Blood Duel; Round 3: Battle 2.
11 replies to this topic
#1
Shinzaren
Shinzaren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 989 posts
Fresh from his warband's victory over the loyalists dogs of the Blood Angels, Ferrous Ironclaw led them deeper into the Imperium, burning and pillaging his way across the stars. So it was that he finally came to this forsaken Hive World, Kollia Prime. Seeing another world defenseless before his might, Ferrous and his fellow Iron Warriors made planetfall and began to assault the Hive World proper, only to encounter more loyal servants of the Corpse God. These Astartes wore white armor, and their defense of the Hive's walls was causing no small amount of frustration to the Warsmith. The siege was taking longer than he had planned, and he knew more servants of the False Emperor would arrive soon. It was a stroke of good luck therefore, when one of his sappers discovered an abandoned tunnel that lead into the Hive. Ferrous lead a contingent of his most worthy warriors, planning on catching the loyalists by surprise. He was slightly unnerved however, to discover that the loyalists knew of the tunnel too, and had hatched a daring plan to kill the invaders. With a shout to their False Emperor, the white armored Astartes drove into the Iron Warriors, and battle was joined. Ferrous quickly slew one of the dogs in front of him, but his next swing with his power claw was blocked by a large glowing blade, wielded by a marine who appeared to be leading these men.
Bral Reiko knew the siege would favor the Heralds of Light. The Iron Warriors had been unprepared to deal with Astartes, and they had not brought heavy weapons along. Still, when his scouts told him there was an abandoned tunnel into the Hive, he knew the Iron Warriors would find it too. So he lead a group of his finest warriors, and met them head on, his Heralds crashing into the steel armored traitors. He watched as a traitor with a large powerclaw decapitated Brother Husta, and with a shout to his Emperor, he charged. The traitor swung his power claw again, but Bral Reiko blocked it with a deft motion with his blade, before lashing out again, trying to force the traitor back.
Ferrous was surprised that his strike was blocked, and even more surprised when the Astartes began to drive towards him, forcing him onto the defensive. The cramped tunnel meant that he couldn't bring his servo-arm to bear completely, and he found the bulk to be a hindrance. Still, he maintained his composure and met each of the Captain's strikes, before changing the pace and going on the offense. He twisted the claw down, catching the blade of his opponent, and pulling his forward. As the Astartes tried to recover, Ferrous brought his combi-melta to bear, and squeezed off a shot, watching with satisfaction as the stream of superheated air struck the Loyalist dog.
Pulled forward by the catching of his sword, Bral Reiko was off balance when the shot came. He saw the weapon being brought to bear, and barely had time to bring his storm shield up, absorbing most of the blast. Still, even the strength of the shield was not enough to completely stop the blast, and his felt the armor of his thigh being boiled and then melting completely, searing into his skin. The blast stopped before his entire leg was gone however, and while wounded, Bral Reiko could already feel his body adapting. The face of his shield completely burnt, and the metal on the edges was glowing white hot. Bral Reiko used it, smashing the superheated metal into his opponent's face.
Ferrous watched with glee as the storm shield deflected the superheated stream downwards, where it boiled away the armor of his leg and let the scorching smell of burnt flesh waft into his nostrils. Still, the loyalist was coming for him again, and as Ferrous moved to block a blow from the blade, he was driven backwards when the rim of the shield smashed into his temple. The metal was so hot, it boiled his own armor away, before driving into the flesh of his skull. There was an acrid hissing sound, and Ferrous screamed as his left ear was burned away. A last second jerk sideways dislodged the shield, before it could do anymore damage. Saved for now, Ferrous was off balance when the second strike came, slicing upwards beneath his claw and into his armpit. The power field ripped through his armor, and Ferrous felt the burning pain as it entered his chest. Slapping his claw downwards, he batted the sword aside, ripping it out of his now bloodied torso.
Bral Reiko watched with satisfaction as the shield hammered home, and while his opponent was off guard, he swung his blade up, slicing cleanly into his torso. The Iron Warrior deflected it before it could become a killing blow however, suffering a dangerous wound, but not death. Pulling back, Reiko drove forward again, swinging his blade down in a curving arc, aiming to decapitate his opponent. He was left vulnerable however, when his sword caught in the ceiling of the tunnel, the low height being to his detriment. Realizing his position, he swung his shield in front of him, while yanking down hard on his blade. The Iron Warrior was quicker however, grasping the rim of his shield with his servo arm and ripping it away before lashing out with his claw. Bral Reiko felt the heat of the claw as it tore into his wounded leg. It severed the bone cleanly, and if not for a reflexive jerk from Reiko, would have cut it away completely. Sorely wounded now, and realizing he couldn't put pressure on his leg until it could mend a bit, Reiko did the only thing he could.
Ferrous felt the claw penetrate the unprotected thigh of the Captain, only slightly disappointed when the loyalist pulled back. He was caught off guard however, when the Astartes dove at him, abandoning his stuck blade in the ceiling. Caught completely off guard, Ferrous felt his own servo arm punch through the armor of his lower back as he was crushed down onto it by the weight of the loyalist. He felt it tear the muscles in his back, stopping short of his vital organs by mere inches. Wrestling with his opponent, he was unable to bring his claw to bear, and unable to stop the loyalist as he hammered his wrecked shield down onto his face, smashing it into the unguarded side of his head. His vision went black for a moment, and he felt the ice cold sting of a combat blade, driving into his side; the same place the relic blade had already done its grim business.
