1500pts Taghmata Omnissiah
7 replies to this topic
#1
nordic
nordic
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 7 posts
Posted this in the HH section but thought it would be wise to put up here too
Here is my 1500pt force that im considering running for small games, i havent played with them yet so still untested with regards to balance etc.
HQ
Archmagos Prime
Cortex Controller, Cyber-familiar, Ordinator, Rad Grenades
205pts
Elites
3 Myrmidon Secutors
2 Graviton guns, 4 Phased Plasma Fusils
230pts
Troops
Adsecularis Covenant
15 Tech-thralls
Rite of Pure Thought
65pts
15 Tech – Thralls
50pts
3 Thallax Cohort
135pts
3 Thallax Cohort
135pts
3 Castellax Class Battle-Automata Maniple
Flamers
285pts
Heavy Support
Thanatar Class Siege-Automata Maniple
240pts
Krios Venator Battle Tank
135pts
Total: 1495pts
I also have the following units to sub in if it needs to:
12 thallax
2 magos dominus
2 castellax
3 vorax
thanatar
any pointers would be greatly appreciated.
#2
FashaTheDog
FashaTheDog
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,198 posts
You really should give your Thallax some sort of weapon like a multi-melta. Lightning guns are nice, but the multi-melta will give you some needed anti-tank.  Giving your Magos either a machinator array or a conversion beamer is not a bad idea as the former makes you tougher while the latter gives you some nice long ranged firepower which complements Ordinator nicely.  Putting him on an abeyant is pretty good standard practice.  The way you currently have him the rad grenades, while useful in some situations, are just not worth the 10 points as they are far better spent elsewhere.
Now I must ask, why does your lone Thanatar not have paragon of metal?  Do you pity your opponents so much that you are passing up on a nearly must take upgrade?  Do you have that much contempt for the foes you face that feel the need to pass up insanely good upgrades?  No longer being subject to programmed behavior and getting IWND is bonkers good.  The targeting array is also a rather nice fit on it as well since reducing covers saves by one in conjunction with the Hellex forcing successes being re-rolled is particularly good.  After dropping 240 points, another 50 in upgrades to take it from big and scary to "fetch me my brown pants" terrifying is really worth it.  Unless you are running two single maniples of Thanatar in the same detachment, there is absolutely no reason that a lone Thanatar should not have paragon of metal.  If you are running two, then really try to put them in separate detachments so both can have it, even if you need to buy extra units to do so; it is just that good!
[url=http://www.bolterandchainsword.com/index.php?showtopic=253135][color=#FFFF00]Dornian Heresy Imperial Fists[/color][/url]
[url=http://www.bolterandchainsword.com/topic/279575-a-wip-thread-with-as-much-reason-and-logic-as-the-warp/]General Work In Progress[/url]
[img=http://fortressofunforgiven.homestead.com/ETL_2014_Banner_V2_03A_Custos_Fidei.jpg][img=http://image.bolterandchainsword.com/uploads/gallery/album_9303/gallery_29004_9303_5739.png][img=http://www.fortressoftheunforgiven.com/Img_CH00_08Awards_06_ETL_2013A.gif][img=http://www.fortressoftheunforgiven.com/Img_CH00_08Awards_03_ETL_2012A.gif][img=http://www.fortressoftheunforgiven.com/Img_CH00_08Awards_07_CoC_2013.gif][img=http://i977.photobucket.com/albums/ae257/Pendragi/40k%20art/gallery_52275_4552_20046.png]
[color=#00ffff][u]P⑨P QUIZ[/u][/color]
A bus left the Scarlet Devil Mansion; three people boarded at the start.
At Hakugyokurou, one left and half a person boarded.
At Yakumo-san's house, two people left; so how many passengers in total?
The answer is zero people because there are no buses in Gensokyo!
#3
nordic
nordic
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 7 posts
It may be abit thanatar heavy but how about this?
Magos prime
Ordinatior, abeyant, conversion Beamer
215
3 sectors
2 graviton guns, 4 phased plasma fusils
230pts
15 tech-thralls
Rite of pure thought
65pts
15 tech thralls
50pts
3 thallax
Multimelta
150ts
3 castellax
Flamers
285pts
2 Thanatar
Targeting array
510pts
1505pts
#4
sparti67
sparti67
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 30 posts
You can also switch out the Mauler Bolt Cannons for Mulit-Meltas for free on the Castellax.  Do you know what you are going up against?  On your Archmagos you can switch out the Conversion Beamer for a Iradiation Engine. Str 4 AP 3 flesh bane, torrent.  Anything above AP 3 is insta kill on a 2+ with flesh bane unless they have multiple wounds.
Edited by sparti67, 26 January 2015 - 09:18 PM.
#5
Jakeisgod
Jakeisgod
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 16 posts
I am not a fan of multimeltas on thallax i prefer the Photon Thruster personally
#6
FashaTheDog
FashaTheDog
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,198 posts
The choice comes down to role.  The multi-melta fits in a more all around role choice for Thallax due to the similar range to the stock weapon while also being a nice anti-tank option.  The photon thruster on the other hand, far outstrips the rest of the unit's ranged firepower.  It does get two shots, allow the unit to rarely be out of range, and with only a handful of lance immune exceptions can glance any vehicle giving it some anti-tank ability, but on the downside it has gets hot and if 60% more expensive than the multi-melta.  If the Icarian augment were cheaper or you are running at least two photon thrusters in the unit (bigger game perhaps) or you've run out Troops slots and need to field more Thallax, it can make a Heavy Support Thallax unit a rather fun anti-air unit.  Basically which AP2 weapon do you think will better suit your list.  In the above list's specific case I think the multi-melta is the better choice.  However, if a list were more Thallax heavy (at least three or four units of them), I would encourage diversity.
#7
Jakeisgod
Jakeisgod
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 16 posts
Ive found the 2 shots to be highly effective against legio lists with lots of power armor and terminator armor. I use my Thallax as a firebase and the Castellax in more of a direct engagement in the front where the T7 is much better than T5. People murdered my Thallax when i used them to engage at short range. I usually walk them around a building and fire then jet pack back around the corner to safety and that lures the opponent into the range of the Mauler bolt cannon and maxim bolters which have a gross number of shots at bs5. Everything i run into with an armor value worthy of a multimelta has ceramite armor...darn legions and those pesky land raiders. But its all about play style, you have success with the MM good im glad. if you look at my post about my 3.5k list youll see i run a lot of the Photon weapons.
#8
bebe
bebe
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 335 posts
If you plan on using cybertheurgy (I play Legio) you actually don't want paragon of metal. It can easily send your Thanatar raging into your own units. I never use it in my Legio list.
The only Myrmdons I use are desructors but I suppose your secutor squad is okay. Why do you feel they are better than destructors.
Cenobites...."demons to some, angels to others". Creations of the Lord of Hell, Leviathan. "The Cenobites [offer] an experience beyond the limits; pain and pleasure, indivisible."
