malika666 Posted April 8, 2017 Author Share Posted April 8, 2017 The first batch of variants of the Centurion Battle Tank have been cast: http://i66.tinypic.com/35l6mif.jpg http://i64.tinypic.com/wwdnh0.jpg http://i64.tinypic.com/2gv57wx.jpg Sniper tank: http://i65.tinypic.com/33a8hhv.jpg Siege tank: http://i66.tinypic.com/2ufue1h.jpg Autocannon tank: http://i67.tinypic.com/2ijpz6f.jpg Plasma cannon tank: http://i68.tinypic.com/ixqlgw.jpg Laser cannon tank: http://i65.tinypic.com/14xkw8j.jpg AceofCase 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 9, 2017 Author Share Posted April 9, 2017 Look what just came out: Novan Elites Battlemaster Command Tank: The Battlemaster is a front line C4i (command, control, communications, computer and intelligence) vehicle for novan elite forces. The design is basically a stretched mauler assault transport chassis and shares many components with that vehicle, the increased internal space allows for a full battlefield command and control suite to be installed giving up to the minute intelligence and situational awarness to the battlegroup commander via the highly sophisticated sensor dome mounted on the upper hull and functions in a similar roll to the regular armies Dictum command vehicle. The sensor module (with a more limited capacity) can also be mounted on the trojan APC but the smaller size of this vehicle does not allow for the full command package or holo tank to be installed. Due to the increased internal space a transport variant of this vehicle has been developed for novan elite troops in heavy armour allowing up to 10 such troopers to be transported instead of the mauler’s 5 man capacity with this armour type. With the sensor suite removed the vehicle also has the capacity to mount a scorpion tank turret for increased firepower. This however does reduce the transport capacity back to 5 men due to the turrets operating systems, crew and ammunition. Dimensions are: hull length 42mm, hull width 25mm, hull height 9mm not including sponson mounts or sensor dome. Single model (£7.50): http://vanguardminiatures.co.uk/shop/novan-elites-battlemaster-command-tank-x1/ Two-pack (£14.00): http://vanguardminiatures.co.uk/shop/novan-elites-battlemaster-command-tank-x-2/ And yes, it's compatible with existing turrets/sponsons: Race Bannon and Khornestar 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 10, 2017 Author Share Posted April 10, 2017 In the meantime, Vanguard is current stocking Wasteland Game Studio's amazing 6mm terrain: http://vanguardminiatures.co.uk/product-category/terrain/wasteland-game-studio/ And also, some new prints have just arrived: Link to comment Share on other sites More sharing options...
malika666 Posted April 14, 2017 Author Share Posted April 14, 2017 Artillery units out! Novan Regulars Bombadier SPM: Self propelled version of the common novan bombadier heavy mortar mounted on a modified warrior hull. Contains 3 x bombadier SPM’s, artillery crew not included. Model dimensions are: length 35mm, width 22mm, height 10mm not including weapons or crane. £11.00 http://vanguardminiatures.co.uk/shop/novan-regulars-bombadier-spm/ Novan Regulars Archer SPA: Self propelled version of the common novan archer heavy artillery gun mounted on a modified warrior hull. Contains 3 x archer SPA’s, artillery crew not included. Model dimensions are: length 35mm, width 22mm, height 10mm not including weapons or crane. £11.00 http://vanguardminiatures.co.uk/shop/novan-regulars-archer-spa/ Race Bannon and Khornestar 2 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 15, 2017 Author Share Posted April 15, 2017 By the way, to give you an idea of scale: Top row (left to right): Anti-Tank Skimmer, Sniper Tank Hunter, Mauler Assault Transport, Battlemaster Command Tank, upcoming super heavy tank, Stormer Siege Breaker, Breacher Siege Harness Bottom row (left to right): Lightning Skimmer, Trojan APC, Support Tank, upcoming Siege Tank, Scorpion Tank (type A), Guardian Main Battle Tank, Gladiator Battlemaster next to a Land Raider: paulJam 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 16, 2017 Author Share Posted April 16, 2017 More new releases today! Plastic Strip Bases 40mm x 12mm (50) £4.50 for 50 bases Plastic strip bases with five recesses for infantry figures. Pack contains 50 x bases with random recess configuration. Dimensions are: 40mm long, 12mm depth, 1.6mm thick. http://vanguardminiatures.co.uk/shop/plastic-strip-bases-40mm-x-12mm-50/ Novan VTOL Buzzard Sky Crane Transport Mk1 £10.00 for two aircraft The P-1218 Buzzard Sky crane transport VTOL Aircraft (Mk1) is yet another development of the Raptor aircraft program being a heavily modified Kestrel airframe designed to carry light vehicles into combat zones. Instead of a troop cabin it has four articulated hydraulic arms that clamp onto the cargo be it a light vehicle or supply pod which allows rapid deployment of the cargo and a quick exit of the drop zone for these lightly armed aircraft. Most commonly escorted by Falcon gunships the Buzzard has