RipOffProductions Posted March 29, 2021 Share Posted March 29, 2021 Those do look nice, having balconies to justify the doors on higher levels of AT buildings is pretty neat, though it seems their printer can't handle details that thin and tiny on the edges... Link to comment Share on other sites More sharing options...
malika666 Posted April 1, 2021 Author Share Posted April 1, 2021 Teaser... Brother Captain Vakarian and apologist 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 3, 2021 Author Share Posted April 3, 2021 More teasers of things to come... Matcap86, apologist and Gore Crow 3 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 7, 2021 Author Share Posted April 7, 2021 Reinforcements inbound! Cybershadows: Cybershadow – Praetoria Set 1 The Cybershadow Praetoria as we have designated them are an oddity within the Cybershadow military structure, although they can be seen operating and supporting other Cybershadow forces from time to time they seem to be an independent element not under the main chain of command. Their place within the Technocracy is not fully understood and is still open to some debate within military circles but it is known that they are an extremely aggressive and highly mobile force.Set contains: 15 x Cybershadow Praetoria in four poses https://vanguardminiatures.co.uk/shop/cybershadow-praetoria-set-1/ Cybershadow – HK-1L Hunter Killer Combat Automaton Another battle robot fielded by the Technocracy, the HK-1L is a dedicated rapid strike unit tasked with seeking out enemy vanguard formations in advance of the Technocracies main battle line and attacking those formations to cause maximum disruption. The designs long legs contribute to its high attack speed and elevated line of sight on the battlefield. The HK-1 is well armoured for its size and incorporates a defensive energy shield emitter located on its back. Two modular weapons hard points allow for the fitting of various weapon systems with energy based weapons being the most common.A variant of the HK-1 the HK-1T has been observed operating in poor terrain and replaces the units legs with a large high speed track system providing excellent stability and good ground pressure in challenging terrain conditions. Set contains: 2 x HK-1 hunter Killer robot torsos 2 x arm weapons sprues 1 x legs sprue Figure shown for size purposes only and is not included. Bases not included. https://vanguardminiatures.co.uk/shop/cybershadow-hk-1l-hunter-killer-combat-automaton/ Novan Regulars:Novan Regulars – Siege Troops Heavy Anti-aircraft Gun Crews Set contains 36 x siege troops heavy anti-aircraft gun crew figures in six poses. https://vanguardminiatures.co.uk/shop/novan-regulars-siege-troops-heavy-anti-aircraft-gun-crews/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 8, 2021 Author Share Posted April 8, 2021 New Cybershadow tanks! Cybershadow – CT-10 APC A heavily armoured and shielded armoured personnel carrier in common service with Technocracy forces. Sponson mounted disruptors and a twin cannon turret provide defensive firepower.Set contains: 1 x APC hull 2 x track units 1 x components sprue Resin cast model. Overall length 50mms, track length 36mms https://vanguardminiatures.co.uk/shop/cybershadow-ct-10-apc/ Cybershadow – CT-20 Missile Tank A variant of the CT-10 APC this “tank” trades its troop carrier ability in order to house a battery of vertically launched missiles, arm mounted twin turrets provide additional firepower.Set contains: 1 x tank hull 2 x track units 1 x components sprue Resin cast model. Overall length 50mms, track length 36mms https://vanguardminiatures.co.uk/shop/cybershadow-ct-20-tank/ Augustus b'Raass, torcathmk2 and Ldorte 3 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 14, 2021 Author Share Posted April 14, 2021 New little terrain piece: Heavy Ordnance – Energy Cannon This cannon is the same model as can be used to upgrade the Novan Elites forward operating base bunker model.We have several planned uses for this model which is why this version comes with power cells that will be a part of a future release. Set contains: 1 x heavy cannon 2 x cannon armour plates (left and right) 2 x cannon power cells (left and right) 1 x cannon turntable Notes: All components are 3D printed resin.Print supports have been removed but some clean up may still be required.Novan Elites figure show for scale purposes only and is not included. https://vanguardminiatures.co.uk/shop/heavy-ordnance-energy-cannon/ Link to comment Share on other sites More sharing options...
