2000pt AdMech Brigade
  • Please log in to reply
8 replies to this topic
#1
Warsmith Manat-Yi
Warsmith Manat-Yi
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 121 posts
I'm planning on jumping full-force into admech now that the new FAQ is out. They're looking a lot stronger and I feel like a brigade is far more attractive. I absolutely ADORE Sydonian Dragoons and have been itching to run them as a screen with Styges. I'm not so sure about the infiltrators, but they're ok to fill the elites slot for now. Thoughts?
++ Brigade Detachment +12CP (Imperium - Adeptus Mechanicus) [111 PL, 1999pts] ++
+ Uncategorised +
Forge World: Stygies VIII
+ HQ +
Tech-Priest Dominus [7 PL, 127pts]: Omnissian Axe, Phosphoenix, Volkite Blaster
. Warlord: Monitor Malevolus
Tech-Priest Dominus [7 PL, 125pts]: Macrostubber, Omnissian Axe, Volkite Blaster
+ Troops +
Skitarii Rangers [4 PL, 85pts]
. 2x Ranger (Transuranic Arquebus): 2x Transuranic arquebus
. Ranger Alpha: Galvanic rifle
. 2x Skitarii Ranger
Skitarii Rangers [4 PL, 35pts]: 4x Skitarii Ranger
+ Elites +
Cybernetica Datasmith [3 PL, 44pts]: Gamma pistol, Power fist
Sicarian Infiltrators [6 PL, 110pts]
. Infiltrator Princeps
. . Flechette blaster & Taser goad: Flechette Blaster, Taser goad
. Sicarian Infiltrator
+ Fast Attack +
Sydonian Dragoons [12 PL, 272pts]
. Sydonian Dragoon: Taser lance
Sydonian Dragoons [3 PL, 68pts]
+ Heavy Support +
Kastelan Robots [12 PL, 220pts]
. Kastelan Robot: Heavy Phosphor blaster
. . Heavy phosphor blasters: 2x Heavy Phosphor blaster
Onager Dunecrawler [7 PL, 140pts]: Broad Spectrum Data-tether
. Neutron laser & cognis heavy Stubber: Cognis heavy stubber, Neutron Laser
++ Total: [111 PL, 1999pts] ++
Created with BattleScribe
#2
Clingy
Clingy
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 494 posts
Given the CP increase to 5 for battalions it actually makes sense it avoid the tax and stack battalions rather than go for a brigade.
I would increase dakabots to at least 4. Take Cawl. Get rid of the extra 2 individual dragoons and the data Smith. Maybe ace some of the Rangers squads and depending what other models you own maybe add in something else. Dragoons are awesome so if you have enough points left over feel free to increase that squad of 4 to a 5.
Would need to work out the points but you get the idea
#3
Clingy
Clingy
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 494 posts
I would probably do something like this. But really dependent on what models you’ve got.
++ Battalion Detachment +5CP (Imperium - Adeptus Mechanicus) [124 PL, 1998pts] ++
+ Uncategorised +
Forge World: Mars
+ HQ [26 PL, 459pts] +
Belisarius Cawl [13 PL, 240pts]
Tech-Priest Dominus [7 PL, 125pts]: Macrostubber [2pts], Omnissian Axe, Volkite Blaster [8pts]
Tech-Priest Enginseer [3 PL, 47pts]: Autocaduceus of Arkhan Land, Omnissian Axe, Servo-arm [12pts]
Tech-Priest Enginseer [3 PL, 47pts]: Omnissian Axe, Servo-arm [12pts]
+ Troops [33 PL, 249pts] +
Skitarii Rangers [4 PL, 35pts]: 4x Skitarii Ranger [28pts]
. Ranger Alpha [7pts]: Galvanic rifle
Skitarii Vanguards [7 PL, 48pts]: 5x Skitarii Vanguard [40pts]
. Vanguard Alpha [8pts]: Radium Carbine
+ Elites [12 PL, 220pts] +
Sicarian Infiltrators [12 PL, 220pts]
. Infiltrator Princeps [22pts]
. . Flechette blaster & Taser goad [6pts]: Flechette Blaster [2pts], Taser goad [4pts]
. 9x Sicarian Infiltrator (Flechette/Taser) [198pts]: 9x Flechette Blaster [18pts], 9x Taser goad [36pts]
+ Fast Attack [15 PL, 340pts] +
Sydonian Dragoons [15 PL, 340pts]
. Sydonian Dragoon [3 PL, 68pts]: Taser lance [9pts]
+ Heavy Support [38 PL, 730pts] +
Kastelan Robots [24 PL, 440pts]
. Kastelan Robot [110pts]: Heavy Phosphor blaster [15pts]
. . Heavy phosphor blasters [30pts]: 2x Heavy Phosphor blaster [30pts]
Onager Dunecrawler [7 PL, 145pts]: Cognis heavy stubber [5pts]
. Neutron laser & cognis heavy Stubber [50pts]: Cognis heavy stubber [5pts], Neutron Laser [45pts]
++ Total: [124 PL, 1998pts] ++
Created with BattleScribe (https://battlescribe.net)
Ok that came out weird, was supposed to be 2 battalions. One mars with an infiltrators bomb of 10. And your heavy castle.
