Szarekhan:
- 5+ feel no pain vs mortal wounds
- Each unit may reroll one to-wound roll in shooting or close combat
- If all units in the army have this dynastic code, then they get both command protocol directives from the Protocol of the Undying Legion when it is active (except for Dynastic Agents and C'tan Shards)
Sautekh:
- Reroll morale tests (note, not just failed tests)
- Rapid fire weapons make double the amount of attacks when within 18" instead of the normal rules
- If all units in the army have this dynastic code, then they get both command protocol directives from the Protocol of the Conquering Tyrant when it is active (except for Dynastic Agents and C'tan Shards)
Mephrit:
- Add 3" to ranged weapons (not pistols)
- Improve AP by 1 when in half range
- If all units in the army have this dynastic code, then they get both command protocol directives from the Protocol of the Vengeful Spirit when it is active (except for Dynastic Agents and C'tan Shards)
Novokh:
- Add 1 to charge rolls
- Improve melee AP by 1 when charging, when charged, and when Heroically Intervening or Intervened
- If all units in the army have this dynastic code, then they get both command protocol directives from the Protocol of the Hungry Void when it is active (except for Dynastic Agents and C'tan Shards)
Nephrekh:
- 6+ inv save
- When a model advances, it translocates instead. It auto rolls a 6 for the extra distance, and can't shoot
- When a model falls back or translocates, it can move through terrain and enemy units.
- If all units in the army have this dynastic code, then they get both command protocol directives from the Protocol of the Sudden Storm when it is active (except for Dynastic Agents and C'tan Shards)
Nihilakh:
- All models gain Objective Secured. Any models that already have Objective Secured count as two models for determining control of objectives
- AP -1 counts as AP 0 when wholly within your own Deployment Zone.
- If all units in the army have this dynastic code, then they get both command protocol directives from the Protocol of the Eternal Guardian when it is active (except for Dynastic Agents and C'tan Shards)
So there will be 6 Protocols that can become active. Each one gives 2 buffs but you can only choose 1 when it's active. Each Dynasty allows you to take both buffs for their designated Protocol.
Dynastic Agents! What do we figure these are? The easy picks are those that didn't fall under any dynasty in the past, like the Praetorians. Wonder what else might get added to that.
Dynasties here:
Canoptek Doomstalker
Lokhust Heavy Destroyers
Triarch Praetorians
Lychguard
Canoptek Spyder
Canoptek Wraiths
Triarch Stalkers
Immortals
Deathmarks
Edited by Seahawk, 13 August 2020 - 02:59 PM.
