2000pts Deathguard
7 replies to this topic
#1
Ridmasta
Ridmasta
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 34 posts
Im starting up the deathguard, all i have is the gw nurgle daemon prince so far! This is my first stab at a list:
2 Daemon Princes - 350pts
MoN, Wings, Warptime
7 Plague Marines - 211pts
2 Flamers, Champion with Powerfist and combi-weapon
7 Plague Marines - 241pts
2 Meltaguns, Rhino with Possession and combi-bolter
2 Landraiders - 500pts
Possession, combi weapons
Please tear it apart!
#2
veidin
veidin
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 212 posts
Drop a Melta PM squad pickup 2 Termicide squads, and switch one prince to a rot prince for hordes, would be my only recommendation otherwise looks pretty solid! Demetrii and Zhukov should have any other ideas.
#3
the jeske
the jeske
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 19,518 posts
never possession on anything else then vindicators . out with the combis on transports for first 2 turns they should be moving 12"/poping smokes etc and after that your either in hth or stuned or blown up.
change the set up of squads . the LR squads are going to be charging in with DPs support they dont need the extra flamer shots , while on the other hand puting a wound on a MC with multi melta on an instan shot on a nob biker may be worth it . At the same time your aspchapionless squads should really avoid getting out of the rhinos and if thats the case then flamer drive by[even with tank shock] is the better option then 2 meltas.
I do agree that I would drop or trim one of the pm squads [maybe 5/6 man camper unit or switch to demons] to get either termicid/oblit or gear up the two other squads .
"Felix wondered how Calgar might feel about the primach's unilateral altering of the Codex Astartes. The captain could not help but feel that, in his drive for victory and efficiency, Guilliman had been careless with the feelings of his existing sons. Increasingly, Guilliman looked to the Primaris Space Marines as his first solution. He made no attempt to hide the fact that the days of the older space marines were numbered."
#4
DemetriiTZ
DemetriiTZ
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 553 posts
Ditch possession on the Raiders and lose the Rhino combi-weapons, like Jeske said. Also, drop Warp Time from one Prince (maybe), to free up some points for:
Giving all your Rhino squads Champions, with an appropriate combi-weapon (flamer, or melta), and powerfists. I figure you probably wanna avoid Termicide and aim for a pure Death Guard build, but if you don't, Termicide is highly effective for the points.
#5
Ridmasta
Ridmasta
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 34 posts
Cheers guys,
I take it termicide is a 3man combi melta and chainfist squad?
#6
Zhukov
Zhukov
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,363 posts
Nope combis only, so 105 points each.
I'm open to messages if you want help or advice from me.
You can ask me anything.
#7
Ridmasta
Ridmasta
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 34 posts
No mark or anything... that is a propa suicide squad!
#8
nurglez
nurglez
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,701 posts
aye, hence the name. they drop down, melta something, then are a speed bump <_<
I sometimes prefer a termicide squad with 2 combi melta and a heavy flamer, just so they can threaten more units :P
