8th Edition: Close Combat Weapons
  • Please log in to reply
172 replies to this topic
#1
Imeran
Imeran
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 426 posts
  • Gender:Male
  • Chapter Name: Iron Hands
https://www.warhamme...omepage-post-4/
Let’s take a look at some close combat weapons, shall we?
We’ve seen already that shooting weapons in the new Warhammer 40,000 use a Strength, AP, Damage system, and melee kit is much the same. The main differences being that there is no range on them, and a lot of them will use the user’s Strength as their basis.
Let’s look at some examples – we’ll start with the classic power weapon lineup.
In the current edition of Warhammer 40,000, the axe is the go-to weapon for a lot of folks. Players gladly took the unwieldy rule in exchange for AP2 and a bonus to Strength. Now, the obvious choice is far from obvious, as they clearly all have their uses. That sword, for example, is looking pretty deadly against most things, with the AP-3 helping it against every type of foe. Even with no bonus to Strength, using the new wounding chart shows that a Strength 4 Space Marine is wounding everything up to Toughness 7 on 5s (which is good,  because a lot of our models have swords).
Even the humble chainsword gets a boost. No longer just a standard combat weapon, the iconic combat weapon wielded by the Adeptus Astartes and many other forces, now gives its bearer more attacks in combat. Perfect for grinding through hordes of low armoured troops, the chainsword now functions on the battlefield how it always has in your head. This change also helps differentiate dedicated combat troops from those just wielding improvised or side-arm weapons.
We can see that all of the above still only do 1 Damage, meaning that while they can chip wounds off bigger stuff, they are primarily infantry killers.
What about some anti-armour stuff though? Check out the power fist:
At the cost of being more cumbersome to swing, it’s dishing out multiple damage with every hit, and at a Strength that will find it easy to wound anything in the game.
Another high damage option is Force weapons. Take a Grey Knight squad of any sort: every guy in there has a blade that, as well as having all the benefits of the equivalent Power weapon, also dishes out D3 damage on every wound! Those guys are going to be phenomenal up-close killers, as they should be.
New40kCCWNemesis.jpgD3 Damage is good, but if you really want to kill something, try the reaper chainsword. This deals a flat 6 Damage to whatever it wounds. That’s enough to carve a Chaos Lord in half, and a couple of hits will wreck most small and medium vehicles in a single Fight phase.
Make no mistake, when facing a dedicated melee unit, stuff is going to die in combat really, really fast.
  • Emicus likes this
#2
Interrogator-Chaplain Ezra
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 3,278 posts
  • Gender:Male
The wording on the chainsword. It's like music to a rules lawyer.
But considering said wording, can we expect to have to split attacks between weapons if the model has several?
  • the jeske likes this
#3
Damo1701
Damo1701
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,285 posts
  • Gender:Male
  • Chapter Name: Ravenguard
Well, that's underwhelming for Fists and Reaper Chain Swords, which, rather than destroying lighter vehicles with ease, now needs to attempts, Fists are hitting on 4's or more, so that's a nerf, no AP on a chain sword, but +1 attack...
Look out Vanguard, you are all going to be ripped apart and lose your iconic weapons for Chainswords and pistols.
Axe, Maul, and Sword?  Pretty standard.
Posted ImagePosted Image
#4
Raven1
Raven1
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 636 posts
  • Gender:Male
Why? You make one additional attack. The owning player removes at his choice, and you have to be within 1" of the enenmy to make attacks.
I expected chainswords to be rend -1 though.
  • Trevak Dal likes this
#5
Valerian
Valerian
    ++ EQUITES ALATUS ++
  • ++ MODERATI ++
  • 7,453 posts
  • Gender:Male
  • Chapter Name: Space Wolves and Grey Knights
As expected, the Power weapons are just like the Force weapons we saw on the Rubric data slate, but with D1 instead of D3.
V
#6
Damo1701
Damo1701
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,285 posts
  • Gender:Male
It looks like I'll be removing the claws, fists, hammers etc from the Vanguard to give them chainswords.  Seeing as it looks like the +1 A for two weapons, and the +1A for charging are vanishing.
Bit of an odd rule though, for a chainsword.  Why not make it AP-1 instead to make it easier.
#7
Canadian_F_H
Canadian_F_H
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 3,644 posts
  • Gender:Male
  • Chapter Name: Black Templars
Wow... not knowing the rest of a knight's rules... but their massive chainsword doing a flat 6 damage is amazing... didnt guilliman have 9 wounds?
  • uberwolve likes this
#8
Deus Ex Ferrum
Deus Ex Ferrum
    ++ INTERFECTOR PRODITORES ++
  • ++ MODERATI CEDO ++
  • 4,691 posts
  • Gender:Male
I'm glad that chainswords finally got some specific rules back, instead of just being a bog-standard CCW.  I'd have preferred an AP value, but an additional attack when the pistol+CCW bonus attack appears to have been removed?  I'll allow it.
  • Valerian, BadSanta, Inquisitor Eisenhorn and 1 other like this
Disclaimer: As far as I'm concerned, post-Heresy fluff for the Iron Hands begins with Index Astartes III: Hand of Justice and ends with Space Marine Battles: Wrath of Iron. Whoever wrote the Raukaan supplement can die in a fire.
#9
Raven1
Raven1
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 636 posts
  • Gender:Male
@Canadian_F_H, yes although it wont kill many special characters or vehicles in one hit. It will kill them in fight phase.
