malika666 Posted July 21, 2020 Author Share Posted July 21, 2020 Reinforcements for the Novan Elites have arrived! Novan Elites (B) – Special Weapons - £6.00 The Novan Elites make use of many special weapons.Set contains 24 figures: 8 x Flamethrowers 8 x Plasma guns 8 x Fusion guns https://vanguardminiatures.co.uk/shop/novan-elites-b-special-weapons/ Novan Elites – Trojan Skyshield Turrets - £2.50 Skyshield anti-aircraft missile turrets for the Trojan APC.Set contains: 4 x Skyshield turrets Note these turrets fit on the Trojan hull only. https://vanguardminiatures.co.uk/shop/novan-elites-trojan-skyshield-turrets/ Link to comment Share on other sites More sharing options...
malika666 Posted July 22, 2020 Author Share Posted July 22, 2020 The 3mm Skinners needed some vehicles! 3mm Skinners – Heavy Transport Pool - £9.00 This set contains:6 x Heavy transport hulls 2 x Skinners tank turret sprues Model length: 30mm https://vanguardminiatures.co.uk/shop/3mm-skinners-heavy-transport-pool/ Ldorte 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted July 23, 2020 Author Share Posted July 23, 2020 Space ship update: FYI.Posted up this notification on my website Panthera product entry.THIS WILL MOST LIKELY BE THE LAST BATCH OF METAL CAST PANTHERA BEFORE I MOVE OVER TO MOSTLY RESIN CAST SHIPS, SO PLEASE BE AWARE OF THAT. THE MOULD FOR THIS MODEL IS SHOWING SIGNS OF WEARING OUT SO THESE ARE NOT OF THE SAME QUALITY AS USUAL BUT STILL OF VIABLE USE, FORTUNATELY MOST OF THE WEAR IS IN AREAS THAT WILL BE COVERED BY THE "WINGS" OR WEAPON BROADSIDES.So this latest batch will most likely be the last metal Panthera available, if any of you guys/gals still want metal versions then you will have to snap them up once ordering has been enabled again either tomorrow or Thursday.Cheers John Get them in metal while you can: https://vanguardminiatures.co.uk/shop/novan-elites-panthera-ii-class-heavy-frigate-x-2/ Aaaaaand, another little update: Ok time for some good news.The first of the Zeus class vessels has entered production, the little Destroyer squadron will be the first release of this ship class, the frigate and cruiser to follow at a later date as circumstances allow.These are actual production casts samples sent to me yesterday. Master Ciaphas 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 7, 2020 Author Share Posted August 7, 2020 Novan Convent – Pacifier APC - £8.00 The Pacifier is a heavily modified variant of the Sparta APC, its primary roll is in urban pacification operations. Fitted with larger armoured viewports than a traditional APC and with hull mounted periscopes for the passengers, those onboard are provided with improved situational awareness when operating in built up areas. A dozer blade can also be mounted on the forward hull to help with breaching obstacles. Standard armament is a small remotely operated twin machine gun mount on the upper hull.Alternatively the passenger compartment can be quickly refitted to contain an armoured fuel tank from which to feed a non lethal crowd control water cannon, or if in extremely hostile situations or supporting battlefield operations a heavy dual flamethrower can be mounted. Set contains: 3 x Pacifier hulls 3 x Armoured dozer blades 3 x Twin heavy machine gun turrets 3 x Twin heavy flamethrower turrets 3 x Water cannon https://vanguardminiatures.co.uk/shop/novan-convent-pacifier-apc/ Doctor Perils 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 10, 2020 Author Share Posted August 10, 2020 So this just happened... Skinners – Hurk Heavy Bomber And Transport Plane - £28.00 The Hurk is one of the heaviest of the Skinners aircraft encountered to date, commonly seen in two variants. The strategic heavy bomber variant has twin bomb bays for heavy ordinance deployment as well as being able to drop lighter bombs from the rear drop down ramp position, the wings can also mount bombs or rockets as required. The transport variant replaces the bomb bay with troop benches and sports heavy machine guns for self defence, alternatively the troop benches can be removed in order to make space for logistics operations.Fixed armaments include two forward facing twin medium cannon on the fuselage, a rotating twin machine gun turret in the dorsal position and remotely operated rear facing twin machine guns on the tail, other armaments have also been observed. This is a multipart resin and metal kit with modelling options. Resin parts: 1 x Fuselage, 1 x Nose section, 2 x Wings (port and starboard), 1 x Vertical stabiliser fin, 1 x Horizontal stabiliser wing, 1 x Bomb bay module, 1 x Transport bay module, 4 x Engine intakes, 4 x Engine thrusters, 4 x Hull fixing dowels. Metal parts: I x Skinner Bombardier, 1 x Bomb bay ramp open, 1 x Closed ramp, 2 x Fuselage cannon, 1 x Dorsal turret, 6 x Machine gun barrels. Model dimensions: Length 115mm, Wing span 140mm Games Workshop Ork fighter (used without permission) shown for scale purposes only and is not included in this set. https://vanguardminiatures.co.uk/shop/skinners-hurk-heavy-bomber-and-transport-plane/ Ldorte, Interrogator Stobz, Firedrake Cordova and 2 others 5 Back to top Link to comment Share on other sites More sharing options...
