  • Please log in to reply
2040 replies to this topic
#2026
Chief Captain Redd
Chief Captain Redd
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,316 posts
  • Faction: The Iron Bears of Daer'dd.
Edit: I apologize for the formatting
Putting this here, not completely done with options still figuring that out.
Conceptually, based on some 2nd edition fluff I figure much like the chainsword being based on Eldar chain weapons, the Grav Rhino is akin to the Eldar Grav Falcon; and based on what little imagery there is the upper superstructure looks reinforced for additional weaponry and such.
Grav Rhino 65 points
Armour
BS Front Side Rear HP
Grav Rhino. 4 11 11 10 3
Unit Composition
* 1 Grav Rhino
Unit Type
* Vehicle (Skimmer, Fast, Transport)
Transport Capacity
* 10 models.
Fire Points
* None
Access Points
* One on either side of the hull.
Wargear
* Spotlight
* Smoke Launchers
* Two Twin Linked Bolters
Special Rules
* Grav Wash
* Deep Strike
Options
A Grav Rhino may take any of the following:
* Two Hunter-killer Missiles
5 points each
* Extra Armour
5 points
* Auxiliary Drive 10 points
* Armoured Ceramite 20 points
A Grav Rhino may upgrade either of its twin linked Bolters to the following
*Combi-weapon 5 points
*Twin linked Volkite Caliver
10 points
* Heavy Bolter 10 points
* Heavy Flamer 10 points
* Multi-melta 15 points
Alternatively the Grav Rhino may exchange 4 transport spots and take the following.
A Turret with
* Twin Linked Heavy Bolter
Points
* Twin Linked Volkite Culverin
Points
* Twin Linked Plasma Cannon
Points
A Grav Rhino may then upgrade either of its twin linked Bolters to the following
10 points
Edited by Chief Captain Redd, 16 December 2018 - 01:07 AM.
#2027
SanguiniusReborn
SanguiniusReborn
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 3,138 posts
  • Faction: The Steel Legion
One day, I really wanna commission a Grav-Rhino in Steel Legion colours, preferably based on the Shapeways Grav-Rhino kit with the the Deimos-Pattern hull.
Proud Creator of the Scarlet Sentinels, my 18th Century British Redcoat Chapter and the Steel Legion, my Cyberpunk-inspired Lost Legion!
#2028
Beren
Beren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 401 posts
Another really long one. I think that I could cut down the history section substantially if necessary.
Furibundus Class Dreadnought
The precursor to the Furibundus dreadnought was sources from the Terrawatt Clans of Terra, a terror weapon rarely used by the techno-savants. Known informally to their enemies as the ‘Withermaw’, its victims could weaken and fall days after what appeared as a fortunate reprieve. With the coming if the nascent Imperium the warframe was adapted for the use of near-dead Astartes, officially becoming a dreadnought pattern.
However a degree of mistrust between the Terrawatt Clans and the Martian Mechanicum prevented the Furibundus from being produced en masse, and as Terrans who had fought alongside or in such creations dwindled, so did the incentive for any such agreement. Unlike their techo-barbarian forebears or the callous armies of the Mechanicum, non-Terran recruits seldom saw the need for a dreadnought so lethal in its radiation output that it could not be repaired without shutting down its reactor. For a time the Furibundus was only seen to any significant degree within the XXth; where their use had only been moderately restrained by the Primarch Andezo as opposed to being abandoned entirely.
This discovery of the Primarch Raktraa Akarro shifted the paradigm dramatically. Unlike the Shepherds of Eden, the original VIIth, the White Devil and his soldiers took a savage glee in the effects caused by the dreadnought. Soon, their demand outstripped both the supply and the regulation upon the Terrawatt Clans’ productions. They began to pressure whatever Mechanicum sect they could to produce the chassis based on those few still available, and in response several if their like minded compatriots echoed this to lesser degrees. The brutality of wars such as the Rangdan exterminations only reinforced this. The power and influence displayed by the Astartes in doing this proved an all too apt concern for the mortal lords on Terra, concerns soon proven right.
Most Furibundus pilots already originated from a Legion’s Destroyer Cadre, thus being no stranger to the lethal and long lasting effects of the weapons they wielded.Within their shielded sarcophagi they were immune to their own emanations and in battle few dared to step within their reach. Even in death, the destructive aftermath of their fall could meant that they could claim their slayer from beyond the grave.
Edited by Beren, 17 December 2018 - 07:02 AM.
