1000 doubles tournament
  • Please log in to reply
3 replies to this topic
#1
Sandviper
Sandviper
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 141 posts
Potentially cheese heavy list ahead. Spearhead detatchment
Winged prince, talons, revolting resilient, supp plate, miasma of pestilence or blades of putrefaction
1 spawn
Contemptor dread, dual butcher, havoc launcher
Crawler, spitter and slugger
Leviathan dread, dual butcher array, 2 hellflamer
Basically going to march up the board and shoot at whatever needs murdered. Probably going to miasma my leviathan. If facing hordes, probably putrifaction
#2
BlackTriton
BlackTriton
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 615 posts
  • Faction: Death Guard
Blades wont be much help against hordes,
Remember you only get the mortal wounds on melee Plague weapon, wich you have none.
Meanwhile, miasma get better the more dices goes into it, its the obvious choice here in almost all match-up.
Otherwise, its a pretty nice list. What's your plan to not get locked in melee? That looks like the obvious weakness here, the lack of screening unit.
#3
Sandviper
Sandviper
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 141 posts
Ah touche on the blades part. Forgot it was a plague weapon. Hopefully not get into combat if I can help it. I could also run the contemptor with a claw/helflamer with a single butcher to help in melee.
I can probably use my partner to run screens or just get into melee as he is going to be using Space Marines as his army and running an elite list.
If I recall he is running 2 vanguards:
Captain w/ thunder hammer plas pistol,
Contemptor with Khebris / fist combi bolter,
tartoros terminators w/ 4 fists and combi bolters, power sword and plasma blaster on the sarge,
special issue ammo Sternguard w/ fist on sarge;
Lieutenant,
Imperial marine,
special issue ammo sternguard w/ fist on sarge,
Sicaran w/ Heavy bolters sponsons
Edited by Sandviper, 03 December 2018 - 02:55 PM.
#4
Sandviper
Sandviper
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 141 posts
Thanks to CA I decided to edit my list a little bit. March of the dreads incoming:
DG Vanguard Detatchment
Winged DP of Nurgle, dual talon, Fugaris Helm, miasma, revoltingly resilient
Unit of 3 spawn
Nurgle contemptor, Deathclaw w/ extoplasma blaster, butcher cannon
Nurgle contemptor, Dual butcher cannon, havoc launcher
Nurgle Leviathan dread, 2 hellflamers, butchercannon array, siege claw w/ meltagun
Basically walking forward, shooting whatever, keeping miasma on the leviathan and then other dreads when the leviathan inevitably dies. My partner's list now has 72 points available so he may revamp his list.