malika666 Posted April 18, 2021 Author Share Posted April 18, 2021 Remember the big gun I've shared last week? Apparently it was part of some additional 3D printed terrain kits! Novan Elites – Forward Operating Base (FOB) The Novan Elites forward operating base (FOB) is a pre-fabricated modular fortification that can be assembled in many configurations. This set contains the components to assembly one configuration “A” structure with two gatehouses and four defence turret mounts. This model should see further modules released to expand on the theme and open up new layout options.Set contains: 6 x plain walls 4 x walls with light turret positions 2 x gatehouses 2 x gates 1 x sentry turret sprue Dimensions: 165mms square, wall height to top of parapet 24mms Notes: 1) These models have been 3D resin printed and are hollow to reduce weight and material cost, print supports have been removed but some clean up may still be required.2) Model has been designed to enable magnet use as desired.3) Various miniatures show for scale purposes only, GW knight shown without permission. https://vanguardminiatures.co.uk/shop/novan-elites-forward-operating-base-fob/ Novan Elites – FOB Upgrade – Bunker With Dish This is an upgrade module for the Novan Elites forward operating base model, a heavy bunker that provides the FOB with a powerful multi-function dish.Set contains: 1 x bunker 1 x bunker roof I x dish 1 x dish turntable Dimensions: bunker height not including the dish 45mms, 75mms long on a side, replaces three corner modules. Notes: 1) All components are 3D resin printed. 2) Print supports have been removed but some tidy up may be required. 3) Some file work will be required to get the roof and dish to sit properly in there locations. https://vanguardminiatures.co.uk/shop/novan-elites-fob-upgrade-bunker-with-dish/ Noserenda, torcathmk2 and Focslain 3 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 20, 2021 Author Share Posted April 20, 2021 Four new releases for the Novan Regulars! Novan Regulars – Warrior II AA Warrior II has seen many weapons system fitted during its long period of service, this particular variant has an arrangement of two twin heavy machine guns that are often deployed in a light anti-aircraft roll as well as providing a high volume of fire when supporting ground forces in an assault.Set contains: 3 x warrior II hulls 3 x AA MG turret sprues https://vanguardminiatures.co.uk/shop/novan-regulars-warrior-ii-aa/ Novan Regulars – Warrior II ATGM Warrior II has seen many weapons system fitted during its long period of service, this particular variant has an arrangement of two twin anti-tank guided missile pods providing organic anti-tank capability to the mechanised regiments.Set contains: 3 x warrior II hulls 3 x ATGM turret sprues https://vanguardminiatures.co.uk/shop/novan-regulars-warrior-ii-atgm/ Novan Regulars – Self-propelled Heavy Siege Mortar An uncommon sight on the field of battle the self-propelled heavy siege mortar can however be found in very small numbers as assets in most Novan Regulars artillery regiments.Set contains: 2 x heavy ordnance hulls 12 x siege mortar components sprues Models painted by Gregory Bailly https://vanguardminiatures.co.uk/shop/novan-regulars-self-propelled-heavy-siege-mortar/ Novan Regulars – Desert Cavalry Company Set 2 Native to the Novan world of Syran and domesticated by the population there the Lemac can be found in many desert towns in various roles as well as serving as mounts for native military forces.Set contains: 10 x Desert Cavalry Squads (30 x models), 1 x Desert Cavalry Command Squad (3 x models) 2 x Desert Cavalry squads with plasma guns (6 x models) Enough cavalry figures for 13 bases with 3 miniatures per base. https://vanguardminiatures.co.uk/shop/novan-regulars-desert-cavalry-company-set-2/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted May 4, 2021 Author Share Posted May 4, 2021 Some more Cybershadow support units are out! Cybershadow – AS-40 Set contains:2 x twin laser cannon hulls 2 x twin HMG hulls 4 x left skimmer units 4 x right skimmer units Four models in total. https://vanguardminiatures.co.uk/shop/cybershadow-as-40/ Cybershadow – AT-35 Set contains:2 x twin laser cannon hulls 2 x twin HMG hulls 4 x left tracks 4 x right tracks Four models in total. https://vanguardminiatures.co.uk/shop/cybershadow-at-35/ Cybershadow – IS-10 The Cybershadow self-propelled infantry support weapon system (IS-10) is manned and fielded by the Technocracies Protector infantry forces in the roll of light fire support units. Often seen operating in defence of Cybershadow installations and bases they are a surprisingly effective mobile weapon system. The platform houses a compact micro reactor power core and mounts a twin linked energy cannon, both the IS-10 itself and the operator are protected by an onboard energy shield emitter.Set contains: 8 x Cybershadow IS-10’s https://vanguardminiatures.co.uk/shop/cybershadow-is-10/ Link to comment Share on other sites More sharing options...