Arendious Posted August 10, 2020 Share Posted August 10, 2020 Dammit... I'm probably going to have to buy that. And I don't even play orrr... Skinners in AI... malika666 1 Back to top Link to comment Share on other sites More sharing options...
Hungry Nostraman Lizard Posted August 10, 2020 Share Posted August 10, 2020 That's a huge chunky plane, very reminiscent of a Soviet PE-8 with stubbier wings, I like malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 12, 2020 Author Share Posted August 12, 2020 New ships released! Novan Elites Fleet – Jubatus Class Rapid Frigate - £7.50 Set contains:1 x Jubatus class frigate hull 1 x Broadsides set 1 x Components sprue Model length: 60mm Related product https://vanguardminiatures.co.uk/shop/novan-elites-fleet-jubatus-class-rapid-frigate/ Novan Fleet – Zeus Pattern Destroyers - £7.50 Set contains:3 x Zeus pattern Destroyers Model length: 30mm https://vanguardminiatures.co.uk/shop/novan-fleet-zeus-pattern-destroyers/ Brother_Bethor, Hungry Nostraman Lizard and Petitioner's City 3 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 17, 2020 Author Share Posted August 17, 2020 Eloi reinforcements inbound! Eloi Federation – Light Support Weapons Battery - £6.00 The Eloi field several types of support weapons systems mounted on anti-gravity platforms to support their infantry formations, the “light” support batteries observed include guided missile launchers, medium lasers and rail cannon. Each battery is sub-divided into three sections and consists of two platforms with two crew members per weapon and a battery commander.This set contains: 3 x Eloi crew sprues 2 x Medium laser platforms 2 x Rail cannon platforms 2 x Guided missile platforms Bases shown not included. https://vanguardminiatures.co.uk/shop/eloi-federation-light-support-weapons-battery/ Link to comment Share on other sites More sharing options...
malika666 Posted August 20, 2020 Author Share Posted August 20, 2020 Dunno if you guys have read this review, but it has some nice teasers of the upcoming Stalker crew set! Redrandy93 and Hungry Nostraman Lizard 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 27, 2020 Author Share Posted August 27, 2020 Novan Regulars Airborne – Heavy Combat Car - £7.50 Novan airborne forces utilise air transportable vehicles with two man crews to provide mobility and heavier firepower for their airborne battle groups.The heavy combat car serves in the fire support vehicle role, it is fitted with a manned turret with a 360 degree field of fire. Most common armament is either a twin rapid fire pulse laser to deal with massed infantry or twin anti-tank laser cannon. Set contains: 4 x Heavy combat cars 4 x Roll cages 4 x Twin laser cannon turrets 4 x Twin pulse laser turrets https://vanguardminiatures.co.uk/shop/novan-regulars-airborne-heavy-combat-car/ Novan Regulars Airborne – Light Combat Car - £6.50 Novan airborne forces utilise air transportable vehicles with two man crews to provide mobility and heavier firepower for their airborne battle groups.The light combat car functions as a scout vehicle and also fulfils a fast attack role. Most common armament is either a heavy flamethrower or belt fed grenade launcher. Set contains: 4 x Light combat car chassis 4 x Roll cages 4 x Grenade launcher gunners 4 x Flamethrower gunners https://vanguardminiatures.co.uk/shop/novan-regulars-airborne-light-combat-car/ Link to comment Share on other sites More sharing options...
Hungry Nostraman Lizard Posted August 27, 2020 Share Posted August 27, 2020 Mmm that magos is awesome! malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted August 31, 2020 Author Share Posted August 31, 2020 Cybershadow – Battle Walker Crews - £8.75 This is a pre-production limited numbers release of this figure set and contains 1 of each sprue type shown in the main image.A full production set will be released in the not to distant future. Restricted to one set per customer at this time. Note that these are first generation master castings the very best castings you can get. Figures represented are: Pilots and commanders both seated and on foot (some with small arms), technical drones and engineers. https://vanguardminiatures.co.uk/shop/cybershadow-battle-walker-crews/ Link to comment Share on other sites More sharing options...