Then a stgyies batallion housing your dragoons etc.
#4
Warsmith Manat-Yi
Warsmith Manat-Yi
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 121 posts
That's not bad. I'm not a huge fan of the robots though to be honest. They can put out an incredible amount of fire, but I would probably drop a bot or two and run three onagers. Still an excellent suggestion.
Also, why vanguards over rangers? I get that the guns are a bit better, but the rangers are cheaper and that's all I really care about. It isn't like their firepower will be game-changing.
#5
Clingy
Clingy
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 494 posts
Well just in case your playing new beta rules. The rule of 3 prohibits stacking multiples above 3 of the same data sheet. It’s a beta rule and probably only tournaments etc will stick to it. = 3s the max
If your not a fan of the robots then I would go fully stygies and ditch Cawl. The robots is the driving force behind them. Tbh it really depends on what you want to do. If you just want to have fun then play what you like. If your wanting a more competitive build then you might want to tweak things slightly.
Infiltrators aren’t very good comparatively to other units but they are fun and if you did take them in a mars detachment then you can use wrath of mars stratagem to put out some surprise mortal wounds.
#6
Clingy
Clingy
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 494 posts
Rvd1ofakind from Dakaka once said
“Our units from best to worst.
Cawl
DakKastelans
Dragoons
Onagers
<gap>
skitarii
<gap>
others
<gap>
destroyers
ruststalkers
<gap>
servitors”
That seems to be roughly the consensus regarding effectiveness
#7
Warsmith Manat-Yi
Warsmith Manat-Yi
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 121 posts
Cawl
DakKastelans
Dragoons
Onagers
<gap>
skitarii
<gap>
others
<gap>
destroyers
ruststalkers
<gap>
servitors”
Don't get me wrong, I understand how good the robots are, I just prefer an onager to a couple bots. Mind you, I'm not building any new army until the knights book drops. If they're good I'll play them with admech support, but if they suck I'll run a list similar to yours.
#8
Clingy
Clingy
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 494 posts
This is the one one working towards.
I don’t have all the models but this is the list I will probably try if I’m playing to win such as entering a tournament.
++ Battalion Detachment +5CP (Imperium - Adeptus Mechanicus) [62 PL, 1059pts] ++
+ Uncategorised +
+ HQ +
Tech-Priest Dominus [7 PL, 127pts]: Omnissian Axe, Phosphor Serpenta, Volkite Blaster
Tech-Priest Enginseer [3 PL, 47pts]: Omnissian Axe, Servo-arm, The Omniscient Mask
+ Troops +
+ Elites +
Fulgurite Electro-Priests [16 PL, 288pts]: 18x Fulgurite Electro-Priest
. 9x Sicarian Infiltrator (Flechette/Taser): 9x Flechette Blaster, 9x Taser goad
+ Fast Attack +
++ Spearhead Detachment +1CP (Imperium - Adeptus Mechanicus) [51 PL, 940pts] ++
+ Uncategorised +
Forge World: Mars
+ HQ +
+ Heavy Support +
Onager Dunecrawler [7 PL, 130pts]: Broad Spectrum Data-tether, Icarus Array
++ Total: [113 PL, 1999pts] ++
#9
Clingy
Clingy
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 494 posts
And this is the one I will mostly play for fun and uses rule of cool. Based on models I liked the look of.
++ Battalion Detachment +5CP (Imperium - Adeptus Mechanicus) [88 PL, 1488pts] ++
+ Uncategorised +
Forge World: Mars
+ HQ +
+ Troops +
Skitarii Vanguards [4 PL, 40pts]: 4x Skitarii Vanguard
. Vanguard Alpha: Radium Carbine
+ Elites +
+ Fast Attack +
+ Heavy Support +
++ Super-Heavy Auxiliary Detachment (Imperium - Imperial Knights) [27 PL, 512pts] ++
+ Lord of War +
Knight Crusader [27 PL, 512pts]: Avenger gatling cannon, Heavy flamer, Heavy stubber, Thermal cannon
++ Total: [115 PL, 2000pts] ++
I’m excited for the knights codex. Hopefully some fun toys to come :)