malika666 Posted May 17, 2021 Author Share Posted May 17, 2021 A couple 6mm battle walkers releases for today. The Novan Elites Marauder and Novan Regulars Locust stride into battle. Novan Elites – Marauder (A) Battle Striders The Marauder was the first “Battle” class Strider created exclusively for the Novan Elites, a very advanced design at the time of its introduction. A fast rugged chassis married to modular weapon pods its longevity in service has been testament to its capabilities.This (A) variant is armed with a twin medium calibre rotary cannon chin turret and two guided missile batteries in the shoulder pods. Set contains: 2 x Marauder battle striders Notes: These are resin cast modelsFigures shown for scale purposes onlyModel height 40mms approximately not including antennaBases not included https://vanguardminiatures.co.uk/shop/novan-elites-marauder-a-battle-striders/ Novan Regulars – Locust Battle Striders One of the first “Battle” class Striders deployed by Novan Regulars regiments the Locust is basically an enlarged and upscaled scout strider. The venerable Mk1 has only one weapons hard point like the scout strider that inspired it, and is often now deployed as a heavy recon unit and sometimes as a command vehicle due to the greater internal space (port side) allowing for the fitting of a command and control suite.The Mk2 has two weapon hardpoints. It is common practise in many regiments to field the Mk1 and Mk2 machines together as a team. Set contains: 2 x Locust kits (one of each hull variant) with modelling options Notes: These are resin cast modelsFigures shown for scale purposes onlyModel height 35mms approximatelyBases not included https://vanguardminiatures.co.uk/shop/novan-regulars-locust-battle-striders/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted May 28, 2021 Author Share Posted May 28, 2021 New reinforcements for the Tainted inbound! Renegade Regulars – Warrior II IFV The Warrior II is a purpose designed Infantry Fighting Vehicle in common service with many of the great Novan houses, created to transport an infantry squad in relative safety to the front line and to fight alongside that squad when they are dismounted as an infantry armour team. There are several patterns in service and many different weapon systems have been fitted over the years, it is rugged and relatively fast for an armoured transport vehicle two features that have ensured its longevity, with the basic hull seeing development for many other military vehicles such as recon, command, heavy weapons carrier and artillery chassis to name but a few it is sure to remain in service for many years to come.Set contains: 4 x Warrior II hulls 3 x Warrior II turret and bow MG sprues (fixed hatches) 1 x Warrior II turret and bow MG sprue (separate hatch) 1 x closed hatch 1 x open hatch Notes: Model dimensions: Length 27mm, Width 18mm, Height 13mm to top of turret.Helmet trophy poles not included.Painted by: Von Krieg Studio https://vanguardminiatures.co.uk/shop/renegade-regulars-warrior-ii-ifv/ Renegade – Elementals Background fluff to follow.15 x elementals 15 x elementals with breather masks Painted by: Von Krieg Studio https://vanguardminiatures.co.uk/shop/renegade-elementals/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted June 21, 2021 Author Share Posted June 21, 2021 A whole bunch of new releases today! First up: Renegade tanks! Renegade Regulars – Centurion Tank Squadron (Paris) The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. Traits that make these tanks attractive to more nefarious forces also. The design has