  • Lord Thørn likes this
#2029
Lord Thørn
Lord Thørn
    ++ CUNICULARIUS APOLOGUS ++
  • ++ MODERATI CEDO ++
  • 4,264 posts
  • Faction: Heretic Astartes (various)
Pretty good overall, but I'm not a fan of how you say only the predators use them for a time, until raktra is found - other legions would be loathe to use it, but would be prepared to use them should it be needed
There's also a "ciwe" which i don't know if it's a typo or a word I don't know
#2030
Beren
Beren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 401 posts
Done and done.
#2031
Beren
Beren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 401 posts
This was trimmed down a bit, so expe t that there may be some odd phrasing where I was trying to save words.
Grav-Rhino
The ‘grav-rhino’ would appear to have originated within the armouries of those military arms known as the ‘Talons of the Emperor’, namely theCustodians and Sisters of Silence. While there is no record of the transport’s initial manufacture, numerous reports and witnesses depict the modified Rhinos bearing the Emperor’s chosen in the early days of the Great Crusade. With the inception of the Coronus Grav-Carriers and Kharon Pattern Aquisitors, its role within such hallowed units was rendered redundant.
At some point a portion of the remaining Grav-Rhinos came into the possession of others, possibly in the form of gifts given to those whom the Custodes trusted. If so, their trust was violated. Under instruction from the Primarch Daer’dd, Tricendian experts in gravitics discovered how to replicate the vehicle, almost certainly against the wishes of the Custodians. Daer’dd’s intent was not to bolster his own power, but to enrich the Legions as a whole. This proved a grievous error. His largesse ensured that Akira, Lasaris and other worlds bound to the Insurrectionists also possessed means of production. The Custodians themselves never commented, but to the councilors on Terra it was a source of disquiet. Already uneasy over the very existence of ‘Astartes Empires’ such as Tricendia and Mycenae, that they could display such a degree of military independence proved yet another blow to the trust between Terra and its supposed protectors.
Despite their utility, Grav-Rhinos lacked the same degree of robustness and reliability that made its cousin the workhorse of the Legions. Instead they became the hallmark of strike formations. Supported by the harrying fire of landspeeders and jet-bikes, such units exploited the disarray of the enemy to seize critical objectives. Gliding in from the sea and other terrain impassable to the standard Rhino gave them an element of surpise used to encircle a bewildered foe or strike deep behind their lines.
Edited by Beren, 18 December 2018 - 08:32 PM.
#2032
Beren
Beren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 401 posts
Just so that I've gotten a summarisation this written down somewhere other than discord, the decided lineup for the story anthologies is as follows:
Intro Anthology-The Dinner, Great Games, Prospero, Baal
Harbringers Anthology- The Colleges, Ghost Crusade, Caged Lightning, Fraught
Halcyon Wardens Anthology-Happiness is..., Beneath the Surface, The Warmaster's Work, Ascension
Currwntly they all( bar perhaps the Colleges and Caged Lightning) need a checking over for Canonicity issues. Fraught needs editing to be more Harbringer centric( The IB and BoU portions can be reused) and the Warmaster's work may need editing doen a bit, but definiteley needs the Sarum magi replaced by Eskut magi.
Edit: In addition, for the Great Games Wilhym and the Jackals need replacement with Nomus and the Steel Legion. Alexos needs to be replaced with Socraes.
Edited by Beren, 13 January 2019 - 04:43 PM.
  • simison likes this
#2033
Beren
Beren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 401 posts
Dramatis Personae for the General Anthology (Excepting those who remain unchanged from Canon.)
Icarion Anasem, Primarch of the Ist Legion, Stormborn
-Raiden Athrawes, Sentinel of the 9th Company and Equerry to the Prinarch
Hectarion Mycenor, Primarch of the IIIrd Legion
Yucahu Sumakutaa, Primarch of the IVth Legion.
