Grey Knight Terminator From AoBR Terminator conversion
Karitas
I've been asked for this several times, both here and on my blog so I decided to document the next one I had a crack at.
(I've also had to split this up into parts due to the pic limit.
We're going to assimilate this scrap AoBR terminator into a proud Grey Knight Terminator
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5020.jpg
First off, a List of What's needed.
The Bitz
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5025.jpg
Plasticard!
Cereal box card (optional)
Plastic Rod
GS
FW =][= Brass etch symbol
One complete AoBR terminator
One Thunder hammer arm
One storm shield arm
Any space marine hand
A suitable blade (I’m using Dark angels ones due to the unique shape)
A purity seal or scroll etc for “dressing”
And the tools used :
Superglue
Scalpel
GS sculpting tools
Pin vice / Drill
Fine files/sandpaper
q-tips
Acknowledgements
There are other tutorials out there which cover pretty much every aspect of this build, some I’ve used, some have been pointed out to me since posting the models.
The two(three) that most directly relate are Ron Saikowsji’s Pre-heresey terminators over at From the warp, and related to that iktovian’s template for PH- Pads.
And USABOB’s picture tutorial on plastic GK termies, which I hadn’t actually seen until someone directed me there, I’ve done almost exactly the same as him, but with less pinning and more GS, and I think a different magazine – I use the existing one, he uses a rhino mounted one.
I can only hope if BOB every sees this tut he wont think I’ve ripped him off.
Anyway, onward -
So here are the step-by-step stages of making this fellow
Part 1) The close shave
First thing is to prepare the AOBR termie, by shaving off all the unnecessary bits.
Head – we make a few select cuts here, shaving off some of the detail from the flat planes thus,
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_502226.jpg
Then following the line of the eye here, we make a cut each side,
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_502228.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5029.jpg
shaving down until we are happy with our new mr. pointyface
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5030.jpg
If you like you can drill some “breathing holes” in one or both sides at this point. I do this to about half the squad, and in different patterns / sides. I’m going to leave this guy vanilla though.
Chest – all detail removed to make a nice flat surface
The stuff in red has to go. I use a sharp blade and then finish with a file or abrasive paper
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_503222.jpg
The result is this:
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5034.jpg
Legs – again, protruding details removed to make way for the plates later
Anything that "sticks out" has to go.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5035.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5036.jpg
if you aren’t a fan of the leg plates leave these intact and use the legs as is. Personally I feel the bulk of the shoulders demands some bulking of the legs for balance.
Okay so there he is prepped and partially converted, next is to start adding bits back on.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5037.jpg
Continued in part two
Continues from Part one
2) The Build
The Head / collar.
For this we need a thin strip of thinish plasticard.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5038.jpg
Now I’m terrible at measuring, I tend to go “by eye” its the same when I cook, paint, whatever, so it’s about this big, and it gets fenegled to fit with a few dry fittings and a bit of a trim, until we have this –
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5042.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5039.jpg
Which can be happily bent around a paintbrush to provide the curve
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5040.jpg
And then glued into place
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5043.jpg
The Nemesis force weapon
Here are the components for the NFW,
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5044.jpg
and the cuts required to get at the good stuff we need
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5045.jpg
The assembly
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5046.jpg
and the product.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5047.jpg
simples :)
The storm bolter
The bolter is made from....
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5048.jpg
Broken down into -
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5049.jpg
and reassembled thus -
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5051.jpg
Positioning the arms
At this stage and before I affix them or do any GS I get the arms to fit correctly for the pose I want. The posing of AOBR figs is very limited, but since we will be adding our own shoulderpads, we can do what we like to their usual mount, the shoulder nub.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_505222.jpg
Its this nub that dictates the angle the arm sits at, so whatever we shave flat here, will affect the final pose, experiment with trimming and test fitting until you have a pose you like. Any big “underarm gaps” can be filled and hidden later
Oh, yeah,
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5055.jpg
It's at this point you should glue the Brass etch in place,
Giving us this assembled Grey Knight to be, awaiting his first Greenstuffing.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5054.jpg
Continues in part three.
Continues from part two
3) The Features
The greenstuff – round 1.
The first part of the GS is to prepare each piece, -
The Bolter shroud is probably the first part you should do, it’s easy and it needs to be cured before you can start attaching arms if you want to avoid fingerprints.
You're aiming for roughly this shape, - the feeling that the whole bolter is some kind of armour peice or "cuff"
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5058.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5059.jpg
Next is the body, first step is to pack the GS in there where you need it,
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5060.jpg
then smooth and shape it to your heart's desire
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5061.jpg
Once cured, clean off the Vaseline with a q-tip and we're ready to move on.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5066.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5062.jpg
The plasticard
Here is where I cut and fit the custom pieces, I have to give props here to Ron Saikowski over at From the Warp, without his tutorial and emails I wouldn’t have got these stages down.