seen many weapon fits over the years this variant (Paris configuration) mounts the fearsome plasmic cannon capable of breaching the type of heavy armour worn by novan elite forces this is a rare but extremely potent anti heavy infantry weapon system. The regular forward hull laser cannon is also present on this variant and the optional sponsons usually house the common heavy machine guns for conventional anti infantry duties. Set contains: 3 x centurion hulls with covered tracks 3 x plasma cannon turret sprues https://vanguardminiatures.co.uk/shop/renegade-regulars-centurion-tank-squadron-paris/ Renegade Regulars – Centurion Tank Squadron (patroclus) The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. Traits that make these tanks attractive to more nefarious forces also. The design has seen many weapon fits over the years this variant (Patroclus configuration) is a dedication anti light vehicle and infantry hunter armed with a duo auto cannon mount in the turret as well as the regular forward hull laser cannon. The optional sponsons usually house the common heavy machine guns for anti infantry duties. Set contains: 3 x centurion hulls with exposed tracks 3 x twin autocannon turret sprues https://vanguardminiatures.co.uk/shop/novan-regulars-centurion-tank-squadron-patroclus/ Renegade Regulars – Centurion Tank Squadron (Nestor) The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. Traits that make these tanks attractive to more nefarious forces also. The design has seen many weapon fits over the years this variant ( Nestor configuration) is a dedication anti vehicle hunter armed with a duo laser cannon mount in the turret as well as the regular forward hull laser cannon. The optional sponsons in this case also sport laser cannons making for an exceptional multi target engagement platform. Set contains: 3 x centurion hulls with exposed tracks 3 x twin laser cannon turret sprues https://vanguardminiatures.co.uk/shop/renegade-regulars-centurion-tank-squadron-nestor/ Renegade Regulars – Centurion Tank Squadron (Ajax) The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. Traits that make these tanks attractive to more nefarious forces also. The design has seen many weapon fits over the years this variant (Ajax configuration) has a demolition mortar in the turret designed to smash defensive enemy bunkers at point blank range, backed up by a fixed forward hull mounted laser cannon. In addition the hull sides can be configured to mount sponson weapons the most common fit on this variant being plasma cannon. Set contains: 3 x centurion hulls with covered tracks 3 x mortar turret sprues https://vanguardminiatures.co.uk/shop/renegade-regulars-centurion-tank-squadron-ajax/ Need some extra terrain? Gothic Dome A solid resin cast dome formerly available as part of the Basilica Minoris plastic tiles set, now available separately. 1 x resin dome Notes: 1. Base 50mms square 2. 8mm tall figure shown for size purposes only and is not included https://vanguardminiatures.co.uk/shop/gothic-dome/ And something for the Skinners! Skinners – Tractor Vector Utility Vehicle A light utility tractor in common use with Skinners forces, used primarily to tow artillery pieces and supply trailers, as well as acting as a light run around amongst many other tasks. Set contains: 3 x tractor vector hulls 3 x engine upgrades 3 x generator modules Notes: 1. This model is also available in the Skinners heavy artillery set. https://vanguardminiatures.co.uk/shop/skinners-tractor-vector-utility-vehicle/ Link to comment Share on other sites More sharing options...
