1500pt List (Catachan)
10 replies to this topic
#1
patchestheclown
patchestheclown
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 160 posts
Hey all, so I've loved guard forever (first introduction to 40k was a box of catachan jungle fighters back in 1999) however I just started collecting models for an army in the last few months of 7th edition. It turned out to be a great time to start collecting models and then with the sneak peeks of the codex, I got so excited that my catachans would actually have stuff to make them more awesome!
So far I've gotten 2 defense forces and 2 basilisks (plus some older models). I have every model (except the psyker) in this list WYSIWG.
Battalion - (Catachan)
Commander - Bolter & Chainsword, Aquila
Commander - Boter & Power Sword, (possibly catachan relic)
3x Infantry Squads - vox, autocannon, sarge has bolter
Heavy Weapons Squad - 3x mortars
Commander - Bolter & Power Fist
Primaris Psyker - Psychic Barrier & Nightshroud
Infantry Squad - vox, autocannon, sarge has bolter
2x Infantry Squad - autocannon, sarge has bolter  (no vox's here for points reasons)
Veterans - 6 shotguns, 3 meltas, sarge has bolt pistol
Chimera - Heavy Flamer, Multi-laser (veterans go in here)
Spearhead - (Catachan)
Tank Commander - Punisher, triple heavy flamers
2x Basilisks - heavy bolter
2x Leman Russ - battle cannon, triple heavy bolters
1500pts exactly, 10CP total
Probably not the most competitive list but should be a blast to play with friends. Any suggestions?
Edited by patchestheclown, 18 October 2017 - 05:57 PM.
#2
BurntheHeretic
BurntheHeretic
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 71 posts
Looks like a good start, with a lot of heavy firepower!
Are you still able to switch weapons on your vehicles? The multilaser is rather weak this edition, you may want to switch it with a heavy bolter (slightly cheaper with the same damage output, buys you an additional storm bolter) or a second heavy flamer.
Also, I would make one of your Battle Cannon Russes a Tank Commander instead of the Punisher, because the heavy flamers don´t benefit from the BS3+ of the Tank Commander.
As to the use of heavy flamers with a Leman Russ, I am doubtful about their effectiveness. I love the idea of a Flamer Russ. But the main gun can only fire twice if the Russ moves half speed or less, whilst Heavy Flamers need to get close to the enemy fast.
You have three commanders for 6 infantry squads. Each commander should be able to remain within 6´´ of two infantry squads. So the vox may not be all that necessary. Removing the vox casters would give you the points to wield a platoon commander, which could be a good addon for the veteran squad.
#3
Halfpint100
Halfpint100
    ++ EXEMPLUM CONVECTORIS ++
  • ++ MODERATI CEDO ++
  • 1,224 posts
Good points from Burntheheretic above!
I want to also echo the heavy flamers. you have heavy flamers on battlecannon russes. They do not want to get close. Heavy bolters would be better.
Changing to heavy bolters would give you many points. removing the voxs as well would give you enough points to get another primaris psyker. They are great! I run 3 at 1500 points, with an astropath. Cheap psykers is something guard do well.
#4
patchestheclown
patchestheclown
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 160 posts
Thanks for the feedback,
I would love to give the chimera double heavy flamers just gotta come up with the points.
I keep going back and forth with the vox's part of me loves em the other part of me thinks they are a waste. In a few games I've played they have done absolutely nothing except in turn 5 when in a mad dash for objectives one squad who rolled 6" for advancing the turn before was out of range of orders, except for the vox caster!! But overall they probably aren't worth it.
Tank Commander, I originally had him with a main battle cannon to hang back with his buddy to always have someone to give orders to but now with the codex tank commanders can order themselves and in my mind nothing says catachan like leading from the front, hence the punisher and triple flamers, and 3+ with 20 shots is tasty. I'll play test it a bit but I know the smarter option is probably the battle cannon. OR I could give him a demolisher cannon for the ultimate distraction carnifex XD
I'll try dropping the vox's and take a platoon commander for the vets and try to scrape up the points for another heavy flamer for the chimera
thanks again for all the feedback!
#5
BurntheHeretic
BurntheHeretic
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 71 posts
On the Tank Commander, I feel you. It might not be the most points effective, but a triple Heavy Flamer Russ leading the assault is menacing! You could always make the triple H.B. Russ your tank commander, effectively switching 2 Russes, and ensuring the BS 3+ of the tank commander doesn't go to waste. For a mere 2 points, a storm bolter may also be a good addition to the close assault LR.
But then, Hellhounds basically have triple heavy flamers, with better range, so if you are up to roasting your enemies you may want to include one as you expand your list!
Edited by BurntheHeretic, 18 October 2017 - 06:49 PM.
#6
patchestheclown
patchestheclown
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 160 posts
Alright, revamped the list a bit. Finishing up painting 15 guys and 2 tanks and then I gotta base em all but then ill have a fully painted army!! (first time that's ever happened lol) I'm not sure if battlescribe changed some of the points but even getting rid of the voxs per suggestions didnt save me as many points as I thought... thanks for all the advice, excited to get on the board and play some of my friends. Any suggestions on what to get next to get it up to 2000 points?
Battalion Detachment <Catachan>
HQ
- Company Commander, bolter, chainsword Aquila (Warlord)
Troops
- Infantry Squad, autocannon, sarge with bolter
Elites
- Veteran Squad, 3x melta, 6x shotguns, sarge with bolt pitsol
Dedicated Transport
- Chimera, Heavy Bolter & Heavy Flamer
HQ
- Company Commander, Power Fist, shotgun
- Primaris Psyker (Nightshade & Psychic Barrier)
Troops
Heavy Support
- Heavy Weapons Team, 3x mortars
Spearhead Detachment <Catachan>
HQ
- Tank Commander, Punisher, 3x Heavy Flamer
Heavy Support
- Basilisk, heavy bolter
- Leman Russ Battle Tank, battle cannon, 3x Heavy Bolter
10CP, 1500 points
#7
vilainlivesmatter
vilainlivesmatter
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 24 posts
If I could make one change it would be to drop the 3heavy flamers for a Lacannon and plasma sponsons.
#8
patchestheclown
patchestheclown
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 160 posts
really why? Since the commander is a punisher I'm gonna want to be within 24" so that means moving meaning these sponsons will be hitting on 4's on the move. Would spending the points for las/plasma be worth it? I could always make one of the basic leman russes the commander with this set up i guess
#9
Halfpint100
Halfpint100
  • 1,224 posts
Personally I find if my battlecannon russes are within heavy flamer range, i have done something VERY wrong. you have infantry to screen so they don't get charged. I would change them all to heavy bolters (saving you 9 points a flamer, x9 = 49 points) Maybe for another infantry squad, another psyker, maybe more mortars? options are endless!
#10
patchestheclown
patchestheclown
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 160 posts
Only the Tank Commander has triple heavy flamers to combo with the punisher cannon (and cause its badass!), the other 2 russes with battle cannons have triple heavy bolters
#11
Altasmurf
Altasmurf
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 313 posts
While I agree that the heavy flamers on the punisher is probably not the most efficient it is awesome and very catachan like. Guard are so cheap and efficient that you can take fun options like that. As long as your core is solid, which it is, you can take some more fun type units. Also with the proliferation of -1 to hit appearing out there I feel autohitting is going to become more useful.
