Rules of the Road
  • Please log in to reply
No replies to this topic
#1
Brother Tyler
Brother Tyler
    ++ FIDELIS MILITUS ++
  • +++ADMINISTRATUM+++
  • 21,957 posts
  • Faction: VIIth Legion
Welcome to the Adeptus Mechanicus Army Lists forum.
This forum is, as the name suggests, intended to provide our members with a central location for the development and refinement of armies based around the Adeptus Mechanicus.
This isn't a green light to post anything and everything under the rubric of the Adeptus Mechanicus, however.
Adeptus Mechanicus army lists may only be posted if they are built under a codex covered by the Bolter & Chainsword. So you can't post your army list for an Adeptus Mechanicus army using Codex: Necrons or any other xenos codex.
Also, since the range of official Adeptus Mechanicus army rules are extremely limited (currently covered only via Titans for Apocalypse and the Forge World Horus Heresy rules), most Adeptus Mechanicus armies are built using counts-as. In cases where you're using another codex covered by the B&C, it is also acceptable to post the army list in the relevant army list forum. For example, if you're using Codex: Grey Knights as the basis of your Adeptus Mechanicus army, you can post the army list both in this forum and the Grey Knights Army List forum.
Players will also find it useful to identify which codex they are using for their Adeptus Mechanicus army, either in the topic description or somewhere at the top of the first post so that other members have the proper context.
Other than the above, the standard Bolter & Chainsword rules apply.
Cheers!