malika666 Posted June 28, 2021 Author Share Posted June 28, 2021 NEW SHIPS!!! Cybershadow Fleet – Light Cruiser Cybershadow light cruiser with three broadsides options. Set contains: 1 x light cruiser hull 1 x hull components sprue (2 prow options) 2 x broadsides sprues (cannon, launch bays, turrets) Notes: 1. Resin cast model 2. Model length approximately 75mms https://vanguardminiatures.co.uk/shop/cybershadow-fleet-light-cruiser/ Novan Elites – Lynx Pattern Assault Destroyer A common variant of the Lynx destroyer the “assault” pattern hull sacrifices its torpedo launchers and broadsides capabilities in order to house a ship busting plasma accelerator cannon, turning the ship into a dedicated attack vessel. Set contains: 1 x Lynx assault hull 1 x destroyer parts sprue Notes: 1. Resin cast model 2. Model approximate length 45mms including prow mounted plasma accelerator https://vanguardminiatures.co.uk/shop/novan-elites-fleet-lynx-pattern-assault-destroyer/ Novan Elites – Lynx Pattern Destroyers Lynx class Destroyers are small and fast craft that are capable of quickly delivering their deadly cargo. For its size the Lynx is heavily armed, making it a jack of all trades. Its basic armament includes two dorsal mounted twin turrets to take out incoming ordnance, and two pairs of prow torpedo tubes. Its broadsides allow for different types of weapon systems which can be changed whilst in dock due to its modular design. Most common broadside configurations are either weapon batteries or launch bays for a small compliment of fighters. Its diverse armament is also its main disadvantage. A lot of space normally used for supplies such as fuel, ammunition, foodstuffs, and oxygen is sacrificed for the Lynx’s many weapon systems. What this means is that the Lynx needs constant resupplying, making it incapable of long independent missions away from sources of supply. Because of this the Lynx is often deployed on short duration missions only, when not operating as part of a larger battle flotilla. This set contains: 2 x Lynx Destroyer hulls (1 x batteries, 1 x launch bays) 2 x optional wings sets and twin turrets Notes: 1.Resin cast models 2. Model length approx. 38mm 3. Flight base not included https://vanguardminiatures.co.uk/shop/novan-elites-fleet-lynx-pattern-destroyers/ Zopha and Ldorte 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted July 8, 2021 Author Share Posted July 8, 2021 A lot of new releases! First up, the Novan Regulars: Novan Regulars – Siege Troops Artillery Crews Crew figures for use with my various artillery pieces (no shells) Set contains: 22 x ground figures with integral bases 10 x vehicle figures without integral bases 32 figure set https://vanguardminiatures.co.uk/shop/novan-regulars-siege-troops-artillery-crews/ Novan Regulars – Short Bow SP Artillery https://vanguardminiatures.co.uk/shop/novan-regulars-short-bow-sp-artillery/ Novan Regulars – Warrior II Scout https://vanguardminiatures.co.uk/shop/novan-regulars-warrior-ii-scout/ Novan Regulars – Indentured Elementals Background to follow. Set contains: 4 x elemental sprues in 5 poses 20 figures in total https://vanguardminiatures.co.uk/shop/novan-regulars-indentured-elementals/ Novan Regulars – Static Bombardier This set contains 3 Static Bombardier on cruciform bases. Set contents: 3 x bombardier guns 3 x cruciform bases 3 x shell stack 3 x double shells 3 x shell trolley https://vanguardminiatures.co.uk/shop/novan-regulars-static-bombardier-battery/ And some extra goodies for the Renegades: Renegade – Sparta APC The Sparta is a light APC originally developed for Convent forces but it has also found favour and been adapted by some houses for use with Novan Elites Pathfinders teams who find it’s small size and silenced stealth engines ideal for battlefield recon duties. Some have been pressed into service by various nefarious forces although how they came by them is not known. Set contains: 4 x Spartas 4 x double sided rear hatches, plain on one side, renegade star on the other. Model approx. dimensions: length 26mm, width 16mm, height 9mm https://vanguardminiatures.co.uk/shop/renegade-sparta/ Spiked Trophy Poles With Impaled Elites Helmets Spiked trophy poles sporting impaled Elites helmets. Set contains: 3 x trophy pole sprues, 10 poles on each sprue 30 poles in total https://vanguardminiatures.co.uk/shop/spiked-trophy-poles-with-impaled-elites-helmets/ Zopha 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted July 15, 2021 Author Share Posted July 15, 2021 Printed models released in limited numbers, get them while they're available! 