malika666 Posted September 10, 2020 Author Share Posted September 10, 2020 Need some artillery? Novan Regulars – Siege Troops Heavy Field Mortar Battery - £7.00 Set contains:4 x Heavy field mortars with ammunition boxes 4 x Siege regiment heavy field mortar crew sprues (6 figures each) 4 x Novan light logistics trailers https://vanguardminiatures.co.uk/shop/novan-regulars-siege-troops-heavy-field-mortar-battery/ Novan Regulars – Siege Troops Heavy Quad Launcher Battery - £7.00 Set contains:4 x Heavy field quad launchers with ammunition boxes 4 x Siege regiment heavy field quad launcher crew sprues (6 figures each) 4 x Novan light logistics trailers https://vanguardminiatures.co.uk/shop/novan-regulars-siege-troops-heavy-quad-launcher-battery/ Hungry Nostraman Lizard 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted September 11, 2020 Author Share Posted September 11, 2020 Novan Elites (B) – Forlorn Hope Storm Squads - £9.00 When called upon to do so the Novan Elites will form special squads of volunteers to storm fortifications or breach the formidable defences of starships during boarding actions. The Forlorn Hope Storm Squads as they are known carry heavy blast shields and specialised weapons to aid them in these extremely hazardous duties.Origin, born in the crucible of the many sieges and breaching operations of the great Skinner’s Insurrection the storm squads have ever since become an integral part of the many tactical doctrines of the Novan Elites Legions. Set contains: 4 x Elites sergeants (in two poses) 4 x Elites special weapon troopers (in two poses) 40 x Elites with Storm Shields 2 x Elites casualties 50 figures in total. https://vanguardminiatures.co.uk/shop/novan-elites-b-forlorn-hope-storm-squads/ Sandlemad, Llagos_Tyrant, Hungry Nostraman Lizard and 1 other 4 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted September 29, 2020 Author Share Posted September 29, 2020 Update from Battlegroup Helios: UPDATEAll Zeus pattern ships and the spear prows have been approved for manufacture. Mould making could start in as little as two weeks with a pre-xmas release quite possible.Panthera and Lynx, both are now being re-printed and will be put back in production as soon as possible.Also now in the queue to follow on the heels of these are another ten vessels for various factions. Hrvat 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted October 2, 2020 Author Share Posted October 2, 2020 Coming tomorrow... Ldorte and Redrandy93 2 Back to top Link to comment Share on other sites More sharing options...
Hungry Nostraman Lizard Posted October 2, 2020 Share Posted October 2, 2020 Woah, that's some good stuff! malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted October 8, 2020 Author Share Posted October 8, 2020 Back in stock! Novan Regulars – Medusa Siege Assault Carrier The Medusa is a dedicated assault carrier developed specifically for the needs of the renowned “Siege regiments” of the Fero Ascendancy. A major adaption of the Tribune heavy tank hull capable of transporting up to four squads of infantry, with egress via a drop down assault ramp. Armaments include sponson heavy machine guns, sponson grenade launchers and two twin medium machine gun mounts in the upper hull. Used on mass to overwhelm enemy positions with sheer weight of numbers these troop carriers have proven most effect in there assigned roll.This set contains: 1 x resin Medusa hull 1 x resin components sprue 1 x metal sponsons sprue 1 x metal gunners sprue (2 gunners) 11 x metal passengers sprues (44 passengers) Model painted by Gregory Bailly https://vanguardminiatures.co.uk/shop/novan-regulars-medusa-siege-assault-carrier/ https://vanguardminiatures.co.uk/shop/novan-regulars-medusa-siege-assault-carrier-squadron/ SteveAntilles, Ldorte, Hungry Nostraman Lizard and 1 other 4 Back to top Link to comment Share on other sites More sharing options...
Sandlemad Posted October 8, 2020 Share Posted October 8, 2020 Not quite my jam but those look amazing, well done. malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted October 10, 2020 Author Share Posted October 10, 2020 Little random release, not meant as a replacement for the existing Centurion Main Battle Tank, but a hull variant of it! Novan Regulars – Centurion Exposed Tracks (Hector) - £8.50 The centurion main battle tank is the most common tank used by Novan Regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions.The designs has seen many weapon fits over the years but the most common armaments (hector configuration) are a regular tank cannon in the turret backed up by a fixed forward hull mounted laser cannon. In addition the hull sides can be configured to mount a sponson weapon most commonly a HMG for close in anti personnel protection. This model is a regular Centurion tank without track guards. This set contains: 3 x Centurion hulls without track guards 3 x Hector turret sprues 3 x bow machine guns 8 x hatches (6 closed, 2 open) https://vanguardminiatures.co.uk/shop/novan-regulars-centurion-exposed-tracks-hector/ Link to comment Share on other sites More sharing options...