proven a very versatile addition to novan air assault forces. Length – 5cm, Wingspan – 4cm This set contains 2 x Buzzard Sky Crane Transport Mk1 Aircraft, and 2 x plastic flying stands. http://vanguardminiatures.co.uk/shop/novan-vtol-buzzard-sky-crane-transport-mk1/ Novan Elites Heavy Armour Breacher Assault Weapons £8.50 for 44 models Tusculum Nova’s heavy armour elites have seen many equipment adaptions over the years with numerous weapons specifically designed to enhance their abilities in all combat situations. These particular troops have been specifically armed for Breaching operations with various specialist equipment such as the forlorn hope blast shield and siesmic hammer combination, whilst other’s have enhanced combat gloves with shreader claw attachments. Some troops will carry grenade launcher pods and heavy flamethrowers are also used to clear a breach of enemy personnel. Usually transported in the Stormer these elite forces have been the downfall of many an impregnable enemy fortress. This pack contains 44 x novan heavy armour elites with breacher weapons. http://vanguardminiatures.co.uk/shop/novan-elites-heavy-armour-breacher-assault-weapons/ Race Bannon and paulJam 2 Back to top Link to comment Share on other sites More sharing options...
Eternal Warrior Posted April 16, 2017 Share Posted April 16, 2017 Those breachers are amazing! Please keep up the good work! malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted April 30, 2017 Author Share Posted April 30, 2017 Various new releases: 28mm Tainted Novan Regulars Special Weapons set - £18.00 This set contains the following: 5 x Plasma gunners 5 x Microwave gunners 10 x plastic bases http://vanguardminiatures.co.uk/shop/28mm-tainted-novan-regulars-special-weapons-set/ 28mm Tainted Novan Regulars Command Section - £20.00 This set contains the following: 2 x Officers 2 x Icon carriers 6 x troopers with various weapon options, 4 x rifles, 2 x microwave guns, 2 x plasma guns 10 x plastic bases http://vanguardminiatures.co.uk/shop/28mm-tainted-novan-regulars-command-section/ And of course the 6mm stuff: Novan Regulars Centurion Tank Armour Hunter - £10.70 The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. The design has seen many weapon fits over the years, this variant (Nestor configuration) is a dedication anti vehicle hunter armed with a duo laser cannon mount in the turret as well as the regular forward hull laser cannon. The optional sponsons in this case also sport laser cannons making for an exceptional multi target engagement platform. Pack contains 3 x centurion armour hunter tanks with modelling options. http://vanguardminiatures.co.uk/shop/novan-regulars-centurion-tank-armour-hunter/ Novan Regulars Centurion Tank Light Vehicle Hunter - £10.70 The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. The design has seen many weapon fits over the years this variant (Patroclus configuration) is a dedication anti light vehicle and infantry hunter armed with a duo auto cannon mount in the turret as well as the regular forward hull laser cannon. The optional sponsons usually house the common heavy machine guns for anti infantry duties. Pack contains 3 x centurion light vehicle hunter tanks with modelling options. http://vanguardminiatures.co.uk/shop/novan-regulars-centurion-tank-light-vehicle-hunter/ Novan Regulars Centurion Tank Bunker Buster - £10.70 The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. The design has seen many weapon fits over the years this variant (Ajax configuration) has a demolition mortar in the turret designed to smash defensive enemy bunkers at point blank range, backed up by a fixed forward hull mounted laser cannon. In addition the hull sides can be configured to mount sponson weapons the most common fit on this variant being microwave cannon. Pack contains 3 x centurion bunker buster tanks with modelling options. http://vanguardminiatures.co.uk/shop/novan-regulars-centurion-tank-bunker-buster-2/ Novan Regulars Centurion Tank Heavy Infantry Hunter - £10.70 The centurion main battle tank is the most common tank used by novan regular forces in the field a rugged and heavily armoured design it has been built to be a reliable and easy to operate vehicle capable of going long periods of time between maintenance cycles making it the perfect machine to equip Tusculum Nova’s armoured divisions. The design has seen many weapon fits over the years this variant (Paris configuration) mounts the fearsome plasmic cannon capable of breaching the type of heavy armour worn by novan elite forces this is a rare but extremely potent anti heavy infantry weapon system. The regular forward hull laser cannon is also present on this variant and the optional sponsons usually house the common heavy machine guns for conventional anti infantry duties. Pack contains 3 x centurion heavy infantry hunter tanks with modelling options. http://vanguardminiatures.co.uk/shop/novan-regulars-centurion-tank-heavy-infantry-hunter/ Link to comment Share on other sites More sharing options...
