Rot Tide - 2000pts Death Guard
No replies to this topic
#1
Warmaster Phthisis
Warmaster Phthisis
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 76 posts
2000pts - Rot Tide
Battalion Detachment 1 - 3CP
HQ
Typhus        175
Miasma of Pestilence, Putrescent Vitality
Malignant Plaguecaster        110
Blades of Putrefaction, Miasma of Pestilence, The Suppurating Plate
Elites
Noxious Blightbringer        70
Blightlord Terminators x5        310
5x combi-melta, 5x Bubotic Axe
Troops
Plague Marines x7        196
Plague Champ - Plasma Pistol, Power fist, Plague Knife
2x Flail of Corruption
4x Bubotic Axe & Plague Knife
Rhino        72
combi-bolter
Plague Marines x7        181
Plague Champ - Plasma Gun, Plague Sword
2x Meltagun & Plague Knife
4x Boltgun & Plague Knife
Rhino        83
combi-bolter & combi-flamer
Poxwalkers x20        120
Heavy Support
Plagueburst Crawler        156
Plagueburst Mortar, Heavy Slugger, 2x Entropy Cannons
Battalion Detachment 2 - 3CP
HQ
Terminator Sorceror        175
Combi-Melta & Force Axe
Warptime, Prescience
Warpsmith        76
Troops
Chaos Cultists x10        40
The Battleplan
The namesake of this list is a formation that takes advantage of the "The Dead Walk Again" strategum.  The Rot Tide is a deathball with a unit of 20 Poxwalkers screened very tightly by 3 squads of cultists geared for assault and accompanied by Typhus and the Noxious Blightbringer.  Each turn I'll spend 1CP on "The Dead Walk Again" for the Poxwalkers and another 1CP for "Cloud of Flies" to prevent my opponent from attacking the Poxwalker core.  The cultists will be packed tight in front of a spread out Poxwalker unit to make sure that any cultist slain is slain within 7" of a Poxwalker model.  These slain Cultists add to the Poxwalker horde.  The Noxious Blightbringer will allow the whole deathball to advance at a faster clip, averaging about 8" per turn.  Typhus is pretty self-explanatory.
Although low-quality and expendable troops, the horde must be dealt with in some way.  However my opponent decides to handle them I can turn it to my benefit.  An enemy who decides to focus their firepower on the Rot Tide will have to be killing cultists, which then will give me almost 30 more Poxwalkers.  Typhus' buff to the unit can then be increased with Putrescent Vitality and once their cultist shield is gone they can be protected with Miasma of Pestilence.  A horde of roughly 50 S5 T5 Poxwalkers barreling down on you is obviously a bigger problem than 20 Poxwalkers with 30 Cultists.    However if they choose to ignore the Rot Tide and focus on the rest of my army, I'm going to be very disruptive with my cultist squads and, again, a squad of 20 S5 T5 Poxwalkers with Typhus.  With such a slow-moving horde, the obvious counter strategy is to redeploy away from them, which depending on the mission and army could cede objectives and could play into a Hammer and Anvil overall strategy with the other mechanized portion of my army.   I'd expect to expend between 5 and 8 CP out of my 9 on this formation.
The Terminator Sorceror will probably teleport in with the Blightlord Terminators, casting Warptime & Prescience on them so they can get into melta range with their combi-meltas.  This is a unit that can destroy a piece of heavy armor in one turn if they've left me enough room to teleport in.  With their added staying power, a squad of Blightlords with an accompanying Sorceror is another big problem for my opponent.
Plague Marines in Rhinos do what Plague Marines in Rhinos do.  The Malignant Plaguecaster will climb into the Rhino with the Plague Marine assault squad and support them.  The Plague Marine squad with Meltas are good all-rounders when supported with the Rhino with a combi-flamer.  These two units will advance and engage the enemy while their Rhinos make a nuisance of themselves.
The Plagueburst Crawlers will be accompanied by the Warpsmith.  PBCs are already tough as nails, but with a Warpsmith fixing them up that's even more true.  I'll advance these tanks up so they present an additional target for the enemy and make sure the Entropy Cannons are in range.  The Entropy Cannons are the real armament on these things.  The Plagueburst Mortar can deal a heavy blow occasionally but there are too many dice rolls in the way to make it reliable.  The remainder of my CP will probably be spent re-rolling 1's for the number of shots I get on the Mortars and possibly a good volley of Blight Grenades off the PM assault squad if the opportunity presents itself.
Alternate choices could be to drop the Warpsmith and take an Apostle to keep me from losing cultists to morale as the ones that run away don't come back as Poxwalkers.  I could also take a regular Chaos Lord to put with the Rot Tide, the Plague Marines or the PBCs.   I could swap out the Meltas in my PM squad and put in Blight Launchers instead and use them as a shooty fire-support unit, and replace the combi-flamer with a Havoc launcher on their Rhino.
My concerns with this list revolve around the Rot Tide either getting killed before they reach the enemy, or being too slow to reach the enemy.  There are armies out there that I know can burn through this formation in a couple of turns of focused fire, or at the very least render it far less effective.  That's going to take about 600 lasgun shots on average to do, or 420 bolter shots. But if they do focus on the Rot Tide, then at least that's shooting that isn't going to the rest of my army.  An enemy being able to avoid it entirely is my biggest concern.  In those instances I'll have to try to use my mechanized Plague Marines to pin them down before I can land my hammer blow.
Any comments or criticism would be greatly appreciated.
-WP
Edited by Warmaster Phthisis, 23 September 2017 - 05:32 AM.
Knowledge is power, power means responsability, responsability requries sacrifice, sacrifice is pain.
Be thankful for the many things that you do not know, for it is the things you do not know that allow you to get to sleep at night.
