Chinchillapimp Posted July 18, 2006 Share Posted July 18, 2006 I Link to comment Share on other sites More sharing options...
Ferrata Posted July 18, 2006 Share Posted July 18, 2006 I also have compiled a similar list, although mine was done with little research and purely mathamatical. I would be intrested to know why you chose certain dates for foundings instead of spacing them evenly. Founding/Yours/Mine/Difference 01 400.M29 400.M29 = 02 000.M31 000.M31 = 03 000.M32 000.M32 = 04 200.M32 200.M32 = 05 400.M32 450.M32 +50 06 600.M32 700.M32 +100 07 700.M32 900.M32 +200 08 900.M32 100.M33 +200 09 100.M33 350.M33 +250 10 200.M33 550.M33 +350 11 400.M33 800.M33 +400 12 600.M33 000.M34 +400 13 800.M33 200.M34 +400 14 000.M34 450.M34 +450 15 200.M34 650.M34 +450 16 500.M34 900.M34 +400 17 800.M34 100.M35 +300 18 200.M35 350.M35 +150 19 600.M35 550.M35 -50 20 800.M35 800.M35 = 21 100.M36 000.M36 -100 22 500.M36 150.M37 +650 23 000.M38 300.M38 +300 24 500.M39 450.M39 -50 25 700.M40 600.M40 -100 26 738.M41 738.M41 = 221.M33 Founding of the Howling Griffons 10/8-9 598.M35 Founding of the Astral Claws 19/19 Link to comment Share on other sites More sharing options...
Chinchillapimp Posted July 19, 2006 Author Share Posted July 19, 2006 I intentionally adjusted some of the dates so that there was less of a pattern. While there is a certain anal-ness that I can appreciate to laying out the dates according to a formula, it seems completely counter to the fluff to have exact spacing between the foundings. Rarely in any large bureaucracy does anything happen with a consistent pattern, let alone the largest empire ever created by humans. There would be countless factors influencing exactly when the High Lords would make the call to establish the next founding. Is there something in the fluff that would make the foundings seem planned millennium ahead of time? To recap my process: GW stated definitively only a handful of exact dates for foundings, 2nd, 3rd, 26th. They also give a very specific time for the 21st founding: immediately before the Age of Apostasy in early M26. This means that for whatever reason, the number of foundings plummeted after the 21st founding. I considered that perhaps the disastrous nature of the cursed founding caused the High Lords of Terra to cut back on foundings, but it doesn't seem likely, as the pattern of gene-seed irregularities wouldn't have been documented and disseminated until many centuries later, long after another founding would be due. It seems more likely to me that the number of foundings simply declined over time, so by M41 the foundings are happening more than one millennium apart. After I added all of the known dates to the timeline, I spaced them out in a roughly decreasing pattern. Six in M32, five in M33, four in M34, and three in M35. I then nudged them by a century here and there so that some of the other known dates aligned with the list. Once all available official founding dates were somehow part of it, I looked at other events not related to the foundings, such as the dates of Black Crusades and other galactic events. I again nudged some of the dates to fall soon after those events. The rest of the dates I was intentionally sloppy about dating so to give the dates the organic feel I discussed above. Link to comment Share on other sites More sharing options...
Kurgan the Lurker Posted July 19, 2006 Share Posted July 19, 2006 Would probably help if people site their sources for Founding Dates. You may also want to check out WD249 (US). It has a list of the Chapters from the A3 campaign -- they have an M marking under them which *might* be a Founding Millenia for the Chapter. Link to comment Share on other sites More sharing options...
Chinchillapimp Posted July 19, 2006 Author Share Posted July 19, 2006 "Would probably help if people site their sources for Founding Dates." How dare you ask me to name sources! :D I had a lingering suspicion that was going to become a necessary part of this. You are certainly right though; that needs to happen if this list will be truly useful at all. "You may also want to check out WD249 (US)..." Will do! Link to comment Share on other sites More sharing options...
