshall's Teeth of Terra, here he is to give you an idea of what to expect : http://hpics.li/ac2882f http://hpics.li/5321ccf (Edit : actually it shows one of Scibor's shoulders and shield, too) Edited May 18, 2014 by Kyliadan greggles and minigun762 2 Back to top Link to comment Share on other sites More sharing options...
NoPityNoRemorseNoFear Posted December 1, 2014 Share Posted December 1, 2014 Here is the site that I am looking at for Templar Heads: http://puppetswar.eu/product.php?id_product=274 also if you are wanting cheaper Forgeworld Brass you can get it from here: http://cadwallon.com/etched-brass-black-templars-symbols.html ThatOneMarshal 1 Back to top Link to comment Share on other sites More sharing options...
Acebaur Posted December 2, 2014 Author Share Posted December 2, 2014 Puppetswar also has swords, axes and some cool looking pads. I updated the first post with them. Link to comment Share on other sites More sharing options...
Sete Posted December 2, 2014 Share Posted December 2, 2014 (edited) Axes? Im sorry im not a space furry. ;) Can you post a pic of the swords? Im procastinating a bit at work. Edited December 2, 2014 by Sete Link to comment Share on other sites More sharing options...
Acebaur Posted December 2, 2014 Author Share Posted December 2, 2014 Axes? Im sorry im not a space furry. Can you post a pic of the swords? Im procastinating a bit at work. Click on the link? They have the pic on their site. Swords are definitely more knightly, but I might remind you that we have axes in our upgrade sprue ;) Link to comment Share on other sites More sharing options...
Sete Posted December 2, 2014 Share Posted December 2, 2014 (edited) Im not procastinating that much ;) Saw the swords. Hmm... those spiky bits after the hilt kills it... Axes are a rude weapon... they lack the class and finesse of a proper blade. Its a butcher's weapon. Edited December 2, 2014 by Sete Link to comment Share on other sites More sharing options...
Arthanor Posted December 2, 2014 Share Posted December 2, 2014 Not quite official yet, but I am coming out of the warp to share a blurry teaser for my brothers. Forgeworld's 30K Templar bits: http://tapatalk.imageshack.com/v2/14/12/02/9af26d8ea2d9baceffa3411b578f6a4d.jpg ThatOneMarshal, Marshal Reinhard, Brother Richard and 1 other 4 Back to top Link to comment Share on other sites More sharing options...
Sete Posted December 2, 2014 Share Posted December 2, 2014 Dem swords. Link to comment Share on other sites More sharing options...
Firepower Posted December 2, 2014 Share Posted December 2, 2014 (edited) The bulk of the shoulders come with arms already attached? Annoying...and why the backpack? Edited December 2, 2014 by Firepower Link to comment Share on other sites More sharing options...