15mm Skinners – Leaders In Heavy Armour Skinners leaders in heavy armour. Set contains: 4 x Skinners leaders bodies 4 x variant arms sprues Notes: 1. 3D printed resin models 2. Model height 20mm from foot to top of armour https://vanguardminiatures.co.uk/shop/15mm-skinners-leaders-in-heavy-armour/ Ldorte and Zopha 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted July 16, 2021 Author Share Posted July 16, 2021 New ships inbound! Novan Merchant Fleet – Merchant Escorts The merchant fleets of the Novan great houses do not rely upon their respective navies to protect the great trade convoys that ply the space lanes of the Commonwealth. Instead they have integral military grade escorts of varying sizes and capabilities that are ready to engage any hostile threat to the convoy and its valuable cargo. The two ships in this set provide a fighter squadron carrier and a gun ship, they provide an integral fighter screen and defensive firepower for the fleet. This set contains: 1 x fighter squadron carrier 1 x gun ship 3 x prow variants (prows are compatible with the prows on the merchant logistics carrier) Notes: 1. Resin cast models 2. Models approximate lengths, carrier 51mms, gun ship 48mms https://vanguardminiatures.co.uk/shop/novan-merchant-fleet-merchant-escorts/ Novan Merchant Fleet – Logistic Carrier Merchant fleet logistic cargo carrier. This model can be built as a light carrier by omitting one central hull section. Set contains: 1 x logistics carrier hull sprue 2 x each of the five cargo pod variants 2 x prow variants (note these are compatible with the prows from the merchant escorts set) Optional wings. Notes: 1. Resin cast model. 2. Model length approximately 72mms https://vanguardminiatures.co.uk/shop/novan-merchant-fleet-logistics-carrier/ Renegade Fleet – Frigates Renegade frigates. This set contains: 2 x frigate hull variants 4 x prow variants (all usable on both hulls) Notes: 1. Resin cast models 2. Models approximately lengths, 40mms to 46mms dependent of which prows are fitted https://vanguardminiatures.co.uk/shop/renegade-fleet-frigates/ Renegade Fleet – Destroyers Renegade destroyers. This set contains: 1 x fighter carrier hull 1 x gun ship hull Notes: 1. Resin cast models 2. Models approximate lengths, 34mms https://vanguardminiatures.co.uk/shop/renegade-fleet-destroyers/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 1, 2021 Author Share Posted August 1, 2021 Novan Regulars – Self-propelled Heavy Field Mortar Battery Set contains: 3 x Warrior II artillery hulls 3 x heavy mortar sprues 3 x mortar cradle sprues 6 x siege troops crew 6 x urban troops crew 6 x desert troops crew https://vanguardminiatures.co.uk/shop/novan-regulars-self-propelled-heavy-field-mortar-battery/ Novan Regulars – Self-propelled Heavy Quad Launcher Battery Set contains: 3 x Warrior II artillery hulls 3 x heavy quad launcher sprues 3 x launcher cradle sprues 6 x siege troops crew 6 x urban troops crew 6 x desert troops crew https://vanguardminiatures.co.uk/shop/novan-regulars-self-propelled-heavy-quad-launcher-battery/ Renegade Regulars – Centurion Tank (Achilles) The centurion main battle tank is the most common tank used by Novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. The designs has seen many weapon fits over the years but this variant the (Achilles configuration) boasts a long range version of the standard tank cannon in the turret backed up by a fixed forward hull mounted laser cannon. In addition the hull sides can be configured to mount a sponson weapon most commonly a HMG for close in anti personnel protection. Pack contains 3 x renegade centurion tanks Achilles configuration with modelling options. Hull length approx, 30mms https://vanguardminiatures.co.uk/shop/renegade-regulars-centurion-tank-achilles-2/ Cybershadow – Praetoria Set 2 The Cybershadow Praetoria as we have designated them are an oddity within the Cybershadow military structure, although they can be seen operating and supporting other Cybershadow forces from time to time they seem to be an independent element not under the main chain of command. Their place within the Technocracy is not fully understood and is still open to some debate within military circles but it is known that they are an extremely aggressive and highly mobile force. Set contains: 15 x Cybershadow (support) Praetoria in four poses https://vanguardminiatures.co.uk/shop/cybershadow-praetoria-set-2/ Gothic Flying Buttress Set A set of 8 x resin cast gothic flying buttresses. Limited edition product. Notes: Height: 36mms Resin colour may vary https://vanguardminiatures.co.uk/shop/gothic-flying-buttress-set/ Link to comment Share on other sites More sharing options...