Ferrata Posted July 19, 2006 Share Posted July 19, 2006 I intentionally adjusted some of the dates so that there was less of a pattern. While there is a certain anal-ness that I can appreciate to laying out the dates according to a formula, it seems completely counter to the fluff to have exact spacing between the foundings. Rarely in any large bureaucracy does anything happen with a consistent pattern, let alone the largest empire ever created by humans. There would be countless factors influencing exactly when the High Lords would make the call to establish the next founding. Is there something in the fluff that would make the foundings seem planned millennium ahead of time? The major probelm between the systems is intent. Your intent to to have a speculative list, while mine was created to be a rough guide. Your list, your trying to make it look realisitic so that *could* be the founding dates, but its not. Mine is no-way trying to look realisitic, but if were to estimate were a founding took place it would be around that date. I'm not saying the foundings were set distances apart, but for estimation formula work best. Link to comment Share on other sites More sharing options...
Chinchillapimp Posted July 19, 2006 Author Share Posted July 19, 2006 Ahhh, then yes Link to comment Share on other sites More sharing options...
Heru Posted July 19, 2006 Share Posted July 19, 2006 Hmm 13th Founding was the Dark Founding, I believe the Age of Apostasy happened right after that not after the Cursed Founding (Age of Apostasy was when High Lord Vandire went nuts right, and allot of SM Chapter info etc was lost?). Edit: Nevermind the Age of Apostasy was M36 just after the Cursed Founding. ::Doh!:: Hmm anyone know why it was the 13th Dark Founding didn't have any official records? Link to comment Share on other sites More sharing options...
Tubal Posted July 19, 2006 Share Posted July 19, 2006 One theory about the decreased rate could be that the number of loyal and unmutated chapters have stabilized. If a certain percentage of chapters in a founding is purged of lost for whatever reason the number of chapters will grow slower, but eventually their numbers will reach a certain level that the HLoT consider enough. Any chapters that survive a few millennia are likely to keep going so fewer are lost, and fewer are created. In other words, any more foundings are just to keep the numbers up. Just a theory :) Link to comment Share on other sites More sharing options...
Chinchillapimp Posted July 26, 2006 Author Share Posted July 26, 2006 You may also want to check out WD249 (US). It has a list of the Chapters from the A3 campaign -- they have an M marking under them which *might* be a Founding Millenia for the Chapter.Do you know where in WD249(US) it is? I've scoured it and I'm not sure it's in there. The 40K articles are: Index Astartes: The making of a Space Marine Alien Menace part II: A further look at the Ork tribes on Armadeggon Ancient Threat: The Chaos Land Raider Any ideas? Link to comment Share on other sites More sharing options...
Brother Tyler Posted July 26, 2006 Share Posted July 26, 2006 The only complication with the possible founding dates shown in the Index Astartes article depicting the Chapters that participated in the Third War for Armageddon is the Mortifactors. I always saw those dates as the founding dates, too. And then Warriors of Ultramar came out. Where the IA showed the Mortifactors as M.40, a very recent founding. WoU, however, turned the Mortifactors into a Second Founding Successor of the Ultramarines. So depending on how much stock you put in BL books, the dates given in the IA may or may not be accurate. If you do consider those dates accurate, though, both the Angels of Fire and the Relictors (formerly the Fire Claws) were also from M.36. I have to agree with Chinchillapimp on the regularity (or lack thereof) of Foundings. The Imperium creates new Foundings based on need, not a schedule. I think it is much more likely that there are varying gaps between Foundings, allowing for anywhere from a couple of centuries up to a couple of millennia between Foundings. Link to comment Share on other sites More sharing options...
Deadlight Posted July 26, 2006 Share Posted July 26, 2006 To be honest i think that WD writer got it wrong with the mortifactors. Mortifactors have been around since 2nd edition and where listed as one of the first founding successor chapters of the ultramarines, in the ultramarine codex for 2nd edition. They are definiately not as new as the IA article suggests Link to comment Share on other sites More sharing options...
Ferrata Posted July 26, 2006 Share Posted July 26, 2006 I have to agree with Chinchillapimp on the regularity (or lack thereof) of Foundings. The Imperium creates new Foundings based on need, not a schedule. I think it is much more likely that there are varying gaps between Foundings, allowing for anywhere from a couple of centuries up to a couple of millennia between Foundings. I agree, the foundings will be all over the place, with no pattern or regularity, but there is noway we can estimate this irregularity. We could not create a list of foundings with all of them correct or even close. With the irregular foundings, you might get one dead on, while the other might be a thousand years out. With the formula system, yes, you will probably never on the money but you shouldn't stray too far from the path. Link to comment Share on other sites More sharing options...
