Tactical Reserves
Beta Rules Tactical Reserves Deep Strike
  • Please log in to reply
96 replies to this topic
#76
Eddie Orlock
Eddie Orlock
    ++ FRATERIS TEMPLAR ++
  • ++ MODERATI ++
  • 3,060 posts
  • Faction: Storm Angels
There should be some logical reason behind both the nerf and any exceptions.
Because, if it's so inconsequential, it was easier for the rule author to implement it this way. More complicated implementations take time, and time is money, and squandering money can get a public company sued if anyone can prove it. This, in the short run anyway, just induces GK players to buy more interceptors if they want to keep up.
There's logic, it's just not happy game design logic.
"Academic politics is the most vicious and bitter form of politics, because the stakes are so low."
- Wallace Sayre
The continued future of the Bolter and Chainsword is in your hands.
#77
BlackTriton
BlackTriton
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 599 posts
  • Faction: Death Guard
Different question.
Mawlocks. Terror from the Deep.
You set your mawlock up in reserves. Deep strike it turn 2.
Turn 3 you try to use its burrow ability.
Does This then kill the Mawlock as they are back in reserves at the end of turn 3?
short awnser, no.
The rules apply to units put into reserve at the beginning of the game. if your mawlock was set-up previously, he is no longer susceptible to the rule.
the rules applies to:
"Instead of being set up on the battlefield during Deployment, many units have the ability to be set up [...] in Reserve, in order to arrive on the battlefield mid-game as reinforcements."
then we rules that
"any unit that has not arrived on the battlefield by the end of the third battle round in a matched play game counts as having been destroyed"
in your example, as far as this rule is concerned, he arrived turn 2.
#78
Gentlemanloser
Gentlemanloser
    +FRATER DOMUS+
  • +EXCOMMUNICATUS+
  • 14,653 posts
The burrow rule uses the terror from the deep rule.
Which sets the mawlock up in reserves. And then they arrive later.
Burrow isn't a seperate rule.
If You have a mawlock in terror from the deep reserves end of turn 3, does it die?
QUOTE (Seahawk @ Jul 30 2011, 05:31 AM) <{POST_SNAPBACK}>
We all feel different ways about different rules, but if you're traveling between different gaming groups or to tournaments, the only commonality is the rules as they are written. If you can get your opponent to agree with you on house-ruling something then that changes things, but until then all we can do is go by how things are written.
#79
Quixus
Quixus
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 7,035 posts
  • Faction: To be decided later
But this is a bad question, a better one would be "why would strike team be another exception?"
Rules like this are written to cover the whole game and all its faction, not just the one's you like.
And that is exactly the problem with rules written like this. Only certain units deployed in reserves are problematic, but the rule applies to (nearly) all units in reserves. Now you need a lot of exceptions just to make the rule work as intended. Just limiting the offenders would have been the much better solution.
  • Kallas likes this
#80
BlackTriton
BlackTriton
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 599 posts
as far as the developer are concerned it does work as intended with only one exception with is genestealer cult.
If you mean that the rule is badly worded, then I agree. it should clearly define that it only applies to unit set in reserve before the games begin.
Unit that begin on the board and then redeploy are not exeption to the rule, even though GW had to clarify that.
It dies if he was never set up at the end of turn 3.
it does not die if he was set up before, but then used the "burrow" ability.
"burrow" is a separate rule, it just refers to "terror from the deep" to avoid repetition, a lot of rules does that.
the above interpretation is a safe bet. If you need "proof" you should send a E-mail and ask they add this clarification to the Tyranid FAQ.
furthermore, insisting that someones mawlock is dead because he borrowed on turn 3 makes you "that guy". dont be "that guy"
  • Plaguecaster and Waking Dreamer like this
#81
Gentlemanloser
Gentlemanloser
    +FRATER DOMUS+
  • +EXCOMMUNICATUS+
  • 14,653 posts
Please dont. This was the stance our tyranid player has taken with the current rules.
Burrow uses the rule Terror from the Deep.
If You use burrow you are no longer on board. You must be back in reserves. For two reasons. There's no where else you can be. And Terror places you there.
As a reinforcement, off the board, you die if not on the board at the end of turn 3.
This had nothing to do with whether you've already been set up or not.