malika666 Posted August 10, 2021 Author Share Posted August 10, 2021 So the Eloi have just received some major reinforcements... Eloi Federation – Fire Banshee Detachment And to give you an idea of size: The Eloi Federation makes use of a great many battle walker designs, fast, graceful and with incredible agility in comparison to our own battle striders, they are potent and deadly war machines. This particular design is one of the most prolific machines fielded by Eloi battlegroups, Banshee’s operate in units of three with a piloted command unit and what appears to be two linked drones working in concert, although fully piloted combat teams have also been observed. Armaments, two arm mounted heavy laser cannon left and right, and two shoulder mounted medium rail cannon. Command units sometimes sacrifice one arm cannon for a close combat weapon instead, a large sword being the most common weapon observed. Notes: 1. Resin printed multipart models with some modelling options 2. Approximate height, 67mms to top of “wing” 3. Plastic bases not included https://vanguardminiatures.co.uk/shop/eloi-federation-fire-banshee-detachment/ apologist and Zopha 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 26, 2021 Author Share Posted August 26, 2021 So this is happening... Helian battleship, Leviathan pattern: Awaiting test print... Ldorte, RikuEru, painting.for.my.sanity and 2 others 5 Back to top Link to comment Share on other sites More sharing options...
apologist Posted August 26, 2021 Share Posted August 26, 2021 So the Eloi have just received some major reinforcements...[...] Eloi Federation – Fire Banshee Detachment And to give you an idea of size: [...] Notes: 1. Resin printed multipart models with some modelling options 2. Approximate height, 67mms to top of “wing” 3. Plastic bases not included This looks awesome – any thoughts on making it available at a slightly larger size? I'd love to use this as a proxy for a smaller Titan in Adeptus Titanicus, rather than as a Knight. I'd like it to stand taller than a Warhound, which are ~65mm. 75mm to the top of the head (~90mm to the top of the wing) would make it a great starting point to convert into a Revenant. malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 26, 2021 Author Share Posted August 26, 2021 I've seen some concept art for an Eloi warmachine that is the slightly bigger brother of the Fire Banshee. No clue when the digital sculpting will start though. Noserenda and apologist 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 30, 2021 Author Share Posted August 30, 2021 Some more space ship stuff! First of all, there have been some questions regarding the size of the upcoming Helian battleship. Here is is next to its cruiser counterpart: Secondly, there was a request for a cruiser prow to match the ones from the old Troublemaker Games versions Novan escorts: And thirdly, some Cybershadows cruisers have just been printed: Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted September 1, 2021 Author Share Posted September 1, 2021 NEW FACTION RELEASED!!! This is going to be the first batch of a new faction on Vanguard Miniatures' Dominion setting. Sentinel – Command Set contains: 3 x Commanders 6 x Sub-commanders 4 x Guardians 6 x Techs 6 x Drones Notes: Sample of contents shown Plastic base not included https://vanguardminiatures.co.uk/shop/sentinel-command/ Sentinel – Infantry Set contains: 40 x Sentinel infantry 6 x Sentinel casualties Notes: Plastic bases not included https://vanguardminiatures.co.uk/shop/sentinel-infantry/ Sentinel – Heavy Infantry Set contains: 40 x heavy infantry 2 x heavy infantry casualties Notes: Plastic bases not included https://vanguardminiatures.co.uk/shop/sentinel-heavy-infantry/ Sentinel – Swarm Dominus Set contains: 3 x swarm dominus 5 x swarm sprues (15 swarm