Not able to see my content/follow tab
#1
Posted 30 October 2020 - 12:22 PM
A few weeks ago a stopped being able to see the above. It just takes me to my Internet service provider screen. The layout of the main page has changed also, with admin section now at the bottom where previously was at the top. Not sure if this is linked. Can this be fixed? Cheers.
Current event badges
Past event badges
#2
Posted 30 October 2020 - 12:26 PM
The order of the Forums was changed, but I don't think it's related. For Warriorfish who'll probably be the one to trouble shoot it properly, is it Desktop or Mobile? Which browser are you using?
Check out my current and past projects HERE Heralds of Devastation
Conquest Collecion Death Guard and Adeptus Titanicus Warlord and Reaver now on eBay
Giving Fiverr a go, model Painting, Assembly and Conversion Commissions available
#3
Posted 30 October 2020 - 12:37 PM
Past event badges
#4
Posted 30 October 2020 - 03:52 PM
Just to be sure we understand you...
When you say that you aren't "able to see the above" (My Content and Content I Follow tabs), how are you getting there? My assumption is that you're clicking on the links from the dialog box that appears when you mouseover the drop down arrow that appears next to your display name at the top left of the screen (I view almost exclusively on PC, so it might look different when using the mobile skin) - see the top left of the image above. When you click either of those links, you are instead taken to your Internet provider screen. Is that correct?
If you're getting there by some other method, please describe and/or provide screenshots.
Is anyone else having a problem seeing these things?
#5
Posted 30 October 2020 - 04:40 PM
Super secret forums........ interesting!
Past event badges
#6
Posted 31 October 2020 - 03:56 AM
If that's close to what you're seeing (it's probably much narrower on your mobile device), then it would be more accurate to say that the problem is that you can't see your profile info or the drop down box from it.
If you look at the bottom center, you'll see the "Full Version" button. Try clicking that to change to the carbon skin (the one I showed in the first image). That's the default skin for PC users, and it works just fine on mobile devices (though you have to scroll horizontally). It doesn't solve the problem (we'll look into it), but it will get you to the stuff you need in the interim. On the few occasions on which I've used my cell phone to browse the B&C, I always use the carbon skin instead of the mobile skin.
For what it's worth, one of our goals with the site upgrade will be to make a mobile skin that is much closer to the default PC skin. It will be optimized for mobile devices, but we don't want mobile users to sacrifice any functionality just because they're on mobile devices.
In the meantime, we'll look into this to see what we can do about it.
I've said too much.
#7
Posted 31 October 2020 - 08:21 AM
It takes me to my provider and says no Internet connection and gives me an option to reconnect. When I do it takes me back the the b&c which says sorry would couldn't find that.
As far as I can see everything else is working as is.
I've said too much.
I have a feeling I've come across this situation before.....and an strange urge to go to the apothecarion for a 'procedure'........
Past event badges
#8
Posted 31 October 2020 - 09:16 AM
To confirm, this is the link you're going to for the followed content:
http://www.bolterand...rch&do=followed
can you try someone else's content link e.g:
http://www.bolterand...ivity&mid=30308
Getting the "no Internet" is strange, as this shouldn't be related to the page you're visiting.
In the grim predictability of online 40k, there can be only Sun Tzu quotes
SM Ironclad | IG Stormies | =][= Stormies | AM Armigers
CSM Terminators | TSons Rubrics | Daemons Daemonettes
DE Warriors | Tyranids Genestealers
#9
Posted 31 October 2020 - 10:17 AM
It's baffled me to be honest as obviously do have an Internet connection.
Past event badges
#10
Posted 31 October 2020 - 02:44 PM
Very strange indeed, is there anything locally that could be interfering such as add-ons to your browser or similar?
#11
Posted 31 October 2020 - 07:17 PM
Past event badges
#12
Posted 01 December 2020 - 09:31 AM
Past event badges
