| Unit | BS | F | S | R | Structure Points |
| Laevantine | 4 | 14 | 13 | 11 | 3 |
Laevantine-pattern super heavy tanks are a rare breed. Each one is salvaged and crafted from an Imperial baneblade that has been destroyed in the line of duty against the forces of Chaos, recaptured, consecrated and gifted to a Holy Order of the Adepta Sororitas. They are as much shrine as weapon, each one blessed and sanctified, crewed by Sisters and honoured by saints.
The tanks were named after the Baneblade Laevantine, which was wounded in the defence of the shrine-world Lorus against the daemon hordes of the Masque. Its corpse provided cover for the Grey Knight Purifiers who held the last loyal city of the planet and refused to leave it to burn in Exterminatus our of gratitude for its loyal service even after death. The restored Laevantine was gifted to the Order of the Ebon Chalice as restitution for a certain incident.
| Unit Type | Unit Composition | Wargear | Special Rules |
- Replace any twin-linked heavy flamer with:
- Twin-linked multi-meltas: +10 points
- Twin-linked heavy bolter with Inferno Bolts: Free
- May take any of the following:
- Exchange Sponsons for Side Armour 14
- An additional sponson with twin-linked Heavy Flamer and turret-mounted Inferno Cannon: +50 points
- a pintle-mounted storm bolter: +10 points
- a hunter-killer missile: +10 points
- extra armour: +15 points
Inferno Gun: See Warhound entry in Warhammer 40,000: Apocalypse. Primary Weapon.
Hellstorm Breaching Cannon: A massive ordnance weapon that fires shells filled with burning acid, this pot-bellied cannon can break through most fortifications.
Range: 24" Strength: 10 AP: 3 Special: Heavy 1, large blast, Ordnance, Ignores cover
Tri-melta:A rare weapon otherwise seen only on the Throne of Judgement, the Tri-melta is even more effective than its single- and double-barelled counterparts.
Range: 24" Strength: 8 AP: 1 Special: Heavy 2, Twin-linked, Melta
Inferno Cannon: See Hellhound entry in Codex: Imperial Guard
Holy Icon: Friendly units within 12" may reroll failed Faith tests, and gain a +1 bonus to their Leadership score (maximum Ld 10)
Laud Hailer: Any model within 12" that passed a Faith test on an unmodified roll of a 6 grants an additional Faith Point to the army.
Inferno Bolts: Always wound on a 4+ against models with T5 or higher.
Rolling Flame: Any enemy model attempting to make a Death or Glory attack against the Laevantine is hit by d3 S5 AP4 hits that ignore cover. If the model dies, it may not Death or Glory.
Edit: Code fixed by Chengar Quordath... as usual.
Edited by Furyou Miko, 30 April 2012 - 09:35 PM.
Sign In
Create Account
Back to top