malika666 Posted October 16, 2020 Author Share Posted October 16, 2020 (edited) Eloi reinforcements! Eloi Federation – Way Seekers - £3.50 Eloi Federation Way SeekersFunction: The Way Seekers of the Eloi Federation function as the leaders of Eloi Battle Contingents, and are to be found serving at all levels of command from Detachment Commander to Battle Group Leaders. They have many specialist branches within the Eloi’s military establishment. Highly intelligent and extensively trained the “Seekers” as they are commonly known have studied the art of war in all its many aspects and are therefore opponents not to be underestimated. Equipment: They wear a modified suit of Eloi battle armour and robes made of an unknown fabric with several remarkable properties which will not be elaborated upon here. Armaments carried by such individuals include conventional Eloi small arms as well as the favoured “great sword” a melee weapon capable of piercing even the mighty armour of our Novan Elites. Certain individuals have also been observed as carrying the less common spear and rarely a staff which may serve as a badge of office. Observed abilities: Redacted by order of the high command – Magenta level clearance required. This set contains: 12 x way seekers 1 x master seeker Miniatures painted by John Fielding. Plastic base not included. https://vanguardminiatures.co.uk/shop/eloi-federation/ Edited October 16, 2020 by malika666 Link to comment Share on other sites More sharing options...
malika666 Posted October 25, 2020 Author Share Posted October 25, 2020 First up, some 3mm reinforcements for the Novan Regulars: 3mm Novan Regulars – Siege Regiment Command - £1.25 Representing a battalion or regimental command group with transport and escort vehicles.This set contains: 1 x siege regiment command strip 1 x warrior I 1 x warrior II https://vanguardminiatures.co.uk/shop/3mm-novan-regulars-siege-regiment-command/ 3mm Novan Regulars – Warrior II IFV Transport Pool - £6.00 This set contains:16 x warrior II hulls 16 x warrior II pulse laser turrets https://vanguardminiatures.co.uk/shop/3mm-novan-regulars-warrior-ii-ifv-transport-pool/ And the 6mm scaled stuff couldn't be left behind... Novan Elites – Guardian Tanks (Turnus) - £9.00 The Elites Guardian tank is yet another product of Tusculum Nova’s most advanced research and development programs to equip it’s Elite forces with the most powerful weapons and equipment that can be provided. Guardian’s are intended to act as front line main battle tanks a roll originally filled by the older Scorpion designs which have now been relegated to a supporting roll for the mechanised squadrons. The hull bears a similar appearance to the Mauler assault transport and was developed alongside that vehicle. Although smaller than the mauler it is none the less a very potent design heavily armed and armoured with an impressive turn of speed .This particular variant of the Guardian utilises the latest turret design commonly found on many new production run Trojan IFV’s with in this case a twin 20mm rotary-cannon mounted to either side of the commanders hatch these cannon are devastating in the anti-personnel roll and they are extremely effective against light vehicles also. Two sponson mounting points are also available these can be fitted with several weapon options with either the standard laser cannon or heavy machinegun being the most common choices and there is also a permanant forward hull MG fitted as standard. In the guardian elite forces have a highly versatile and potent battle tank able to survive in the deadliest of warzones. This pack contains 3 x guardian main battle tanks with rotary cannon turrets. Model dimensions are: 30mm long, 22mm wide not including sponsons, 15mm high to top of turret. https://vanguardminiatures.co.uk/shop/novan-elites-guardian-turnus/ Hungry Nostraman Lizard 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted November 5, 2020 Author Share Posted November 5, 2020 Novan Regulars – Heavy Anti-aircraft Cannon - £9.00 DescriptionHigh altitude heavy anti-aircraft cannon of 90mm calibre on static cruciform mounting.This set contains: 3 x heavy anti-aircraft cannon sprues 3 x cruciform mounts https://vanguardminiatures.co.uk/shop/novan-regular-heavy-anti-aircraft-cannon/ Paintjob by Khan. Hungry Nostraman Lizard 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted November 8, 2020 Author Share Posted November 8, 2020 Update time! Ships NewsAfter much thought I decided to dispense with the funding campaign and press ahead with self funding a bunch of the ships myself. The Panthera frigate and Lynx destroyers previously manufactured in metal have now been slightly remodelled and remastered for resin casting. These three ships are now being moved towards printing the masters and then moulding. Hope to see them re-released very early next year. Zeus pattern vessels, the destroyer as you are probably aware has already been released. I have now received sample production castings of the cruiser, light cruiser and frigate which I have authorised to be manufactured ASAP, the casters predict a late November delivery date for the first batch of those. The Spear pattern prows will also be available around the same time. Picture of all four ship types below. LameBeard and Dr_Ruminahui 2 Back to top Link to comment Share on other sites More sharing options...