Anyway I draw out the following, and mount to plasticard.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5063.jpg
I cut out the scrap insides
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5065.jpg
I then mount this onto cardstock. (the previous two models I used cereal box card, for this one I tried using all plasticard, having found some very thin sheet styrene, allowing me to make the leg plates a little thinner and the feet more visible, as people seem to have expressed a preference for)
And cut the outline
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5067.jpg
A little curving round the brush and we are ready to go
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5068.jpg
Glue in place
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5070.jpg
You can see some issues with the new thin styrene in that is has a tendancy to bend in one place rather than smoothly, not a problem though, a rub over with a sculpting tool smoothes away most of this.
Next we put in some structure for a Tabard – a simple peice of styrene for mount, thicker card this time.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5071.jpg
Affix arms
You can pin these if you wish, but I haven’t needed too yet, there's lots of plastic to plastic surface area which means good glue adhesion with CA.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5073.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5074.jpg
Once the arms are on we can Affix the shoulders.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5072.jpg
Bend,
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5075.jpg
place,glue.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5076.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5077.jpg
Greenstuff round 2 - tabard and edging
First up, repair any cracks or visible seams in the plasticard parts
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5078.jpg
After that we are going to apply GS to the tabard plastic to build up folds and create a dynamic shape.
Slap it on first.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5079.jpg
Then refine the shape
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5080.jpg
Then smooth and improve
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5081.jpg
Don’t forget the back
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5082.jpg
Continues in part 4
Continues from part 3
Detail and done.
Last step is to glue on a few purity seals and bolt heads
The seals just get glued in place, along with a few skulls to "hold the tabard on"
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5084.jpg
Then the bolts
Theres a trick to getting little things stuck on,
use a Cocktail stick as a glue applicator, dip and drop.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5085.jpg
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5086.jpg
then use a Needle to deposit and position the item
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5088.jpg
There we are.
One GK Termie, from an AoBR box.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_5089.jpg
And last but not least, Here is the whole thing primed and ready for paint.
http://img.photobucket.com/albums/v335/Karitas/Grey%20Knight%20tutorial/DSC_509229.jpg
(of course hes just "resing" in place as I'll paint them seperately.)
All I can say is I hope that tutorial had value for you and if it did, please let me know.
If there's anything i've taken for granted you know, or if you've any questions in general, let me know what I missed or what you'd like to know and I'll do my best to answer.
I'll put up a tut for the Base in the basing section here at BnC, please also note my blog has this tut in a single chunk and a good few others.
Link to basing tut
I made a simlar mistake where I made multiple topics thinking it was the only way to fit in all the pictures, but you could roll them all into one by replying to your frist post making it 1 topic. The converting is very good I like it, how do you do the book on the shoulder pad? theres books on the dark angels frame so you use those?
I'm an idiot.
when it shut me down from uploading i just made multiple posts, why didnt i reply to myself?
put it down to being tired as this thing took a huge amount of putting together from the old copy/paste aspect.
/sigh
if a mod wants to tidy this up, feel free, I could consolidate but i cant delete the mess i dont think.
anyway, thanks for the positive comments guys, and those who have pmed me, it's appreciated ;)
Really useful tutorial and very tempting to try myself, however I'm definitely stealing the shoulderpad technique, I've seen similar tutorials before but I like the simplicity and effective results of this one..
How you went about creating your tutorial was probably the best way Karitas as you would have had to deal with the board's flood control filter.
I don't see any need to do any 'clean up' the thread though since it's become a fully functional thread after the merger :)
Much appreciated Angelus, I'll try to be a bit neater about it next time though, if i ever post another tut. :wallbash:
and to those comments above - I'm glad they might be of use to some of you. i accept that not everyone likes my big legs ;) personally i thik without them the models look too top heavy, but I'm also able to see why people dont like them.
If I hadnt started back in RT I think i would have a very different idea about Tactical Dreadnought Armour but as i did i cant help thinking of the big lumbering things of 1e space hulk and that middle word there, Dreadnought.
I also totally understand the PH comments, Mainly because i stole the idea for the shoulders, after trying a few different types, from Ron saikowski at the from the warp blogger group and his Pre-Heresy tut. :)
I never really liked the shape of the metal GKT's - i think the are a little too "pointy" in the upper torso and the huge imposing shapes of PH armour just spoke "knight" to me much more. i know fluffwise the GK stuff veers wildly between them having the newest and best in one panel and having ancient and revered relics in the other, but in the end i figure if i'm going out to fight a demon, i'd like a lot of metal around me :)
  • 3 weeks later...
Thanks for posting up this tutorial. The helmet-cutting tip actually made me go and try that on a model to make me a new Terminator Captain. And when I get the materials I'll probably try the Force Weapon too.
http://i811.photobucket.com/albums/zz37/braintick42/SDC10846.jpg
  • 1 month later...
  • 1 month later...