#82
Plaguecaster
Plaguecaster
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,995 posts
Why not take that stance??, the Tyranid player sounds like he is completely right
I'd argue that it's fine and not actually destroyed since it's already arrived on the battlefield field before turn 3 because if you read the rule it states, "any unit that hasn't arrived on the battlefield by turn 3 is destroyed" it has already arrived on the battlefield so it doesn't matter, it can't be destroyed because of that rule you can burrow as much as you want with the only thing being if the game ends whilst it is still burrowing it is destroyed
Edited by Plaguecaster, 21 April 2018 - 09:27 PM.
Nurgle Abominarions: A Host of Decay Revived for 8th​.
UPDATED 29/07/17
#83
Quixus
Quixus
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 7,035 posts
The rules don't say that. what they do say is:
Any unit that has not arrived on the battlefield by the end of the battle counts as having been destroyed.
Where the unit is at the end of turn 3 is irrelevant. The only fact of importance is that the unit has arrived at some point before that time. A unit that arrived in turn 2 does not count as destroyed no matter where it is at the end of turn 3.
  • Plaguecaster and BlackTriton like this
#84
BlackTriton
BlackTriton
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 599 posts
I see where your misunderstanding is now.
You see, to assume that a unit off the board = in reserve witch = subject to the tactical reserve rule is a mistake.
To be subject to the tactical reserve rule you must begin the game off board.
This is, although I admit it is unclear, the first line of the tactical reserve rule:
The line is there to explain what unit the rule affect.
A unit that leaves the board is therefore not subject to the tactical reserve rule.
#85
Gentlemanloser
Gentlemanloser
    +FRATER DOMUS+
  • +EXCOMMUNICATUS+
  • 14,653 posts
Yeah we're mistaken here (which he'll be pleased to hear).
Burrow only says you can return as described by the terror from the deep rules.
Burrow shouldn't be effected.
  • Quixus likes this
#86
STTAB
STTAB
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 341 posts
All of a sudden Guard are the best alpha strike army.
Valkyries can transport 12 troops (or 4 ogryns)... turn 1 do a grab chute drop within 9" of enemy. Troops can then move, shoot and charge.
Plasmacide scions, one of the units that influenced the beta rule is still doable and even more effective from a Valkyrie as they can move to get in rapid fire range for plasma or re-roll damage for melta.
Valkyries start from 140 points. Toughness 7, 14 wounds.
Alternatively, 3 Valkyries, 3 inquisitors and 33 acolytes with chainswords would be awesome.
#87
Plasmablasts
Plasmablasts
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 894 posts
Alas, Acolytes are restricted six models a unit, so you can field only 18 Acolytes, not 33, in a 2000 pts game using the organised play recommendations.
#88
STTAB
STTAB
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 341 posts
Apologies, I was thinking a Vanguard could have 3 hq for some reason. A Vanguard would allow up to 36 Acolytes and 2 inquisitors.
#89
Plasmablasts
Plasmablasts
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 894 posts
Rule of Three (for organised play up to 2000 points) would restrict you to three iterations of the Acolyte datasheet, which means you are allowed up to 3 units of 6 Acolytes, so 18 max.
#90
STTAB
STTAB
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 341 posts
Thanks for the correction.
Given previous beta rules, I reckon the beta DS rule will eventually become a full rule in a diluted form.
The most likely, to me, is that the beta DS rule will eventually only apply to the army that goes first, creating more of a balance between going first/second, and choosing to go second a better option for DS heavy builds/factions. This would allow a saving of face with the concept of the beta rule standing but improving the balance between going first/second.
DS assualt armies will always have to face one round of movement/fire before being able to DS, so the opponent always has the ability to do something to counter. With the current Beta rule, a DS heavy build will struggle if they go second with 50% of their force having to stand up to 2 rounds of fire from up to 100% of the opponent's force.
Given past performance and current trajectory, this seems a logical and elegant solution.
  • BlackTriton likes this
#91
Basteala
Basteala
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 169 posts
If this restriction will stick, having Drop Pods exempt from it (for no points increase) would be a good move.
While it would be something, I think you going to have problems justifying why the drop pod can land crash outside of your deployment zone and jump packs cannot land there, but only in the first turn.
Easy. The jump packs are making a controlled descent towards the ground and are therefore limited in how fast their entry velocity can be. Enemy units could shoot them down on that first turn ,but by turn 2 are too busy dealing with approaching ground threats.
A drop pod, on the other hand, is more heavily armored, and can allow much faster entry, especially when you consider with with genetic enhancements, redundant organs, and considerable training, they can probably handle a much higher G Force rating. This lets the Drop Pod slam in, shrugging off small arms fire and moving too fast for heavy weapons to reliably lock on.
