Slight tangent but I hope the mods allow it: If you use Firefox (like I do) and only see these weird codes instead of images (like I do) then press right-click on the code and then the middle mouse button on "View Image". The middle mouse button just opens it in a new tab, so you've got the B&C still open to check out another link, compare images, etc.
It should be the same or similar with other browsers.
I don't know exactly what I did, but the images that are only showing weird codes are hosted on Facebook and since I don't use that and Firefox has a special Facebook Container, I guess it prevents them from loading a preview.
But now something on topic: Am I seeing this right and the Invictor's Heavy Bolter is down to one shot only? It's still Heavy, not a Pistol (even though he uses it like one)... weird.
That's sorted it, cheers
Oddly enough I regularly open images in another window using that technique, but I never thought to try it for the image codes.
I'd also noticed that it was images hosted on FB. It never occured to me that it was the new Firefox FB container that was causing the issue, but it started happening just after they introduced the container and now I check back, only with FB hosted images.
Hopefully I can pass this info forwards to someone else.
