thewarriorhunter Posted July 11, 2019 Share Posted July 11, 2019 That is what I'm thinking. The one spot that I keep thinking of is the torso platform on the warlord. I think having a little snow on the rails and in the corner of the floor and door would be appropriate, or as you said the armor panels, or along the legs and feet. Link to comment Share on other sites More sharing options...
Kilofix Posted July 11, 2019 Share Posted July 11, 2019 Looks really good. Poor tree! Link to comment Share on other sites More sharing options...
Mandragola Posted July 11, 2019 Author Share Posted July 11, 2019 Poor tree! This amused me. I must have seen a hundred buildings kicked in by titans and nobody bats an eyelid. I kick over one tree and I start getting stick for it. I actually work for an environmental charity, so I'm against kicking over trees in general. I think it works quite well to show a bleak battlefield, as all the smashed trees look sadder somehow than smashed buildings - at least to me. Maybe if the buildings for AT were more domestic-seeming then there'd be some emotional connection to them. Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 11, 2019 Share Posted July 11, 2019 Could drybrush white on the titans just avoiding the vents and weapons where heat will melt. Link to comment Share on other sites More sharing options...
noigrim Posted July 11, 2019 Share Posted July 11, 2019 The void shields stop rain so snow too Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 11, 2019 Share Posted July 11, 2019 (edited) Snow is cold so it can pass though a void shield #makingstuffup Edited July 11, 2019 by Fajita Fan Link to comment Share on other sites More sharing options...
thewarriorhunter Posted July 11, 2019 Share Posted July 11, 2019 Well, I'll figure out what do do with the snow, but I'll do it over in my plog, link in my signature. I don't want to clog of Mandragola's thread with my stuff. Link to comment Share on other sites More sharing options...
Sherrypie Posted July 11, 2019 Share Posted July 11, 2019 Active engines get snow on them all the time, can't really see why titans wouldn't. Sure, they can probably actively get rid of it via heat release when they really care, but in a prolonged skirmish that might be problematic. A proper snow storm gives no quarter, you can clean when it ends, which might very well be after the battle. There will also be icicles under heat sinks and vents, as heat causes meltwater runs that freeze again a bit later. They will fly off everywhere when running and explosions kick up, but ehh... For modeling purposes, snow is fine on these things too. Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 12, 2019 Share Posted July 12, 2019 And the voids aren't always on. Link to comment Share on other sites More sharing options...
noigrim Posted July 12, 2019 Share Posted July 12, 2019 The heat of active voids melts the snow and when active no kind of precipitation can get in Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 12, 2019 Share Posted July 12, 2019 If that were the case then the snow would sublimate and turn directly into water vapor and be trapped inside the void. The next time they go down the water would then freeze out of suspension in the air turning directly back into snow to land on the armor. Link to comment Share on other sites More sharing options...
noigrim Posted July 12, 2019 Share Posted July 12, 2019 Actually the voids work only against the outside, that way the titan can fire its weapons from within the shield. Anyway when the shields come down is under fire so the snow would be vaporized instantly Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 12, 2019 Share Posted July 12, 2019 What if it’s not H2O snow? Also snow would look pretty amazing on Astorum models anyway. Link to comment Share on other sites More sharing options...
Kilofix Posted July 12, 2019 Share Posted July 12, 2019 (edited) There’s quite a number of instances in novels describing rain, dust, snow etc. “sizzling” against Voids. But even then, there would still be ample opportunity for the above to collect on Titans - e.g. during downtime, when it’s kicked up by wind inside of Voids, when moisture from generators freezes inside of Voids, etc. Also, I’m assuming Voids don’t just vaporize everything that gets close (else Secutarii would be all dead). Against slow moving stuff it’s probably more like a high static discharge. Lots of slow moving stuff will get through. Edited July 12, 2019 by Kilofix Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 12, 2019 Share Posted July 12, 2019 Rule of cool. Link to comment Share on other sites More sharing options...