Also, if you're a shooty army, going second against a Deep Strike list with the old rules was really obnoxious. If they do ease off on the Deep Strike Rule, I hope it's akin to the penalty applying if you go first, that way the other guy isn't getting completely disrupted on his Turn 0.
Edited by Basteala, 11 May 2018 - 10:30 PM.
#92
Deathwalker
Deathwalker
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 378 posts
Funny Thing, going second against a shooty army is just as obnoxious, and does not have the random variables of making a charge either.
#93
McElMcNinja
McElMcNinja
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 402 posts
I would have been happier if they said you couldn't DS into your opponents deployment zone turn 1. I run Death Guard and still being able to DS some Deathshroud next to Mortarion after his first move would have been nice.
#94
chapter master 454
chapter master 454
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 2,907 posts
  • Faction: Angels of Justice
Unfortunately it doesn't help at all and in fact will only hurt armies that have select deep strikers, Deep Strike heavy armies WANT to go second.
While Bubbling is something that can be done, maintaining it can be difficult in an effective manner and really only horde armies can do it. Deep Strike armies do this "Go Second" because they forfeit moving but then make you effectively skip a turn of shooting. Most DS heavy armies will bring chaff and supporting units that mean little to the grander scheme of things, being purely there for rule reasons and to distract. Whether or not you shoot them is moot, if you shoot them they achieve their objective if you don't they achieve their objective. Now I come in via my Deep Strike and unleash a salvo of hellfire on you with ranged weapons and likely attempt some charges with an army you had no interaction with.
If both sides need to forfeit their first turn to gain access to the most powerful movement ability in the game then it becomes fair as now both players gave up a turn but in that proposed idea now going second is far more favourable for one army to an extreme case of becoming heavily gimped just because of chance (so now the inverse happens) and even then going second in a DS heavy Mirror match is best as it forces your opponent to blink at turn 3 if they hold off and now you have one army getting their chance to take first turn despite not having first turn.
Let me make this clear: Turn 1 deep strike is incredibly powerful beyond anyone realising here. Let me make this absolutely clear: at WORST where the enemy has bubbled their entire deployment zone perfectly, not one grot spit of space to Deep Strike into, you will still gain in effect over standard maps 15" of movement and even the more esoteric deployment maps still give MASSIVE areas to drop into round the flanks (which depending on which side you want to travel up could be anywhere up to 24" to 36" on a 6x4 table). That is a MASSIVE amount of movement for any unit to have, we are talking movement rates equalling some of the fastest skimmers in the game and we have that on units like genestealers whose main weakness is meant to be getting shot at WHICH NEVER HAPPENS because by the time you can shoot you are already jumped on, eaten and now genetic soup!
I want to know why people still think Turn 1 Deep Strike is healthy for this game? It doesn't hinder alpha strike armies (a common complaint) but instead it helps them as they make use of it the most. Getting to dump your army wherever you like turn 1 is not good design, you may as well at that point tell your opponent to not bother with deployment zones and instead alternate placing units anywhere on the board with 9" minimum between any hostile units!
I Chapter Master 454, Chapter Master of the Angels of Justice, Warboss of WAAAGH Gubskul, Commander of a Catachan Regiment, Phaeron of a Tomb World, Shas'O to a Cadre and Princeps of a lance of House Taranis hereby pledge that I will not take up any further models til all other prior have been fully built and painted to tabletop standards. There is no time limit for this task, there is no deadline. My oath is to solemnly complete the armies I have now, to see it that they can have their glory. Paint will be stripped from the old in need, thick may it be like ceramite I will see it removed so that plastic and metal alike may see light of new paint. Models yet to be, boxed and in darkness will be assembled with due care and attention. For this task I am permitted to still buy the supplies needed to do my task but not one model more.
http://www.bolterand...one-model-more/ the thread to my oath. My own reminder.
http://www.bolterand...rk-in-progress/ my own chapter
"The objective of playing a game is to win. The point of playing a game is to have fun. Never confuse the two"
#95
Kallas
Kallas
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 1,211 posts
  • Faction: Howling Griffons
Deep Strike alpha strikes aren't the problem. Alpha strikes in general are.
I've played several games with the beta rules now and I've managed to play around the beta rules and get some massive alpha strikes in regardless using flyers, Blood Angels Scouts, non-DS Jump Pack units and Upon Wings of Fire (Blood Angels stratagem).
