BT and IG: Yarrick and Helbrecht's Wild Party
1 reply to this topic
#1
HenricusTyranicus
HenricusTyranicus
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,324 posts
Apologies, mods, since this is a list with units from two factions, I'll be double posting this in both the Astra Militarum section and the Marines section.
In 7th edition I ran BT and guard together, and that's a combo I'd like to see keep going, especially as my guard are painted in Templar colors. It's a little harder with higher vehicle costs, but a little easier with the keyword Imperium. Anyway, here's what I've got.
EDIT: I suppose I should mention this is a 2000 point list :P
Double Battalion detachment for 6 HQs, 6 Troops, and a total of 9 command points.
Helbrecht 170
Pask in executioner with lascannon, storm bolter, and plasma cannon sponsons 249
Tank Commander in Punisher with lascannon, Heavy stubber, and heavy bolter sponsons 227
Company commander 30
Yarrick 130
Crusader Squad 9 initiates, 1 SB, 5 Neophytes. 2 power swords, plasma gun 206
LRC With multimelta, storm bolter, and hunter killer missile 312
Guardsmen squad, Heavy bolter, plasma gun 55
Conscripts 50 man squad 150
Manticore Hunter killer missile 139
Wyvern 99 Hunter killer missile
Commissar 31
Basic battle strategy is composed of several waves. The first wave shall be all the Templars in the Land Raider, charging forward. The Second wave, a conscript line, guarded by a commissar, with Pask and the other Tank commander chilling nearby them. Third Battle line, the guardsmen squads, all set up in range of Yarrick buff bubbles. The company commanders will roam about, issuing orders where needed. The final line will be the Manticore and the Wyvern, ideally also in range of Yarrick's buffs, wut it isn't the end of the world if they aren't.
In the event I'm facing a foe with heavy deepstrike, I can sacrifice getting some troops into Yarrick's bubble in order to make sure that no one can deepstrike more than 9 inches away, unless they do so outside my lines.
Edited by HenricusTyranicus, 07 June 2017 - 08:15 PM.
8th edition win-lose record.
Win-Lose-Draw
  3-2-0
#2
WarriorFish
WarriorFish
    ++ PRÆFECT SOCIORUM ++
  • +++ADMINISTRATUM+++
  • 23,479 posts
Theory looks good, as there's plenty of models on the table which sounds solid. It's also a good point on deep striking - due to the limitations it's entirely possible to prevent anyone deep striking where you don't want then ;)
gallery_48988_15465_8206.pnggallery_30308_9518_1551.pnggallery_30308_3239_3185.pnggallery_30308_9518_17558.pnggallery_30308_3239_193.pnggallery_30308_3239_17729.png
Painting Oaths Completed:
gallery_30308_3239_28.gifgallery_30308_3239_28.gifgallery_30308_3239_102.gifgallery_30308_3239_84.gifgallery_30308_3239_42.gifgallery_30308_3239_102.gifgallery_30308_3239_102.gifgallery_30308_3239_102.gifgallery_30308_3239_102.gifgallery_30308_3239_42.gifgallery_30308_3239_28.gifgallery_30308_3239_102.gifgallery_30308_3239_42.gifgallery_30308_3239_102.gifgallery_30308_3239_102.gif
In the grim predictability of online 40k, there can be only Sun Tzu quotes
SM Ironclad | IG Stormies | =][= Stormies | AM Armigers
CSM Executioner | TSons Infernal Master | Daemons Daemonettes
DE Warriors | Tyranids M'neh the Neurothrope