Bral Reiko heard the traitor give a shout of pain, and with a quick motion he slid his blade into the unarmored section of his opponent's chest, driving it towards the heart and lungs. He felt a surge of satisfaction as another traitor fell, a surge cut short when he felt the Iron Warrior roll over, towards the blade, trapping his only free hand between the rockcrete and his body.
With a shout to his Dark Gods, Ferrous hurled himself sideways, impaling himself deeper on the blade, and trapping his opponent. This was a worthy adversary, but Ferrous would not allow himself to be bested here. He felt the burn as the blade penetrated one of his hearts, and barely had the focus to remain conscious and rip his power claw upwards. Catching the codpiece of the loyalist, Ferrous ripped the energy enhanced claw upwards, tearing his foe completely in half. With a curse, he felt the grip on the blade stuck in his chest weaken. He stood on shaky knees, ripping his servo arm out of his back and using it to grab the ceiling and steady himself.
Bral Reiko felt the terrible pain that started in his groin, and knew he was finished. Intent on his foe however, Reiko locked his hand down in an iron grip on his knife, deciding that if he went, the traitor would go with him. He died thinking he had ended a great enemy of the Emperor, though he would never know the truth.
Ferrous Ironclaw looked about the tunnel, seeing the bodies of a dozen or more Iron Warriors, and nearly twice that of Heralds of Light. Only three of his veterans remained, but they had done their work well. The enemy force's leadership had been slain, along with two dozen of their finest. This world would fall.
"Iron Within!" He tried to shout, though the words came out as little more than a whisper.
"Iron Without!" His survivors responded, in the same quiet manner as he.
Knowing he couldn't do anything more today, Ferrous and his warriors limped out of the tunnel and back to their lines, where Ferrous ordered another block of troops to assault the undefended tunnel. Victory for Perturabo. Victory for Chaos, were his last thoughts, before falling unconscious in his command center. He woke moments later however, as his Astartes blessed constitution repaired what it could, enabling him to watch the final battle, as his Iron Warriors put another world to the sword.
Spoiler
Edited by Shinzaren, 18 November 2010 - 06:55 PM.
#2
Ace Debonair
Ace Debonair
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 5,722 posts
Let's go Lib-
Oh, damn. :)
Well, that's a shame.
Congratulations to the Iron Warrior, rascally traitor though he may be. :P
#3
Shinzaren
Shinzaren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 989 posts
Let's go Lib-
Oh, damn. :)
I tried to at least give Captain Bral Reiko his due haha :P
#4
Captain Augustus
Captain Augustus
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 32 posts
Man I was hoping that Reiko would get revenge on the awful Iron Warrior :)
#5
Aurelius Rex
Aurelius Rex
    ++ GESTORIS ++
  • ++ MODERATI CEDO ++
  • 5,726 posts
Gaagh! Well, losing in the semi-finals is traditional for Liber Astartes contestants, it seems. Just ask Sergeant Pallas of the Scions of Dorn in the recent MoD AoD. :D
Hidden Content
#6
Viray
Viray
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 388 posts
It's a pity that there will be no Loyalists fighting in the finals. I suppose we can all comfort ourselves in the knowledge that no matter the outcome of the future bouts, a traitor will die. :P
In all seriousness though, congratulations to the winner and a nice pat on the back for the... er... not-winner.
#7
Codex Grey
Codex Grey
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 709 posts
NOOOOOOOOOOOOOoooooooo!
Oh well, at least he died in an epic showdown. Congratulations Shas'o R'Vre, now you better win the whole thing.
#8
Ace Debonair
Ace Debonair
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 5,722 posts
Agreed. It's now a matter of Liber honour - we'd better have been beaten by the best. :lol:
And, obviously, the Chaos Gods will be pretty impressed if you can off one of their other champions, but that's neither here nor there. :D
#9
Zynk Kaladin
Zynk Kaladin
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,984 posts
Wow, that was pretty epic! Well done.
Next time I fight the Iron Warriors I'll be sure to take as many of those bastards to hell as I can :D
#10
Shinzaren
Shinzaren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 989 posts
If it's any consolation, it was really hard for me to write Bral Reiko's defeat... Hence the drawn out nature, and Bral Reiko kicking as much butt as I could allow him too before dying :D
#11
Aqui
Aqui
    ++ ARQUUS PRAELIA ++
  • 7,561 posts
Well, congrats to Shas'o R'Vre and condolences to Codex Grey.
Can't wait for the final now! :P
In the darkness between the stars, the weak and the faithless find no deliverance. We are raised to believe that the God-Emperor watches over us all. And so we are charged to cleanse the mutant, the heretic and the alien. We must not falter. We are His sword. We are His wrath. Even in the face of death, we shall not submit. Suffering is our prayer. Faith is our armour. In Battle He offers us redemption. And for those who proves their worth, the Emperor sends sends forth His Angels!
#12
Cpt_Reaper
Cpt_Reaper
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,332 posts
The Liber has had a good run. Good work Reiko and Grey, congrats Shas'o R'Vre. Go for it man! *pulls out power-fist shaped foam hand*