In the games I've played I've managed to go first every time (which is skewed, of course). Regardless; not being able to deep strike turn one made no difference, as in those games I demolished huge portions of my opponents' armies before they could react.
Two notable examples for their brutality, using this army:
Blood Angels
Captain (JP, Thunder Hammer, Storm Shield)
Librarian (JP, Wings of Sanguinius)
Lieutenant (Veritas Vitae)
2x Stormhawk Interceptors
Stormraven
3x Predators (Predator Autocannon, Heavy Bolters)
3x 5 Scouts
2x 3 Inceptors (1 Bolter, 1 Plasma)
vs Guard:
Spoiler
Second game example:
Spoiler
Now, both of those would certainly have been different if my opponents had gone first. My Scouts would almost certainly get obliterated; my Predators would likely get hurt, maybe losing one (Necrons were definitely light on AV fire) and the Guard would've had Scions ready in their second turn.
But the point is that my alpha strikes came with little hindrance due to the beta rules, and those rules actually shut out my Guard opponent's possible comeback by denying him the ability to retaliate.
Something certainly needs tweaking about the game, but it's about alpha strikes in general, not deep striking in general. Maybe they are intertwined, but nerfing deep strike doesn't really curtail alpha strikes, as that's a much larger issue.
  • Quixus and Soder like this
#96
Morticon
Morticon
    ++ FILIUS VINDICOR ++
  • ++ MODERATI ++
  • 13,943 posts
Responding to Chapter Master 454;
I cant answer this from the perspective of other lists and other armies, only from a SM perspective. So, the thoughts and comments are largely in relation to them, despite some concepts applying across the board.
As a BA player I was massively gimped with the tactical reserve rule.  At the start of 8th I was getting absolutely CANED by shooting armies.  The way 8th is designed, and the way that cover works, as well as AP, means that marines are at a massive disadvantage.  Lists at start of 8th were monstrously alpha shooty.
The ONLY chance I had to mitigate this, was to deploy into reserve, and spare some of my better units a turn of shooting against them, while the rest of my forces were shot at for one turn.
Now, not only do i potentially need to weather 2 turns of shooting, I can't mitigate the units that put out the most damage either.  I have to deal with screens or die.
Added to this, Screens/Bubbles at the start of 8th were just as problematic as they are now- but at least you could get in in turn one (and as a BA, where you're attempting to charge, you still have to get a 9" charge for most of your units...)
None of this was game changing or game-breaking for marines.   Decent placement and average luck was all that an opponent needed.
Maybe my meta missed the massive devastation that was first turn deep striking alphas.   And I dont mean that facetiously.  I mean that honestly- It's possible the competitive gaming group I played with just missed the builds that terrified the developers into nerfing this tactic (and thus a legitimate alternative to shooty alpha).
But, yeh...drop pods with massively average payloads coming down in turn 2 only, jump pack marines that only deployed in turn two, and were pathetic in combat....didnt really see how any of this was problematic.  All it did was give a little bit of tactical flexibility and list viability to a broader range of players/list styles.
  • Quixus and Kallas like this
Gamist, cheesy, beardy or broken; If Games Workshop put it in the book I'll gladly play against it, or with it. - Mort
"Use soft words and hard arguments." (Henry George Bohn [1796-1884].)
There is no harm in, on occasion, having disagreements. It's another thing entirely, however, to be a tool in conveying that disagreement.
"OP: The term used by players to describe a combination of yours they are personally unable to beat"
Collection of Battle Reports
Corbulo Tactica
#97
STTAB
STTAB
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 341 posts
First turn survival is still an issue, especially to crazy shooting.
I went second to Orks this week. 6 Traktor Canons, 23 lootas and relic shokk attack gun.
Running Vigilus Scions drop force.
Used prepared positions to get my 4 T7, 14w, -1 to hit flyers to a 2+ save, deployed in corners to stay out of range.
Lost 2 valkyries, a vulture and the remaining Valkyrie had 6 wounds left.
Game was over at that point with scions trapped in corners and Orks swarmed over 2/3 of the board.
On average I should have lost 1-2 of the flyer, but those are the dice.
What I'd love to see is a once per game universal stratagem to give a unit a 4+++ (excluding titanic/super heavy). Call it divine protection or something.
At least on those bad matchups it could help keep you get out the gate and make a game of it, same for one time protecting key character now sniping is more powerful.
Personally I'd like to see deep strike enabled for battle round 1, for the player going second.
Also tagged with one or more of these keywords: Beta Rules, Tactical Reserves, Deep Strike