Alexandros Darsham VonSalim, Primarch of the Vth Legion, Warmaster
-Pyrricles, Fortress to the Order of the Shield Equerry to the Primarch
-Irvin Ruel, Chapter Master
Dae'rrd Niimkiikaa, Primarch of the VIth Legion
-Lord Chief R.Damon Redd, Master Slayer, Master of the Fleet, The Iron King
-Aandegg Niimkiikaa, Master Shaman
-Solomon Grimm,Legion Champion
-Therox "Cass" Casstiel, 1st Lord Chief
-Achille Nibaasiniiwi "The Wolverine", 1st Praetor
-Ezibiknh "Ezekiel" Spinebreaker, 2nd Lord Chief, Master Warrior
-Lotarra Sarrin, Iron Queen, Fleet Mistress of the Iron Bears
-Minerva An'saalmo, Fleet Lietenant of the 2nd Grand Wartribe
-Ellen Temeter, Rememberancer of the Primarch Dae'rrd
Koschei Kharkovic, Primarch of the VIIth Legion
Raktra Akarro, Primarch of the VIIIth Legion
Kozja Darzalas, Primarch of the IXth Legion
-Vizenko, former Atrefos of the Asklepians, prosecuted at Baal
Niklaas, Primarch of the Xth Legion
Gwalchavad, Primarch of the XIIth Legion
-Arngrim Valten, 'The Legend', Blademaster of the Wardens of Light
Socraes Travier, Primarch of the XIIIth Legion
Azus Bahmut, Primarch of the XIVth Legion
K'awil Pakal, Primarch of the XVth Legion
Sorrowsworn Morro, Primarch of the XVIth Legion
The Jade General, Primarch of the XVIIth Legion
Nomus Sardauk, Primarch of the XVIIIth Legion
Pionus Santor, Primarch of the XIXth Legion
-Antonidas, First Captain and Equerry to the Primarch
-Metis Odyssallas, Second Captain
-Inna Santor, Prima Medica, adoptive sister to Pionus Santor.
-Diokles, Sixth Captain
Andezo Sambedi, Primarch of the XXth Legion
Captain Nux Pyrruk, Captain of the Shepherds of Eden and formerly of the VIIth Legion
Edited by Beren, 14 January 2019 - 05:18 PM.
  • Kelborn likes this
#2034
SanguiniusReborn
SanguiniusReborn
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 3,138 posts
You're missing two Primarchs from that list, Raktra and Nomus.
#2035
Beren
Beren
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 401 posts
Ak. Nomus still needs to be added to the Great Games/Dinner himself to be fair.
I also realised that I still have to go through Baal.
Edited by Beren, 13 January 2019 - 07:56 PM.
#2036
SanguiniusReborn
SanguiniusReborn
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 3,138 posts
Oh ok, never mind then, I misunderstood.
#2037
Grifftofer
Grifftofer
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,053 posts
Because I have a terrible memory I completely forgot to post a summary of the grav rhino discussion that we had on discord before Christmas.
TLDR: The Turret option won't be included, so it will effectively be just a floating rhino with two pintle weapons.
#2038
bluntblade
bluntblade
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 8,043 posts
  • Faction: Inkspillers
Grifft, I found a few mistakes in my Untara piece. Corrected them on the Wiki, so I'll send you that with the edits soon.
#2039
simison
simison
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 6,881 posts
  • Faction: Halcyon Wardens, Blood Angels
32 days to our D-day! Where do we stand on the generics?
  • Nemesis
  • Vilicus [Optional]
  • Arigus
  • Accipitrine Dread
  • Lucifer Dread
  • Furibundus Dread
  • Frag Bombard Vindicator
  • Sabre
  • [Fancy Tank]
  • Sarkastodon
  • Jocasto
Let's wrap it out and get ready for publication.
Edited by simison, 28 January 2019 - 04:12 PM.
Project Leader of the Brotherhood of the Lost
The Second Son: Narrative of the BOTL Vth Legion Primarch
Brotherhood of the Lost has arrived on Patreon
#2040
MikhalLeNoir
MikhalLeNoir
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 4,693 posts
  • Faction: XIth Legion Wardens of Light
I may be able to finish an Accipitrine Dread until then. Ordered most of the necessary parts
Open for Comissions, just PM me. The Wardens of Light were like golden blades, cutting down their enemies scarring the darkness.
gallery_92945_11930_15891.jpeggallery_78117_10471_62812.pnggallery_92945_11930_12458.png
#2041
Grifftofer
Grifftofer
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,053 posts
Alright. A quick summary of tonight's crunch discussion featuring the Arigus Consul and Vindicator expanded weapon options.
Vindicator:
After some consideration only the Frag Bombard will be added to the Vindicator Squadron as an option. As the feeling was that the Legions having access to the Vanquisher Cannon would be stepping on the toes of the Solar Auxilia list a little bit too much. The Frag Bombard seems to be a bit more effective against infantry, but significantly less so against vehicles when compared with the demolisher cannon, so we decided to make it a free swap.
Arigus Consul:
The Arigus Consul is pretty much a BS5 Legion version of the Auxilia Tank Commander. The major change is that instead of the Leadership benefit of the Tank Commander the Arigus will have an ability to improve it's own tank/squadron. The final cost came out to 70 points.
Also tagged with one or more of these keywords: Brotherhood of the Lost, Lightning Bearers, Eagle Warriors, Iron Bears, Godslayers, Grave Stalkers, Abyssii, Scions Hospitaller, Segmentum Ultima, Segmentum Tempestus
