Sabre Super-Heavy Tank
4 replies to this topic
#1
Freelancer
Freelancer
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 13 posts
The Sabre was developed in 399.M40 following the discovery of the STC for a feasome weapon, dubbed the Quasar Cannon. The Quasar Cannon was developed on Mars itself, using the STC along with technology recovered and salvaged from Eldar D-cannons. Within a relatively short time the cannon was readyfor the primary tests. Mounted on a Shadowsword chassis, the cannon is a devestating, if not unpredictible weapon.
Although the cannon was developed on Mars using xenos tech, it was under extreme secrecy due to the lack of knowledge of Vortex weapons on this scale
0-1 Sabre Super-Heavy Tank
SP: 3
Armour: F14 S13 R12
BS 3
Weapons
1 Hull mounted Quasar Cannon
2 Sponson mounted twin linked heavy bolters
2 Sponson mounted las-cannons
Quasar Cannon
Range: 72"
S-
Ap-
Ordinance 1*
* After the target is chosen roll D6. This is the radius of the blast's effect. Any model hit suffers a Vortex hit. On the result of a 1, the Sabre suffers a Vortex hit as the Sabres Warp generators overload.
Comments? Too powerful? Overpriced?
Edited by Freelancer, 17 May 2009 - 07:19 PM.
#2
ryan.............
ryan.............
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 116 posts
sounds pretty awesome, not too pricey and has good rules, i wouldnt have i problem with someone fielding one....
92% of teens have moved on to rap. If you are part of the 8% who still listen to real music, copy and paste this into your signature
click him or her, im not quite sure yet:
#3
Frosty the Pyro
Frosty the Pyro
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,729 posts
I would veto this, its cannon is unequivicably stronger than a vortex grenade. A vortex grenade is one shot, short ranged (6"), has a solid chance of scattering into you units, it cost 250pts+the model that has to carry it. This has a larger blast radius, longer rang, without risk of comming back to bite you, and can be fired as many times as you have turns.
It ignores cover, invulnerable, armor, number of wounds, eternal warior, everything. What it hits dies, unless its a superheavy or gargantuan creature, then it just has a good chance of dieing.
TL:DR vortex CANNONS are a bad idea
Also using xeno tech in its creation is heresy, please report to the nearest commisar for exicution.
QUOTE (War Angel @ Jan 20 2009, 07:06 PM) <{POST_SNAPBACK}>
i have orderd 36RB's and 30 speeders. Emperor help me, this will be done
My Offical 40k Hero: War Angel
QUOTE (nighthawks @ Jan 7 2010, 07:02 PM) <{POST_SNAPBACK}>
QUOTE (Sgt. Farney @ Jan 7 2010, 06:02 PM) <{POST_SNAPBACK}>
Frosty is my Favorite!!!
I imagine I'll be seeing this in the other self aggrandizing quotes in mr. frosty's sig. ;)
QUOTE (greatcrusade08 @ Sep 4 2011, 05:37 AM) <{POST_SNAPBACK}>
so much more eloquent than my response, even if you were typing like stevie wonder at the time ;)
#4
Freelancer
Freelancer
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 13 posts
how about if i remove the minimum range, reduce the maximum range and change the downside of the weapon to the following:
"if a 1is rolled, no hits are resolved against the target. The Sabre counts as being hit by a Vortex weapon"
Im sure there have been examples somewhere of Imperials using xeno-tech, for example, Pasanius' bionic arm in The Ultramarines Omnibus and the Adeptus Mechanicus higher-ups dont need to know about it :)
#5
Raven Angel
Raven Angel
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,840 posts
Im sure there have been examples somewhere of Imperials using xeno-tech, for example, Pasanius' bionic arm in The Ultramarines Omnibus and the Adeptus Mechanicus higher-ups dont need to know about it :rolleyes:
Thats a start I would also say make it a blast templete not an Ordinance templete. This is new and not well understood tech. The raw power requierments alone should preclude a larger area of effect scince this is using such a small engine. Think about it this is basically a mini starship warpdive here and you are trying to project that effect over didstance. For a first pass at the weapon it should be just about as dangerous to the user as to the enemy. Once the Adeptus Mechanicus have tinkered with it for a few hundred years then we can think about maybe getting better range.
1. As a Wargamer I am not owned by one company alone.
2. As a Wargamer I am loyal to excellence in rules sets that encourage balance and fair play. (either in tournaments or in casual play)
3. As a Wargamer I am loyal to Excellence in miniature manufacturing.
4. As a Wargamer I am loyal to companies that are fair in pricing.
5. As a Wargamer I am loyal to companies that are accessible and provide me with timely information.
6. As a Wargamer I am loyal to companies that value me as a customer, not as a commodity.
7. In return these companies will receive my financial support.
