Xenith Posted September 13, 2021 Share Posted September 13, 2021 (edited) ++Neurothrope++ We have a new unit of the week! Having already discussed all codex and Forge World datasheets, we're working our way back throgh some of them. This week it's the Neurothrope. Previously discussed under the same topic as the Zoanthropes, I feel that the Neuro is sufficiently distinct from the Zoans to deserve its' own topic. What are you thoughts, and how best would you use them? To compliment a list, or to build a list around? Will the beta rules affect your list(s)? What size unit? Will you be running multiple units? What Hive Fleet Traits, Adaptative Physiologies and Stratagems do you prefer and how much does it depend on the above choices? Are you buffing this unit? If so, how? Uses in Matched, Narrative and Open Play Over to you. Tyranids Unit of the Week Index Edited January 4, 2022 by Xenith Link to comment Share on other sites More sharing options...
Xenith Posted September 13, 2021 Author Share Posted September 13, 2021 So as Neuro's are different enough from Zoans to have their own place in lists without Zoans, and as we have a relatively new edition, how are you using your Neuros? One popular use I see is as a HQ in a Kronos detachment with Symbiostorm, casting it on an exocrine. Symbio gives an extra hit on a 6+, the exo gets +1 to hit if it stays still, so it gets extra hits on a 5+. from 12 shots, you're expecting 4 5+'s, in your 8 hits, so really looking at 12 hits/100% accuracy. Those 12 hits will then likely annihilate whatever they hit. Otherwise, the Neuro is my first choice HQ in smaller games where I'm not using my tyrant. It can kick out 2 powers per turn, which are usually smite and catalyst. Resonance barb seems a great choice on this at first for the +! to cast, however the second part of the barb allows you to manifest another power. As the Neuro only has 2 powers, it doesnt have a 3rd for the barb to take effect, so I prefer the barb on tyrants. In my crusade campaign I've been running it as Jormungandr, which is pretty much a waste, I see much more benefit as Kraken for super advances, or Leviathan, for the 6+++ on everything without needing catalyst. Comments on the Neuro from the previous thread: I prefer to run mine as Neurothropes for the following reasons:- They’re durable with a 3++ and character protection.- They’re cheap synapse beacons.- Reliably cast powers with re roll 1’s.- Can cast two psychic powers.- Heals wounds via smite.- Point for point more efficient than zoan’s.- Second cheapest HQ to help fill out detachments. XeonDragon 1 Back to top Link to comment Share on other sites More sharing options...
WarriorFish Posted September 13, 2021 Share Posted September 13, 2021 I've not got one sorted yet, but my thoughts match the above in that they look like a solid HQ choice that doesn't break the bank. Great for smaller point games, and as support for larger ones. I also noted that if you want the psychic output they are better than Zoanthropes, but you're not likely to be loading up on Neurothropes over it. I might get to mine next Bug's Life vow now I think about it, I have one of the old metals and for legacy/history reasons decided that he'd be a great Neurothrope letting the new plastics be the Zoans Xenith and XeonDragon 2 Back to top Link to comment Share on other sites More sharing options...
Xenith Posted January 3, 2022 Author Share Posted January 3, 2022 Time to get back to the Neurothrope! With the new Octarius system book, Tyranids gained a whole slew of 'Synaptic Abilities', that enhance our bioforms. The Neurothrope brings the Synaptic ability 'Psychic Creep', allowing you to drop a -1Ld and -1 Attrition test penalty aura on a unit. Normally I'd think this is pretty weaksauce, but with some crusher stampede rules, we can stack some things to make it interesting: Savaga intimidation is an additional -1 to tests (along with a greta -1 to hit). Stick creep on it, then pop off terrifying charge for 1CP and your opponent is taking LD tests at -4Ld with -2 on attirition tests, which might get a few more. Situational as hell, but might help big beasts cut through hordes faster. Thoughts? Link to comment Share on other sites More sharing options...
Azekai Posted January 3, 2022 Share Posted January 3, 2022 Time to get back to the Neurothrope! With the new Octarius system book, Tyranids gained a whole slew of 'Synaptic Abilities', that enhance our bioforms. The Neurothrope brings the Synaptic ability 'Psychic Creep', allowing you to drop a -1Ld and -1 Attrition test penalty aura on a unit. Normally I'd think this is pretty weaksauce, but with some crusher stampede rules, we can stack some things to make it interesting: Savaga intimidation is an additional -1 to tests (along with a greta -1 to hit). Stick creep on it, then pop off terrifying charge for 1CP and your opponent is taking LD tests at -4Ld with -2 on attirition tests, which might get a few more. Situational as hell, but might help big beasts cut through hordes faster. Thoughts? Would this combo be better used on elites, maybe? -4 is pretty significant and if even a single terminator (or whatever) fail the test and gets removed that is better than chaff killing, since almost anything can kill cheap chaff. WarriorFish and Xenith 2 Back to top Link to comment Share on other sites More sharing options...
Xenith Posted January 4, 2022 Author Share Posted January 4, 2022 I guess it's good for anything then! My thinking was that most Tyranid MONSTERS are suited for elite infantry killing with low attacks and 3D weapons - we're bad at hordes, bar maybe the Haruspex. Link to comment Share on other sites More sharing options...