Aurelius Rex Posted July 26, 2006 Share Posted July 26, 2006 I was interested to read this thread, and some thought has gone into it. However, by laying down even speculative dates for the foundings outside the known ones you are holding your IA hostage to fortune and to GW if they finally do give a date for the other foundings, and also you are kind of treading on the toes of others by saying that 'My chapter was from the 6th founding in 555.M33' and stating such a wideranging thing as a fact. A simple way to get round this is to state that they are 6th Founding, sure, but being ambiguous about the date even down to the Millennia if need be. To me this seems much more appreciative to others and if written well it detracts not a jot from the quality of your IA article. :angry: Link to comment Share on other sites More sharing options...
Kurgan the Lurker Posted July 26, 2006 Share Posted July 26, 2006 You may also want to check out WD249 (US). It has a list of the Chapters from the A3 campaign -- they have an M marking under them which *might* be a Founding Millenia for the Chapter.Do you know where in WD249(US) it is? I've scoured it and I'm not sure it's in there. The 40K articles are: Index Astartes: The making of a Space Marine Alien Menace part II: A further look at the Ork tribes on Armadeggon Ancient Threat: The Chaos Land Raider Any ideas? My mistake, WD248 US. The "Emperor's Shield" IA article, page 76. It lists the Chapters that fought during the A3 Campaign and gives a millenium note to each Chapter. Now this *might* be a Founding date but then it might not as ther are some inconsistencies in the dates. I'll list the Chapters and the M date attached to the image: Celebrants M36-41 Black Dragons M36 Angels of Redemption M31 Blood Angels M31 Salamanders M31 Raptors M31 Black Templars M31 Mortifactors M40 Storm Lords M31 Storm Giatns M41 Omega Marines M40 Space Wolves M31 Angels of Fire M36 Silver Skulls M31 Marines Malevolent M32 Relictors M36 Sons of Guilliman M33 Celestial Lions M38 Angels of Vigilance M40 Angels Porphyr M31 Exorcists M40 White Scars M31 Flesh Tearers M31 Iron Champions - note says "founding unrecorded" Mortifactors have been around since 2nd edition and where listed as one of the first founding successor chapters of the ultramarines, in the ultramarine codex for 2nd edition. They are definiately not as new as the IA article suggests May want to check that. I just went thru my 2nd ed UM dex. Not only are the Mortifactors not listed as a "First Born" Chapter, but they aren't even pictured in the Codex Chapters section of the Codex. Link to comment Share on other sites More sharing options...
Chinchillapimp Posted July 26, 2006 Author Share Posted July 26, 2006 I was interested to read this thread, and some thought has gone into it. However, by laying down even speculative dates for the foundings outside the known ones you are holding your IA hostage to fortune and to GW if they finally do give a date for the other foundings, and also you are kind of treading on the toes of others by saying that 'My chapter was from the 6th founding in 555.M33' and stating such a wideranging thing as a fact. A simple way to get round this is to state that they are 6th Founding, sure, but being ambiguous about the date even down to the Millennia if need be. To me this seems much more appreciative to others and if written well it detracts not a jot from the quality of your IA article. :P I totally agree. Writing fiction around a speculative list of dates is likely to cause problems with later official fluff. That Link to comment Share on other sites More sharing options...
utilityzero Posted July 27, 2006 Share Posted July 27, 2006 well, i personally have never been of the impression that a founding was a one day event... i mean, it takes 50 years to create a chapter and if a dozenchapters are created at once... then they might not start on each one on the same day, and from what we have agreed upon here they don't all undergo the same level of training and mentoring, so they won't all actually 'found' on the same day, or even in the same year. a founding could concievably be spaced out over as much as a decade, or even a century. you've got like 10,000 years to fit in 25 foundings, that's 4 per millenium, right? that would put the 21st founding in the end of the 35th, begining of the 36th millenium if i'm counting right. so by that system, he's just about right, but you'll never really know, it's best to just pick a founding in my opinion. Link to comment Share on other sites More sharing options...