#10
depthcharge12
depthcharge12
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 7,996 posts
  • Gender:Male
  • Chapter Name: XVth Legion, Ist Legion
Finally power swords will see the light of day again
  • Valerian and Theduke08 like this
Sons of Horus painting log (3000+ points & Horus)
http://www.bolterand...rus-plog-horus/
Scars of Rangdan, Dark Angels Legion:
http://www.bolterand...79#entry4575179
#11
CommodusXIII
CommodusXIII
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,409 posts
  • Gender:Male
  • Chapter Name: ΦΙΡΜΑΜΕΝΤΥΜ
I like the new Reaper Chainsword rules.  It hits like a ton of bricks, but it's not nearly as powerful as Destroyer weapons used to be.  That makes it more likely that I can get games in with my Knight Household without all the complaining.
Personally, I think they are coming. Like a massive electrified thousand ton ball of barbed wire with hundreds of trapped and frustrated gamers embedded in it, rolling down a hill. "That, Bilbo Baggins, is the sound of inevitability."
#12
Lexicanum
Lexicanum
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 14 posts
  • Gender:Male
I, for one, welcome our new pistol and chainsword overlords.
  • uberwolve, Dolchiate Remembrancer, BadSanta and 4 others like this
#13
Imeran
Imeran
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 426 posts
  • Gender:Male
I like it just for variations sake. If you gave all weapons just varying amounts of +S and -AP, they'd get pretty boring. It's questionable how well this is all balanced, but since they want to make it a living set of rules, things will balance out eventually and additionally keep the fluffy variations. At least that's the hope.
#14
Swarm492
Swarm492
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 7 posts
Where did they say the bonus attacks for charging or for having two CC weapons was going away?
#15
uberwolve
uberwolve
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,291 posts
  • Gender:Male
  • Chapter Name: The Deleted.
Power swords look freaken amazing. Just have to find a way to pip the users strength.
I didn't expect a rend value on the chainswords because bolters don't have one. However I am now expecting a -1 rend when NewMarines get a New marine chainsword.  But they might skip those for something better.
http://warhead01.blogspot.com/
Destroy what you enjoy!
#16
Thunder_god
Thunder_god
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,047 posts
  • Gender:Male
  • Chapter Name: Vlka Fenryka
Looks like all those powers word armed vet sgts I like to model have become really useful!
#17
Marshal Loss
Marshal Loss
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,420 posts
  • Gender:Male
Pretty cool, I like.
The Unblinking Eye
A blog about 30k & the Sons of Horus 29th Company
#18
Black Cohort
Black Cohort
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,070 posts
  • Gender:Male
  • Chapter Name: Black Cohort
Why would vanguard switch out to chainswords? I would much rather have a power weapon than a chainsword. What we will likely see more off is vanguard with special pistols, particularly if gunslinger is still a thing.
And I would much rather have powerfists hit on 4+ than hit last. Though I was hoping for better damage or AP.
Follow the link to help make "A Better 40k"<p> http://www.bolterand...types-finished/
#19
Guiltysparc
Guiltysparc
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,223 posts
  • Gender:Male
I don't see how you came to any of these conclusions, lol.  A flat 6 damage from the knight weapon is brutal.  A knight is going to be hitting on 3s or 4s, wounding on 2s and 3s, and throwing 6 damage per wound.  Its going to wreck whatever it hits.  Powerfists were already hitting on 4s most of the time and now they don't go last and do multiple damage per hit, its a huge buff.
  • Valerian, Venomlust, Irbis and 7 others like this
  My Legio XII Project Log
#20
Deus Ex Ferrum
Deus Ex Ferrum
  • 4,691 posts
  • Gender:Male
They didn't, but they haven't mentioned it in any of these articles.  Plus, the fact that you get to shoot pistols in CC speaks against it.
#21
Sete
Sete
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 5,837 posts
  • Gender:Male
  • Chapter Name: Black Templars/Grey Talons
Cawl pattern chainsword.
Btw will the forum name change to Rifle And chainsword? 😉
Edited by Sete, 19 May 2017 - 02:15 PM.
  • uberwolve, Flame Boy, Megalodon and 5 others like this
#22
CommodusXIII
CommodusXIII
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,409 posts
  • Gender:Male
With the new Strength versus Toughness balance, power swords aren't at such a disadvantage for wounding as they are currently.  The trade-off of S for AP of the various power weapons is very flavorful, and in the grand scheme of things none seem to be auto-includes and none seem to be garbage.  That's how you encourage fluffy army building.
  • Antarius, Kierdale, Sete and 2 others like this
#23
Guiltysparc
Guiltysparc
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,223 posts
  • Gender:Male
Yep, i feel like the power sword is a definite winner here for most marines given the new damage table.  The +S weapons maybe seeing more use on higher strength models?
  • Lexicanum likes this
#24
Race Bannon
Race Bannon
    ++ MUNUS SPECIALIS AGNITIO ++
  • ++ MODERATI ++
  • 6,649 posts
  • Gender:Male
  • Chapter Name: Raven Guard
THANK YOU GW OMG
  • CommodusXIII, KiltedMarine, wildweasel and 2 others like this
"Fully dressed in the ancestral Terminator Armour of their Chapter they rise to a new level of battlefield supremacy, a level where monstrous tanks are but playthings of a child, and where Terminators, Daemons and gods stalk as equals." -Thunder and Lightning, White Dwarf 116 (UK)
gallery_6494_6331_1745.gif gallery_6494_11942_9573.png gallery_6494_6331_4817.pnggallery_6494_6331_16668.jpggallery_6494_6331_8260.png
Index Astartes: Red Shoulders
#25
Imeran
Imeran
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 426 posts
  • Gender:Male
Assuming the Imperial Knight has as many attacks as a Morkanaut (ballpark: 4-5 before degrading) it's possible but not guaranteed that he can still one-shot said Morkanaut with 3 hits that go past the save. So, while no longer a D-Weapon, the Reaper remains very scary!
  • CommodusXIII, uberwolve and Sugarlessllama like this