malika666 Posted May 12, 2017 Author Share Posted May 12, 2017 New release!!! I'm kinda excited here, for years I've been working on designing ships and one of the reasons why I've joined up with Vanguard Miniatures was to have my ship designs put in production. Hopefully this will be the beginning of a whole bunch of ships being released! Novan Elites Panthera Class Heavy Frigate x 2 - £7.00 The Panthera class Heavy Frigate is the workhorse of the Novan Elite fleets. Heavily armed and armoured, its various weapon configurations allow it to fulfil many different void combat roles. No matter its broadside configuration, the Panthera’s basic armament includes two heavy twin linked dorsal mounted turrets and two pairs of prow torpedo tubes. Its broadsides allow for different types of weapon systems which can be changed whilst in dock due to it’s modular design. Most commonly used are weapons batteries, more than capable of tearing huge chunks out of enemy vessels many times its own size. Another popular configuration for the Panthera is to fit it with launch bays, allowing the heavy frigate to carry several squadrons of Javelin fighters and Pilum bombers. In order to protect other ships of the fleet from waves of ordnance and enemy fighters the Panthera is sometimes also configured with broadside turret platforms capable of projecting a withering volume of defensive fire. Panthera class heavy frigate x 2 with three broadside options each. Images show three vessels to demonstrate the broadside options. Model is 52mm long, bases not included. http://vanguardminiatures.co.uk/shop/novan-elites-panthera-class-heavy-frigate-x-2/ airinhere 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted May 18, 2017 Author Share Posted May 18, 2017 The Gladiator walker kit will be updated: I have had a walking pose created for the gladiator and mirrored it to gain two new poses. Also had the arm mounts lowered as I feel it creates a more pleasing aesthetic for the model. Also, new prints: Pilum class bombers: More Centurion Battle Tank variants: I've got two questions for you: 1) Would you like to see a 6mm version of the Pilum bomber? 2) What other Centurion variants would you like to see? Link to comment Share on other sites More sharing options...
malika666 Posted May 20, 2017 Author Share Posted May 20, 2017 Winter Infantry 2.0 are out! Novan Winter Infantry: £7.20 for 48 Armed in a similar manner to conventional Novan Rifle squads, the Winter Infantry are issued with heavy protective clothing and breathing apparatus intended for operations conducted in extremely cold environments, where exposed flesh or even eyeballs will freeze in minutes. 48 x Novan Winter Infantry http://vanguardminiatures.co.uk/shop/novan-winter-infantry/ Link to comment Share on other sites More sharing options...
malika666 Posted May 21, 2017 Author Share Posted May 21, 2017 (edited) New casts are in! Castings of the new elites vehicles are in i'm loving these. Challenger, Dominator, and Punisher super heavy tanks and also the Trojan Hammer and Hunter variants. Edited May 21, 2017 by malika666 Link to comment Share on other sites More sharing options...
malika666 Posted May 21, 2017 Author Share Posted May 21, 2017 Also, a little something for BFG fans: expect a big announcement in the coming days... Link to comment Share on other sites More sharing options...
Petitioner's City Posted May 21, 2017 Share Posted May 21, 2017 This really makes me think of Warzone 2100, which at the time did remind me of 40k (at least in weapon names, if nothing else). Link to comment Share on other sites More sharing options...
malika666 Posted May 22, 2017 Author Share Posted May 22, 2017 http://i68.tinypic.com/16bedz8.jpg Link to comment Share on other sites More sharing options...
malika666 Posted May 24, 2017 Author Share Posted May 24, 2017 Need some reinforcements for your Novan Elites? Novan Elites Hammer and Hunter Tanks - £6.00 As Novan Elite forces grew to operate more independently from other elements of the Novan military, they were forced to develop vehicles and units normally assigned to the Novan Regulars. This means that the Novan Elites needed to develop their own siege tanks. A modification of the Trojan Infantry Fighting Vehicle (IFV) hull was developed to match the Regulars’ Support Tank Hull. Like its Warrior IFV based brother, this variant of the Trojan has been armed with various weapon configurations – the two most popular being the Siege Cannon and the Heavy Laser Cannon. The Trojan Hammer is a light siege tank, deployed to take out enemy bunkers and fortifications. Its Siege Cannon can easily turn armoured structures into rubble. The Trojan Hunter’s role is that of a tank hunter. Its Heavy Laser Cannon has been designed to penetrate heavy armour and thick shielding, making the Trojan Hunter the perfect candidate to eliminate enemy tanks and even larger war engines. Pack contains: 2 x hulls, 2 x siege cannon, 2 x laser cannon http://vanguardminiatures.co.uk/shop/novan-elites-hammer-and-hunter-tanks/ Link to comment Share on other sites More sharing options...