discs) https://vanguardminiatures.co.uk/shop/sentinel-swarm-dominus/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted September 28, 2021 Author Share Posted September 28, 2021 Lots of new releases! For all you fleetscale players out there... Ordnance Turrets Set 1 Set contains: 12 x missile pod turrets 12 x single barrel turrets 12 x twin barrel turrets 12 x triple barrel turrets https://vanguardminiatures.co.uk/shop/ordnance-turrets-set-1/ Renegade Fleet – Fighters Set contains: 6 x Hecate Interceptor fighter sprues (5 fighter discs each) Notes: Fighters are on 6mm diameter discs designed to fit in the recesses of our plastic bases. These fighters are at 1/5000 scale https://vanguardminiatures.co.uk/shop/renegade-fleet-fighters/ Novan Elites Fleet – Fighters Set contains: 3 x Javelin fighter sprues (5 fighter discs each) 3 x Spiculum fighter sprues (5 fighter discs each) Notes: Fighters are on 6mm diameter discs designed to fit in the recesses of our plastic bases. These fighters are both at 1/5000 scale https://vanguardminiatures.co.uk/shop/novan-elites-fleet-fighters/ And some 3mm reinforcements! 3mm Cybershadows – Protector Infantry Interaction Protectors are the Cybershadows front line infantry, these dedicated and fearless cybernetically enhanced warriors escort the mighty Cybershadow War Stalkers into battle. As well as providing protection against enemy infantry for these mighty war machines they can also go where the War Stalkers cannot giving greater flexibility to the battlegroup, they also fulfil a garrison roll when not required for combat operations. Set contains: 24 x Protector infantry strip bases in two variants 1 x Command Node figure https://vanguardminiatures.co.uk/shop/3mm-cybershadow-protector-infantry-interaction/ 3mm Skinners – Rotary Cannon Tanks Skinners tank with rotary cannon turrets Set contains: 8 x tank hulls (4 variants) 8 x rotary cannon turrets (4 variants) https://vanguardminiatures.co.uk/shop/3mm-skinners-rotary-cannon-tanks/ Link to comment Share on other sites More sharing options...
malika666 Posted October 8, 2021 Author Share Posted October 8, 2021 Eloi Federation – Typhoon Heavy Tank To give you a sense of scale: Typhoon Heavy Grav-tank The Typhoon is the Eloi Federations heaviest anti-gravity combat vehicle encounter to date. A swift and highly manoeuvrable vehicle for its size it combines unprecedented mobility with lethal and highly accurate firepower. Typhoon’s are known to be crewed by two Eloi, a pilot/driver and a weapons operator both of which sit in the small rear compartment. The apparent central cockpit is in fact a highly advanced sensor array, real time data gathering module and terrain following suite linked directly to the crew by a neural linked helmet interface. This gives both crew members unprecedented situational awareness of their surroundings on the battlefield. The turret armament consists of two heavy laser cannon with a secondary centrally mounted rail gun sitting between the barrels. However two other weapons systems have also been observed on this chassis, a large long range energy weapon (the quantum lance), and a triple barrelled indirect fire weapon (the trinity plasma mortar). The graceful curvature and the thick well slopped composite armour plates of Eloi vehicles provide excellent protection from enemy fire but it is the tanks speed and agility that is considered to be its primary defensive measure. Set contains: 1 x heavy tank hull 1 x Twin heavy laser cannon turret 1 x Quantum lance turret (with 3 sponson options) 1 x Trinity plasma mortar turret Notes: This is a fully resin cast set Model approximate dimensions, length 75mms, width main hull 42mms – across the stabiliser fins 50mms, height around 10mms not including turrets https://vanguardminiatures.co.uk/shop/eloi-federation-typhoon-heavy-tank/ Link to comment Share on other sites More sharing options...