Beren Posted July 12, 2019 Share Posted July 12, 2019 Doom of Mymeara artwork shows a Reaver absolutely covered in icicles. Fajita Fan 1 Back to top Link to comment Share on other sites More sharing options...
Aleczander_G Posted July 12, 2019 Share Posted July 12, 2019 I wouldnt see voids stopping snow. I mean full titans walk through voids to get close enough to punch stuff. I imagine voids only stop things from passing through that are over a certain threshold of kinetic energy. Rain may not pass through as the droplets have reached terminal velocity when falling but I dont imagine snow being effected. Fajita Fan 1 Back to top Link to comment Share on other sites More sharing options...
Fajita Fan Posted July 12, 2019 Share Posted July 12, 2019 #science Link to comment Share on other sites More sharing options...
Dosjetka Posted July 13, 2019 Share Posted July 13, 2019 Ultima Lux is a thing of brutal beauty, Mandragola. You've done yourself proud with that Warlord; absolutely fantastic. :tu: Mandragola 1 Back to top Link to comment Share on other sites More sharing options...
Mandragola Posted July 22, 2019 Author Share Posted July 22, 2019 Well my Acastus turned up. I've built one, though there's obviously no need to share a pic as it looks the same as everyone else's right now. What a kit. The detail on the knights for AT is just phenomenal.Can't wait to get one painted up, though the fact I've got a holiday and a house move lined up in the next couple of weeks means I don't know when that'll be. Reyner 1 Back to top Link to comment Share on other sites More sharing options...
Mandragola Posted August 4, 2019 Author Share Posted August 4, 2019 With the arrival of the titans of Legend, I decided to make myself a new Reaver, to be Lucius Praetorian - or "Lucy". I also thought I'd try and replicate the pose from this classic old drawing of a Reaver from the 1988 version of AT: The trees I've been using so far are a bit too small for a reaver to stand on, so I've used some thicker bits of wood to represent the ones in the picture. I made these out of a knackered old paint brush that I snapped in a few places. On the other side I pinned her on a bit of sprue to get the height right. I then built up the hill with a bunch of bits of rock. In the image the Reaver is on the slope of a hill but that's not really possible on this base, so instead there will be a slope up leading to a cliff edge. This will need a lot of filling in of course to get the slope. I'll probably use some plasticard or something so I don't have to use a whole pot of fake mud. Otherwise I don't think my weak wargamer's arms would be strong enough to lift her up. I quite like how the brush has broken. It looks quite a lot like a shattered tree if you ask me, with the paint on the brush forming a layer kind of like bark. Should look ok when painted. Here's where I'm up to. She's been magnetised and has a head now, with some borrowed weapons to show how she'll hopefully end up. I might see about making her a left-handed volcano cannon that angles up like in the picture and a right-handed power fist. That's probably not how I'll run her most of the time though. What do you think of her? Brother Captain Arkley, Dark Bjoern and Mendi Warrior 3 Back to top Link to comment Share on other sites More sharing options...
Mendi Warrior Posted August 4, 2019 Share Posted August 4, 2019 Very nice! For the slope, I would use polystyrene covered with a nice layer of polyfilla. The polystyrene gives volume without weight and the polyfilla allows for more texture and protects the polystyrene when spraying it. Link to comment Share on other sites More sharing options...
Mandragola Posted August 4, 2019 Author Share Posted August 4, 2019 That's a good call on the polystyrene. I don't actually plan to spray the base at all - the titan isn't glued on yet. The mud stuff will protect the polystryene anyway. Wonder where I've got some polystyrene. Link to comment Share on other sites More sharing options...
Fajita Fan Posted August 4, 2019 Share Posted August 4, 2019 (edited) I was going to try this but didn’t realize Reaver legs could bend that far! Edited August 4, 2019 by Fajita Fan Link to comment Share on other sites More sharing options...
Bjorn Firewalker Posted August 5, 2019 Share Posted August 5, 2019 Impressive customization. Link to comment Share on other sites More sharing options...
