Black Legion 2000 pts Semi-Competitive/Fluffy
black legion competitive
  • Please log in to reply
1 reply to this topic
#1
dakkamasta
dakkamasta
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 282 posts
Hey gang, I'm looking to re-vamping my Black Legion army with models from the new range with a competitive list that still has a solid theme for the army. Interested to see people's thoughts:
1986 Points
12 Command Points
+Black Legion Battalion +5 CP+
+Council of Traitors -1 CP+
+No Force Org+
Dark Disciples - 10
+HQ+
Abaddon the Despoiler - 210pts (Warlord) (WT - First Among Traitors)
Dark Apostle – 72pts <Slaanesh> (WT - Trusted War Leader)
Benediction of Darkness
+Troops+
5 Chaos Space Marines - 75pts <Slaanesh>
- Aspiring Champion w/ bolter, chainsword
- Chaos Space Marine w/ Reaper chaincannon
- 3 Chaos Space marines w/ bolters
30 Cultists - 120pts <Slaanesh>
w/ Autoguns
+Fast Attack+
9 Chaos Bikers - 209pts <Slaanesh>
-Aspiring Champion w/ extra combi-bolter, chainsword
-8 Bikers w/ chainswords
+Heavy Support+
3 Obliterators - 285pts <Slaanesh>
Havocs - 140pts <Slaanesh>
- 2 Havocs w/ Lascannons
- 2 Havocs w/ Autocannons
+Soulforged Pack -1 CP+
+Field Commander -1 CP+
+HQ+
Sorcerer with jump pack - 116pts <Slaanesh> (WT - Veteran Raider)
w/ Force stave
- Warptime, Delightful Agonies
Lord Discordant - 170pts <Slaanesh> (WT - Master of the Soulforges)
w/ Baleflamer
+Troops+
10 Cultists - 40pts <Slaanesh>
w/ Autoguns
w/ Autoguns
w/ Autoguns
+Heavy Support+
Maulerfiend - 122pts <Slaanesh>
w/ Lasher tendrils
w/ Lasher tendrils
***I've got 14 points left but not sure where to put it yet. I'll probably just throw an extra cultist in each squad.
The main aim of the list is to have a solid core that will hold the mid-field with all the other units supporting the central push.
The core of the list is to use Abaddon, havocs, marines and cultist blob slowly advance as a mobile firebase while the daemon engines rush forwards to apply pressure. The obliterators will come down next to Abaddon for rerolls or in the backfield using Let the Galaxy Burn for reroll 1's. The Dark Apostle will usually put the -1 to hit on the Lord Discordant since I know he will draw fire being the only one on the table.
The bikers are for chaff clearing duties, supported by the chaincannons and cultists. Depending on the matchup they will either play defensive by staying back with Abaddon and firing down field, using the cultists to prevent being tagged in combat. Against shootier lists they can push forward, using Tip of the Spear for rerolls if needed and begin tying up units in combat. If they survive, the Sorcerer will allow them to fall back and charge again. They will also be the likely target for Delightful Agonies so that they can shrug off D2 weapons better.
Thoughts?
#2
Debauchery101
Debauchery101
    +FRATER DOMUS+
  • + FRATER DOMUS +
  • 938 posts
Your Disco lord will be killed 1st turn. Hes you need to have an extra one or two or take alpha legion.
I see you like cheap screens..how about taking a death guard battalion...for 704pts you get
Typhus
Malignant Plaguecaster
3x20 poxwalkers
2c foul Blightspawn
I think you should take a melta on your bikers. Also your biker champ cam only take 1 extra weapon if I'm not mistaken. Bikers are good tar pit units as well. A power fist is also another good option. Since they're slaanesh it's very powerful to take the icon...5+ death to false emperor
The Pleasure God's Chosen
Emperor's Children (RIP) 2500 pts
Death Guard 3500 pts
Iron Warriors 3000 pts
Enslaved Traitor Guardsmen 1500 pts
Daemons 4000 pts
Salamanders 3000 pts
Necrons 2000 pts
Also tagged with one or more of these keywords: black legion, competitive
