Exorcist hellstorm
  • Please log in to reply
4 replies to this topic
#1
high marshall jordan
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 133 posts
  • Faction: Order Of The Holy Flame(SOB)
thought i might try to create a datasheet for my exorcists for apocalypse
exorcist hellstorm formation
3-6 exorcists+150 points
one exorcist must be assigned as the command tank
strike force same as any other formation
exorcist hellfire: when 3 or more excorsists target the same unit they may instead use the hellstorm wepon profile
Hellstorm
range=48 in. strength=D AP=1 fires heavy D6 for every 3 exorcist firing
lead the faithful: for every 3 exorcist add 2 faith points to the faith point pool but does not benefit the martyrdom rule
SUFFER NOT THE WITCH TO LIVE
92% of teens have moved on to rap. If you are part of the 8% who still listen to real music, copy and paste this into your signature.
Metal is what we love.
#2
Jaron95
Jaron95
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 53 posts
That's cool. The Witch Hunters could use a native Strength D option in Apocalypse.
What if you mix it up like the new Eldar Sunstorm Squadron?
Exorcist Hellfire: When 3 or more Exorcists target the same unit, consult the Hellstorm damage chart:
Hellstorm:
3 firing: Range 48", Strength D, AP 1, Heavy D6
4 firing: Range 48", Strength D, AP 1, Heavy D6, Pinning
5+ firing: Range 48", Strength D, AP 1, Heavy D6, Pinning, Blast
This adds some extra tactical advantages to aiming multiple Exorcists at infantry units without giving them the potential to fire 12 Strength D shots in a single turn.
I would add some delayed gratification to the Lead the Faithful rule too. Drop it down to one Faith Point for 3 tanks and two Faith Points for 6 tanks. Let them use Martyrdom when the 3rd tank and the 6th tank are destroyed by enemy shooting or assaulting (not if they are wrecked by dangerous terrain or simply immobilized, sort of like how Faithful characters who are removed by Sweeping Advance do not receive Martyrdom).
Edited by Jaron95, 21 December 2007 - 02:26 AM.
#3
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 133 posts
alright i revised it a bit thanx to jaron
exorcist hellfire: when the entire formation fires at a single unit consult the hellstorm weapon profile
Hellstorm
3 firing: range=48 in. strength=D AP=1 heavy D6
4 firing: range=48 in. strength= d AP=1 heavy D6, pinning
5 firing: range=48 in. strength= d AP=1 heavy D6, pining, rending
6 firing: range=48 in. strength= d AP=1 heavy D6, pinning, 2D6 armor pen.
lead the faithful: for every 3 exorcist add 1 faith points to the faith point pool and for every 3 exorcist destroyed/explodes/annihilated benefits from the martyrdom rule
#4
Jaron95
Jaron95
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 53 posts
Strength D automatically penetrates when it scores a hit, so it wouldn't need 2D6 extra penetration. :P
Edited by Jaron95, 24 December 2007 - 07:51 PM.
#5
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 133 posts
alright im giving this another try so here goes
exorcist hellfire: such is the concentration of fire when the entire formation fires at a single unit consult the hellstorm weapon profile
Hellstorm
5 firing: range=48 in. strength= d AP=1 heavy 2D6, pinning
6 firing: range=48 in. strength= d AP=1 heavy 2D6, pinning, +2 damage chart
with such an amount of fire if any of the heavy D6 were to be a 6 one exorcist of your choice cannot fire its exorcist missile launcher next turn as it has fired all available missiles and must to take the time to reload though may fire anything else(pintle mount strom bolter)
all exorcists must be in range to count towards the firing and those not within range cannot fire on anything else
lead the faithful: when such symbols of the emperors will come together to fight for every 2 exorcist add 1 faith points to the faith point pool and for every 2 exorcist destroyed/explodes/annihilated benefits from the martyrdom rule