malika666 Posted May 26, 2017 Author Share Posted May 26, 2017 The new super heavy tanks are in! Novan Elites Challenger Super Heavy Tank (x1) - £6.75 Dimensions: 45mm long, 26mm wide excluding sponsons, 17mm high to top of turret. http://vanguardminiatures.co.uk/shop/novan-elites-challenger-super-heavy-tank-x1/ Or get three of them for £18: http://vanguardminiatures.co.uk/shop/novan-elites-super-heavy-tank-company/ Novan Elites Dominator Super Heavy Tank (x1) - £6.75 Dimensions: 45mm long, 26mm wide excluding sponsons, 17mm high to top of turret. http://vanguardminiatures.co.uk/shop/novan-elites-dominator-super-heavy-tank-x1/ Or get three of them for £18: http://vanguardminiatures.co.uk/shop/novan-elites-dominator-super-heavy-tank-company/ Novan Elites Punisher Super Heavy Tank Destroyer (x1) - £6.75 Dimensions: 45mm long, 26mm wide excluding sponsons, 17mm high to top of turret. http://vanguardminiatures.co.uk/shop/novan-elites-punisher-super-heavy-tank-destroyer-x1/ Or get three of them for £18: http://vanguardminiatures.co.uk/shop/novan-elites-punisher-super-heavy-tank-destroyer-company/ IronDrake28 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted May 27, 2017 Author Share Posted May 27, 2017 The Tainted are in! Tainted Regular Infantry - £7.00 Pack contains 40 x tainted regular infantry. http://vanguardminiatures.co.uk/shop/tainted-regular-infantry/ Tainted Regulars Specialists - £6.50 Pack contains 36 miniatures: 4 x officers 2 x political officers 2 x icon bearers 2 x riflemen 4 x prone snipers 2 x light quad mortars with 2 crew each 2 x heavy mortars with 2 crew each 2 x heavy auto cannon with light tractors and spotters 2 x auto cannon ammo trailers with light tractors http://vanguardminiatures.co.uk/shop/tainted-regulars-specialists/ Link to comment Share on other sites More sharing options...
malika666 Posted June 4, 2017 Author Share Posted June 4, 2017 New renders: New turrets for your Novan Elite vehicles. http://i1299.photobucket.com/albums/ag77/Stefmanovic/Guardian-trojan_zps7hprcavc.jpg And some reinforcements for the Tainted... deathspectersgt7 1 Back to top Link to comment Share on other sites More sharing options...
Eddie Orlock Posted June 5, 2017 Share Posted June 5, 2017 So, any plans for a certain Grant style grav tank to support some Affray++? malika666 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted June 5, 2017 Author Share Posted June 5, 2017 Ha, you'll just have to wait and see... Link to comment Share on other sites More sharing options...
malika666 Posted June 17, 2017 Author Share Posted June 17, 2017 Some upcoming 15mm miniatures: Novan Elites: Race Bannon 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted June 19, 2017 Author Share Posted June 19, 2017 Little teaser... Currently at the printers is this 6mm scale wierd but wonderful tainted cybershadows big wheel tank. Battybattybats 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted June 23, 2017 Author Share Posted June 23, 2017 New releases! 15mm Novan Elites Forefront Set (jump packs): £13.00 Novan Elites Forefront infantry set. Set consists of: 16 x Forefront Elites with rotary blade swords & pistols 4 x Forefront Elites with flame throwers 4x Forefront Elite Sergeants http://vanguardminiatures.co.uk/shop/15mm-novan-elites-forefront-jump-packs/ 15mm Novan Elites Heavy Armour Set: £13.00 Novan Elites Heavy Armour infantry set. Set consists of: 8x Novan Elites in Heavy Armour 2x Novan Elites in Heavy Armour Sergeants http://vanguardminiatures.co.uk/shop/15mm-novan-elites-heavy-armour-set/ Race Bannon 1 Back to top Link to comment Share on other sites More sharing options...
malika666 Posted June 27, 2017 Author Share Posted June 27, 2017 Here some more teasers of some upcoming stuff: Lynx class Destroyers for the Novan Elites: The Tainted are also getting some reinforcements: http://i1299.photobucket.com/albums/ag77/Stefmanovic/19457793_10214143670494522_1491340402_o_zpspityv0p6.jpg And the Dread Wheel has been printed: http://i1299.photobucket.com/albums/ag77/Stefmanovic/P1050335p_zpsp8rtfsip.jpg http://i1299.photobucket.com/albums/ag77/Stefmanovic/P1050334p_zpsf5grxhxk.jpg Race Bannon 1 Back to top Link to comment Share on other sites More sharing options...
