2000 points of fun against Dark Angels!
#1
Posted 05 January 2019 - 05:39 AM
T'au Empire Sept Choice: Bork'an Sept
HQ
Cadre Fireblade
Cadre Fireblade
Troops
Strike Team
. Fire Warrior Shas'ui: Markerlight
. 4x Fire Warrior
Strike Team
. 4x Fire Warrior
Strike Team
. 4x Fire Warrior
-Super-Heavy Auxiliary Detachment
KV128 Stormsurge 2x Burst cannon, Advanced targeting system, Cluster rocket system, 4x Destroyer missile, Pulse driver cannon, 2x Smart missile system
-Vanguard Detachment +1CP
HQ
Commander in XV86 Coldstar Battlesuit 4x Fusion blaster
Elites
XV8 Crisis Battlesuits
. Crisis Shas'ui: 2x Plasma rifle
XV95 Ghostkeel Battlesuit 2x Burst cannon, Cyclic ion raker, 2x MV5 Stealth Drone, Shield generator, Target lock
T'au Empire Sept Choice: Sa'cea Sept
HQ
Ethereal Honour blade, Puretide engram neurochip
Elites
Firesight Marksman
Firesight Marksman
Firesight Marksman
-Outrider Detachment +1CP
HQ
Commander in XV86 Coldstar Battlesuit 4x Fusion blaster Warlord: Seeker of Perfection or Precision of the Hunter
Fast Attack
Tactical Drones 4x MV1 Gun Drone
-Spearhead Detachment +1CP
HQ
Heavy Support
XV88 Broadside Battlesuits
. Broadside Shas'ui: 2x Smart missile system, Heavy rail rifle
12 CP 1999 points
This is a list I'm going to be using against a Dark Angel's army. I intentionally did not take a riptide. Figured I would try something different. I am unsure about which warlord trait I should use. There may be another thread entirely dedicated to this topic, which I will definitely look for, but I'm not sure which trait is more efficient. I'm positive they both have their own strengths but I can't be certain which one would be a more versatile option. Anyways. I will be posting some pictures of this army either on this thread or a different one. I will also post the Dark Angel's list on this thread just for a little deeper analysis. Let me know what you guys think! The goal is really just to have fun. Thank you guys!
#2
Posted 10 February 2019 - 12:15 AM
I only bring this up because someone mentioned it to me elsewhere on the B&C, but isn't there a 3 detachment limit? Of course, you said this list is mainly for fun games so I imagine if your opponent doesn't mind there won't be a problem
#3
Posted 13 March 2019 - 08:24 PM
In the matched play rules there is a limit on the number of detachments and the number of copies of the same data sheet.
You would be better off taking a Brigade + Super Heavy Aux than what you have posted.
Since you are going after maximizing CP, 15 CP is clearly better than 12 CP.
Two things would have to change with your list in order to do that.
You will need to come up with points for 3 more troops for the minimum 6 required.
You will need to drop 1 of your 6 HQs because the Brigade has a maximum of 5 HQs.
You will probably have more than enough points dropping that 1 HQ to pick up those 3 troops.
However you are only required to have 3 HQs, so you may be able to buff some squads to be more effective with the reduction in the number of required HQ units.
