Iron Warriors 750 point mini tournament
Iron Warriors Mini Tournament
  • Please log in to reply
2 replies to this topic
#1
TZ20
TZ20
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 34 posts
  • Faction: Chaos Space Marines
At the end of July, I am going to be attending a mini tournament at a local gaming store and as the title suggests, the points limit is 750 points. I'm at a debate at this point as I have two lists but built around either using the Patrol detachment, or the Battalion detachment. The list also focuses around the Shadowspear box set as it's the first models I have for the Iron Warriors army.
I'll post two lists and just wanted to get everyone's feedback on either, and whether you'd suggest running something different.
Onto the lists.
Idea 1 (Patrol detachment)
HQ
Chaos Lord 100 points
Plasma Pistol, Thunder Hammer
Troops
Chaos Space Marine unit 1 160 points
Aspiring Champion and 9 Chaos Space Marines. Reaper Chaincannon, flamer and champion carries power maul and bolt pistol
Chaos Space Marine unit 2 161 points
Aspiring Champion and 9 Chaos Space Marines. Reaper Chaincannon, flamer and champion carries power axe and bolt pistol
Elites
Hellbrute 108 points
Plasma cannon and hellbrute fist with combi-bolter
Fast attack
Raptor squad 87 points
Raptor champion and 4 raptors. Champion has twin lightning claws
Heavy support
Venomcrawler 130 points
Total 746 points
Idea 2 (Battalion detachment)
HQ
Exalted Champion 82 points
Combi-flamer and power sword
Master of Possession 98 points
Troops
Chaos Space Marine squad 85 points
Aspiring champion and 4 Chaos Space Marines. Missile launcher, champion carries bolt pistol and chainsword
Chaos Space Marine squad 91 points
Aspiring champion and 4 Chaos Space Marines. Reaper Chaincannon, champion carries combi-bolter and power sword
Chaos Space Marine squad 81 points
Aspiring champion and 4 Chaos Space Marines. Autocannon, champion carries plasma pistol and chainaxe
Chaos Space Marine squad 94 points
Aspiring champion and 4 Chaos Space Marines. Missile Launcher, champion carries a power fist
Elites
Hellbrute 120 points
Twin-lascannon and missile launcher
Fast Attack
Raptor Squad 94 points
Raptor champion and 4 Raptors. 1 Meltagun and champion carries a power axe and bolt pistol
Total 745 points
And there are the two armies I have. I'm leaning more towards the second one as it's a mixture of both anti-infantry and anti-armour, but it all depends on what I go up against.
Slow painter, quick reader, many ideas but little time.
#2
Hannibal
Hannibal
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 196 posts
Hi,
my impressions:
1. Definetely go with a Battalion!
2. HQ choices: You can´t go wrong with a Chaos Lord for that reroll ones. Give him a Bolter of any kind to use the mortal wound stratagem on a 2-to-hit, rerolling ones character.
If you´re heading towards a sorcerer, leave that Matser of Posession at home because you do not have that many units that can be supported by his spells. Instead I´d go with a sorcerer who is able to use Warptime, because that is one hell of a good power and can be used on Hellbrutes or Daemon Engines too! That can lead to some surprising moments...
3. Do not use more Marines than you´re forced to. 3 units of 5, nothing more. Champion´s equippment should compliment the special / heavy weapon loadout of the unit. For example: 5 Marines, heavy bolter, champ with combi bolter => max Dakka / low costs. 5 Marines, Plasmagun, Champ with Combi Plasma => good against elite infantry / light vehicles. 5 Marines, Lascannon, Champ with combibolter => las cannon fires at hard targets while all that light dakka fires at infantry.
conclusion:
I didn´t do the maths, but you should be able to run
Chaos Lord
Sorcer of any kind  OR   2nd Chaos Lord
3 units of 5 MArines, Champs with low equippment
Hellbrute
Venomcrawler
Raptors
  • SanguinaryGuardsman likes this
#3
SanguinaryGuardsman
SanguinaryGuardsman
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 785 posts
Do what Hannibal says but also add a jump pack to any Chaos Lord you run that you intend to get stuck in.
And the Master of Possession sucks.  Do not take him.
Also tagged with one or more of these keywords: Iron Warriors, Mini Tournament
